mccullough
Location
Idaho
Interests
Mechanics
Occupation
Juvenile Probation
Biography
going bald
mccullough's Achievements
Advanced Member (3/11)
10
I blew out the low beam on the passenger side of my 2011 Outback. I figured I could just lift the hood and replace it like my 1994 Legacy or my 2000 Legacy...WRONG. Access to the light is buried under the frame and I'm sure there is a simple procedure for this fix. Someone please direct me to this post as I have looked and cannot find it. Thank you so much in advance. :-p
My dad and I went to replace the timing belt on my 2000 Subaru Outback (2.5l SOHC). When he removed the belt he did not align the crank/cam sprockets. I know the cam sprockets moved a little. What is the procedure to get everything back in alignment without destroying the valves or pistons? Can we simply put the belt back on and bring everything close to alignment once all the timing marks are pointed towards the top, or are we going to hurt the engine? The crank mark is almost pointing straight up, and the cam marks are down at different angles. HELP US
I found the specs for the timing belt tooth count for my 96 EJ22 40.5 to the right and 44 to the left. I have all my timing marks lined up and the count on the left is 41.5 which is what it was before I took it off. If I move it to 40.5 the cam timing mark on the left cam would be 1 tooth off to the inside of the notch. Whats more important the tooth count or the timing marks lined up perfectly?
Completed my first timing belt replacement on 96 Legacy EJ22. When I look at the cam lines and notchs with the crank line and notch perfectly lined up, the right cam line and notch (looking from front of engine) is perfect. The left cam line however is just outside of alignment, just outside to the right of the notch. I used a OEM Subaru belt I got at the dealer. Is this imperfect alignment (slight variance) going to cause me problems.
I replaced the left head gasket and the timing belt (from Subaru Dealer) on my 1996 EJ22 and now get very bad gas mileage (20 mpg). The engine sounds good but is it very possible to be off on the timing belt a tooth or 1/2 tooth and it still sound like it is running good? Also would changing just 1 head gasket mess the whole timing belt process up? Thank you for your help.
I have a 96 Legacy Wagon (EJ22) that I changed timing belt on (counted belt teeth and done correctly) and had to replace a head gasket. Although it sounds like it runs great I smell the slight odor of unburnt gas at start up. My gas mileage is 25 mpg's at best in both cold or hot weather. I moved my knock sensor around to see if this would make a difference and it did not help the problem. Any ideas what the culprit might be? It was getting 31 mpg's before I changed the belt. It has 144,000 miles on it.:-\
I have not changed the wires but have recently tuned it up w/new air filter, spark plugs, fuel filter and I cleaned the MAF. The car is usually empty w/o alot of junk in the back. I guess I'll replace the spark plug wires and see what happens and then the O2 Sensor if that doesn't work. Thanks much, Dave
I fixed my knock sensor problem in my 96 Legacy Wagon 2.2L and my gas mileage did not go back up very much. It was about 21 and is now 23 mpg. I can still smell a slight unburnt gas smell at start up but the engine runs and sounds good. Any ideas? I wonder if the knock sensor on it's way out could cause this. I only have 130,000 miles on it.:-\
