Ned P Pritchard
Everything posted by Ned P Pritchard
  1. Any Ideas where or how to replace ? may be easier to replace the whole back hatch any Ideas apreciated.
  2. Will this be legal in california ? will it pass smog inspections ? my choke is broken . I need to replace with a new or other system where can i get this piece ? IE / choke cover and spring coil.
  3. Hey where is this part available / ? Is there an other usable part of another car that will work? 86-GL wagon carb.
  4. 86 gl hard to start choke is not working properly / how to adjust replace and check if it still good. choke is not stuck flapper moves freely .EA 82 Hitachi carb. please help?
  5. Hey thanks for yhe reply . When I open the cap no whoosh sound maybe not sealing New gas cap what should I check for leaks first ? This car has a carb Isn,t this vented to air ? can I cap the vent lines with a BALL BEARING IN the lines to pass the pressure test need to get it sealed somehow, thanks NP
  6. What can I do to insure a pass of smog tests ? I have an 86 4/4 GL wagon carbed standard trans runs well. Timing is set to 8 or 9 degrees before standard I beleive , Idle is set at 850 RPM standard range. any TIPS OR IDEAS ? what about fuel tank tests and Vapor cannister systems { DIY} ideas needed ASAP thanks alot . NP> PS I just cleened EGR valve
  7. Before I swap to the discs / will I need to change anything else to make it work well # proportioning valve # master cylinder # with out tomuch slop at the pedal /86-4-4 standard trans gl wagon Thanks Ned.
  8. Hey what brand of exhaust ? EA-82 or EA-81 ? Have you heard of D.E.C. catylist.
  9. do you meen the thermal vacum valve mounted on the Intake manifold, where can these Be had . How much ? Thanks.
