Everything posted by mikeshoup
What kinda condition is the radiator in? Is it plugged up at all? Have a severe case of fin rot? How's the coolant?
No start! Eating computers??
mikeshoup replied to Prospeeder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
87.5 XT Turbo, definitely. I dunno if the spider intake has anything special on it that prevents non-XT ECUs from working though. -
By spider, I mean it has the new fancy shmancy intake manifold on it. TB points toward the firewall, and has 4 runners that look like spider legs (sort of...). That's an 87.5. I'm not entirely sure what ECUs are compatible with it though. 85-86 definitely are not compatible. Seems to me early 87 (non-spider, tb points toward the sky, but has hotwire maf and optical disty) aren't either. Probably could use the non-XT 88+ Turbo ECU. To be completely sure though, you'd probably have to get an 87.5 XT Turbo ECU. (XT Turbos never made it in the US past 87.5) -
Your's is an 87.5. The 88 Manual doesn't cover Spider Turbos. They only cover the Spider N/A and the ER27. Try and find an 87 XT Manual... -
You guys are killing my thread Actually, I don't mind. I've hijacked a fair number of threads myself. I'm gonna have to pull a set of rear discs and see about shipping them to you guys down under.
colorado meet at red rocks awdpirates
mikeshoup replied to jeffast's topic in Meet n' Greet. Your USMB Welcome Center
I'm out. Got a barbeque going on over here for a couple birthdays and to help ring in the new semester at school -
Got my new tranny in the car...
mikeshoup replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Lucky dawg. I woulda pissed my pants had a tranny fallen like that... -
4-speed automatic slipping?
mikeshoup replied to Pooparu's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have you checked the fluid level? -
EA82 with quad headlights?
mikeshoup replied to Phizinza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
DLs, the base model, have the quad sealed beams. The single lenses are considered better because they're not sealed beams, and you don't have four bulbs to replace, only two. -
Way I look at it, $100 was a decent deal. I wanted another set of wheels so I could have all-seasons on them. A set of A/S and a set of Snows for winter. I figure, $10/rim (I got 5, one doesn't have a tire), and $12.50/tire that'll last me probably two years. Not bad.
I'll be honest, never thought of scowering junk yards for tires.
Actually, the biggest advantage was the tires. I've been running snows I got from DrKrazy for cheap, and I needed some all seasons. They're very nice all season tires with about half tread left. I can probably get a couple years left out of the tires. Colorado is definitely not part of the rust belt.
T-Cat's old camo wagon... update with pics
mikeshoup replied to RichLo65's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm with him, I don't see a car. I just see floating lights... -
I got a set of Wagon Wheels and tires without about half tread left on them for $100 yesterday. (actually, got 5 wagon wheels, 4 of them had tires mounted already) I like the look of them on the wag, though, they need to be cleaned up and repainted. What do you guys do to clean them up with tires still mounted to them? I'd love to have 'em sandblasted and powder coated... I'll probably do that when they need new tires.
Loyale Turbo Nightmare Story
Yup I did check for one. Found one at radiatorexpress, there's a few sellers on eBay carrying them, Checker had one, Napa had one. They're still fairly easy to come by. Trouble I had was finding a two-row. Radiator express was the only one to carry one. -
Are all EA-81's the same?
mikeshoup replied to soobcollektor's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Dunno if there are any, but to be safe, you could just swap the intake (mani, carb, everything) from the 82 onto the 86. Oh, and probably the disty. That would negate any chances of having electrical differences. -
Since they're both EA-81s, should drop right in, no problem. This is also an upgrade, since the 86 will have the hydro lifters, and possibly larger valves. -
Personally, I wouldn't touch lug adapters. They DO break. My friend used some on his old school bug... one of them ended breaking after a few months...
Actually, XT radiators are pretty easy to come by. Aftermarket XT6 radiators though were NEVER mader. The hard ones to come by for the XT are dual core. I've only seen one brand sell those. Most if not all major parts chains can get you a single core XT radiator. -
All the heads have the same combustion chamber, so no. What determines compression is the pistons. Turbo pistons have a bathtub cut into the top of them, making them 7.7:1 instead of the carb's 9.0:1
How did my car stop using oil?
mikeshoup replied to bgd73's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Oil doesn't look like its getting milkshaky does it? That's pretty odd that overheating stopped oil consumption... -
You *could* change the heads, but then that leaves with the lower compression turbo pistons too... That sucks man.
Only made a single point carb'd intake. Why do you want to go carb btw?
I've got 10 days to intercool dorothy now. If I get 'er intercooled by then, she'll be down. -
Finally washed my new car
mikeshoup replied to kennyvb's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No you don't. The orange digi dashes suck to see in the daylight. I can't wear sunglasses while driving my XT cuz of it.
