My daughters 93 Legacy sounds like a valve is stuck or ????? loud clicking that increases with RPMS. Any recommendations on a good Subaru repair shop, Eastside/Seattle. Thanks Doug:mad:
Tried the graphite, no change. She said the auto seat belts don't work also. Thinking it might be in the shift, tried N and Park, no luck. Loose, just won't release.
While driving it started to buck then died. Let it sit for 10 minutes, started up and ran at idle, tried to drive and it would die..... replaced filter, solved the problem.
My daughter called from college. She can't get the key to release from ignition switch. Tried all the usual but no luck, shift in to park-out-in, rotate steering wheel etc. won't let go. Any ideas? 93 legacy wagon
