oregonloyale
Everything posted by oregonloyale
I was running some tests on my 90 legacy wagon 2.2l manual trans and found that my IAC is bad. The car is idling at around 2k @ normal op temp. pulled the IAC with ign. on , engine off and the plunger is all the way up inside the housing , w/the electrical connectors attached. If I unplug the IAC with the ign on , engine off , the plunger falls out of the housing. Also lost the spring that goes inside , GRRRRRRRRRR. Any help would be great. Suppose to sell the car tomorrow , but thats probably not gonna happen now. Also the lead wire has 3 prongs and the IAC only has 2 . I think its the wrong IAC to begin with?
OK codes are cleared . Check engine light stayed off till I got about 2 miles down the hwy @ 60mph. Need to pull the codes. Bought some electronics cleaner for the MAF and to R&R the old O2 sensor since i dont have the money to replace it. The electronics cleaner I have will 0 residue and has no flashpoints . I have used it on many a VW MAF. I should have the outcome by late tonight.
I have cleaned many a MAF on VW, as they are my primary tuning vehicle. Remove Maf from inttake. DO NOT TOUCH THE INSIDE OF THE MAF!!!!!!!!!! I cannot stress that enough , they are brittle and easliy snap. Get a can of Non conductive electronics cleaner. The kind that leaves "0" residue and start spraying. You can spray everywhere , its "0" residue and will not hurt the electronics as this is what the cleaner is for. Others say get some alcohol based cleaner, I forget exactly what but then put the cleaner in a bag w/the maf and shake. That is a NO NO in my book as it falls back to the fragility of the MAF. Legacy777 can attest to the fragility of a MAF . He foound out when he did the open filter element and didnt bracket it well enough and all the jarring around screwed up the MAF. So anywyas back to the cleaning. Once you have totally spryaed thpiss out of it let it sit in a nice room temp area and go have a beer, lets say 30 min. Then come back inspect for any residue, I doubt there will be , and bolt it back up. I would reset the ECU before firing it back up with the cleaned MAF , but thats just me . This way I would be starting from scratch, so to speak.
Ok car is sitting overnight with the battery unplugged because its 1am and Im to tired to do anymore. Ill hook it back up in the mornin. ECU will def. be reset by then , LOL. Anyways , man the trans fluid was LOW. Barely even showed up on the dipstick. Drained it and refilled it with 80w90 GL-5 gear oil Drained and filled oil with 10w30 syn blend (Conoco) Seafoamed the engine thru the PCV valve - I actually removed the PCV valve and filled thru the hole so as to get all the cylinders = smokey , LOL Replaced old gunked up PCV with fresh new one Realigned the driver window and got it back on track, rolls up and down nicely now. And pulled all the codes as stated above. Well see what tomorrow brings. Im going to bed. Goodnight.
ahhhh ................. I hear ya. Well so much for that idea. Gonna just try a overnight drain of the trans gear oil and then fill with fresh 80w90 stock and see if that works. If it doesnt work then Ill try some high dollar stuff. I can fill my trans w/the stock 80w90 for the same cost as 1 quart of redline. Hebce try the cheap stuff 1st . Its not like its gonna hurt anything.
