mwells
Location
Paintsville
mwells's Achievements
Member (2/11)
10
The car has 98K on it. Where is the knock sensor connector located? Is it near the air box? I'm not a mechanic, so excuse my egnorance. Also, I will be changing the fuel filter, the service manual says to disconnect the connector to the fuel pump...then start the engine til it dies...and then disconnect the lines from the old fuel filter. Where is the connector for the fuel pump located? With this knock sensor code(PO328) is it dangerous to drive the car? Thanks for all the help.
I have a 2000 Outback Wagon that has a PO328 Code with CEL light on. The car runs fine. I've been getting a PO420 code for some time, but the PO328 just happened Saturday. I had a local "oil change" outlet change the air-filter for me and they failed to install it correctly. They hadn't aligned the tabs at the bottom where the air-filter mounts and it was "sucking air in" on acseleartion. I corrected this and that's when I got the PO328 code. Is this a knock sensor code..? I plan on changing the front O2 sensor this week along with the fuel filter and PCV valve.
While driving this car at lunch...I'm going up hill..I accelarate to pass a car and I notice I don't have the power I used to have. I get some "belching" from the engine..some "missing"..before I can get enough speed tp pass. I also see that the CEL has came on and is "flashing". Is this serious? I ordered new oem wires, plugs and an o2sensor. What else do I need to look at? Does Advanced Auto still pull the codes from this car for free? Thanks...
I have a 2000 OBW with 91000 miles. I just had the head gaskets replaced plus some other things it needed (belts, etc) at this mileage. This was about 2000 miles ago. I am now getting a slight "miss" or fuel problem or transmission slip when the car is running between 30 and 45 mph. It only happens when the car has shifted to 3rd and I have to accelarate just slightly I feel a "miss" or something. After I press the gas and it shifts to another gear I don't feel this. The car operates fine when pulling out or at "highway speeds"(50+). Could this be the transmission or is it a fuel filter or something? Thanks for the help.
Just wanted to let everyone know...took my Outback to dealer yesterday..yes, it was head gasket..leaking oil AND coolant. Although slowly...I wasn't seeing any loss of coolant and oil loss wasn't even reading on dip stick. AND I'm having all those things done we metioned earlier w/ no labor cost..just cost for parts, because they have to pull engine anyway. Hopefully this vehicle will last another 90-100,000..I really love this car. Just had brakes and Goodyear Assurance Tripletread tires installed about a month ago...(love those tires too.) Thanks again to everyone who posted on this thread.....love this board!!
Assuming that SOA takes care of the head gaskets, and I think they will, what should I expect to pay(parts, labor, etc) for replacing the following items while the dealer has the engine pulled: 1. Oil Separator 2. Rear seal 3. All Front Seals 4. Timing Belts 5. Tensioner 6. Water Pump How many days in the shop would the above scenario involve? I'm just trying to get an idea on the magnitude of this job, and trying to have all the things done that need be done while it's already torn down. Thanks again for all the help.
I have an appointment with the dealer to address the head gasket problem with my Outback. When they do the gasket job, at 89,000 miles, what other things should I have them look at? As long as they have to pull the engine anyway, what other preventative maintanence things could/should they do? Thanks alot for all the help from this board.....
The fellow I spoke with at the dealership this morning told me "9 times out of 10 that's usually the problem"(head gasket). I don't seem to be loosing any coolant..and the oil leak isn't enough to leave a "spot" on the ground, but it sure looks like a mess underneath. It's seems(to me) to be pooling right under the oil pan, best I remember, and blowing back onto the "y" exhaust and then smoking. When you're setting still at idle you sometimes get, especially with the heat on, a smell of burnt something. With the heat off I smell nothing. I used to take the car to a "quickie change" place til I found out they hadn't been taking the spalsh guard off to change the oil. Pretty much destroyed the guard from all the splashed oil. I'll keep my fingers crossed and hope they do the repair and it'll take care of the problem. I really love the car, I had an 87' GL Wagon before this and put almost 200,000 on it. Thanks again.......
Well...I took the Outback to a mechanic that was recommended to me.. and he says its "the cylinder head gasket on the drivers side". I called the dealer where I purchsed the vehicle and they told it SHOULD be covered under a recall. I had some Subaru "stop-leak" additive added by the dealer about 1.5 to 2 years ago from a recall letter I received concerning the head gasket, so this should cover me...right? I thought the vehicle should be leaking coolant..not oil if the head gasket was the problem. Anyway, taking it to dealer Thursday for repair. They say it's a 3 day job. Will this car be safe to drive 2 hours/120 miles to the dealer. The car is leaking a small amount of oil and blowing back onto the exhaust at the "y" underneath the engine. Thanks for all the help.
