indianaoutback
Location
Cincinnati
indianaoutback's Achievements
Member (2/11)
10
Behind the passenger side tire (front) there is a plastic cover (that extends all the way around the wheel well). Take the wheel off, unbolt that cover and see if the drain (pull black drain cover off) is plugged up with sand, dirt and whatever else. Rainwater runs off your windshield down the drain system on the passenger side and if that exit is plugged the water runs back into the car above the passenger floor. It has happened to me twice.... first we thought the windshield was leaking and then the cowling below the windshield, etc. Try it and see if that helps.
Thanks everyone, but.........we've cleaned the injectors, fuel filter, air filter, new plugs and wires, just replaced the starter, neutral safety switch and coolant temp sensor. The dealership replaced the air control valve and ignition coil pack........all that in four months and the car still does the same thing. The throttle body has also been cleaned. The symtoms started right before we replaced the second stage catalytic convertor. You warm the car up, drive for awhile, come to a stop, the tach drops below 0 and the car dies. Turn the key and it fires right up. Won't do it again until after a long high speed run. Any ideas would be appreciated. By the way, the code reads P1507............
Nothing wrong with the BFG's, but nothing great. The TT's seem to handle better on dry and especially wet pavement (but they're still new, so I can't give you a 'wear' opinion). The Scorpions did not like grooved concrete pavement and the Mich. were just average in every category. The only Bridgestones that will fit my stock wheel (that I considered) were Turanzas, but I didn't try them. Tire Rack is really a good place for any tire info........
Unfortunately my local dealership has seriously hosed me in the last year...... billing me for parts that I didn't need, overcharging me for parts and basically screwing up my car so badly it's taken a month for my independent mechanic to get straightened out. They have even denied there were recalls for my car that were listed on the internet. And even worse, they own the other major dealer in my area. So, I'm looking for someone that is honest and has the parts available.
I've got a '99 Outback and have run original Michelin XW4, two sets of Pirelli Scorpions, BFG Traction T/A and currently have a new set of Goodyear Triple Treads. So far, the Goodyear Triple Treads (never thought I would say this about a Goodyear tire) are the best tires I've ever run on this car (I drive about 25000/year).
idle air control valve for '99 outback/forester
indianaoutback posted a topic in Subaru Retrofitting
dealer installed an air control valve listed for a 98-99 forester on my 99 outback (with a 2.5 engine). are they the same part?
