mikeshoup's Achievements
Subaru Master (10/11)
20
Loyale 2.7 Turbo started following mikeshoup
EA81T, 3AT, ATF spews out the dipstick tube
mikeshoup replied to mikeshoup's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So I did a couple things: I drained the ATF and re-filled it, making sure not to overfill it. The previous owner had also plumbed the breather for the front diff into a vacuum hose for some reason... I fixed that. It's not doing it any more. -
That, and it has no other symptoms of a head gasket issue. Stays cool while driving, no oil/coolant mixture. I'm hoping it's something simple like a fluid change or some bizarro bad vacuum diaphragm. I just need it working enough to get it through emissions so I can get it plated. -
Thanks for the replies. I'll check the vent tubes (I didn't know the 3at had any) and make sure the cooler on the radiator isn't clogged. Then I'll change the fluid. I don't think it's head gaskets or the motor overheating. No other indications of a problem with the motor. At least I hope the motor is solid. ETA: could it be the vacuum modulator? Is the a check valve on it? Or is it possible the boost is making its way through the modulator and adding pressure to the transmission? Probably a very stupid question. -
FEELER: EA Turbo Silicone Intake Hoses
mikeshoup replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Fit an EA81T? I'll know more in a week or two, but I may potentially be interested. -
If it still looks that good, I'm very jealous. I miss my old EA81 Turbo wagon and have been trying to find another. They seem to be rarer than hen's teeth.
- 18 replies
- vacuum
- automatic transmission
(and 1 more)
Tagged with:
My mom's 99 Legacy's speedometer intermittently stops working. It has an automagic, about 115K miles. Did some searching, appears to a common problem with the speedometer head, couldn't find much more beyond that. Is there an easy way to test this to verify its the speedometer head? Any directions on pulling out the instrument cluster? Thanks a bunch.
Gear oil for loyale 4wd
mikeshoup replied to GorgeSuby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just get some plain old cheap 80W-90, or whatever the manual recommends. I've always used 80W-90 and never had problems. -
88 GL wagon..need idler pulley, worth buying?
mikeshoup replied to midnight302's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Idler pulley is nothing. If everything else works fine, then its not a big problem at all. -
If you're goal was to keep up with WRXes, you bought the wrong car. Should've got a WRX. You could put a newer engine and transmission in your car, that'll help, but its a lot of work and money. Easier solution, buy my 88 RX w/ EJ25 and AWD trans It'll keep up with stock WRXes in the mountains. (ask me how I know)
I did fix it. Turned out to be the flywheel bolts had worked them selves loose. Tightened 'em down with Loc-tite and got it straightened out... I think this car was parted by ShawnW though.
According to the 1984 FSM, the 2WD and 4WD distributors both have the same advance curve.
Find a FWD transmission out of early EJ soob (pre-97 I think). One from a Legacy or Impreza. Then, you can pull the rear diff and other junk in the back. Its not as hard as Gary is making it out to be, but I don't see the point.
Get the $100 one. I've owned a few 200K+ 5spds, and none of them really exhibited any problems.
Newbie Loyale 4wd vacuum question
mikeshoup replied to nbiehl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It doesn't. Its off of direct manifold vacuum. Speaking of which.... I need to replace my check valve....
