Everything posted by mikeshoup
If manual, yes. If auto, I don't think so (?). However, the author of this thread doesn't mention switching trannies. The difference is in the tranny.
Can I please get the original locations of these FSMs and who scanned them so I can give proper credit where it is due? Thanks In an effort to conserve server bandwidth usage, everything's been zipped up. I've uploaded the partial 89 FSM here: http://mshoup.us/docs/fsm/EA82/ You'll also find the full 88 XT FSM there (Thanks to Mr. Radon from xt6.net) The EA81 manuals have also been zipped up. Why zip 'em up you ask? A) Uses slightly less space on the server. This is fairly negligible though since PDFs are already compressed Forces people to save them to their computer instead of opening directly every time they need to use it. Please save these to your computer for future use!
can I hook up the torbo
mikeshoup replied to Mike Moore's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I beleive he's saying the turbo engine has a crack in it somewhere. Doesn't sound like he wants to use the turbo block. -
They'll get there. For some reason the VPS is being slow. I haven't determined if its due to the previously linked FSMs.
87 GL Wagon Stereo Wiring Diagram?
mikeshoup replied to BlindSight's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would suspect that your radio not turning off and the clock not turning off are part of the same problem. Perhaps a circuit got rewired to stay on constantly? -
Are these the partial FSMs that are already hosted else where? If they're elsewhere, I see no reason to use my server's bandwidth...
Loyale turbo Timing question
mikeshoup replied to Pooparu's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Cam timing has nothing to do with TDC. Its timed to when the valves have the least pressure on them (makes it easier to turn the pulley). If cylinder 1&2 are at TDC, then you should be at the 0 mark on the flexplate. -
You need the EA82 Turbo manifold with the MPFI, which in turn requires the MPFI heads and a computer to control the MPFI. I guess, you could some way run a turbo on it with the carb, but why? -
Got a VOM or a Test Light? Hook it up to the wire you have for 12V Switched, make sure it goes on and off with the key. -
Seeing as RXs are fairly rare, 1500 is definitely a reasonable price. If it had no rust, I'd even say 2000. That's for an 87-89. The 85 and 86 RXs are sedans, and although rare, don't have as many cool things about them, included the FT4WD D/R. (They have a PT4WD D/R though)
Got the switched and constant 12V backwards? I think that'd keep it on all the time. -
hey looking at a 1980 GL wagon...
mikeshoup replied to kodiak1232003's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Not all GLs are 4WD. Only the Turbo versions had an AWD option. The rest were either FWD, or Part Time 4WD. Some of the 4WD models had dual range (hi, lo, transfer case built into tranny). Being its 80, it will not have AWD at all. If its 4WD, I beleive it would have the 4 speed dual range 4WD tranny in it. -
RXs are nice cars. The 87-89 come with a FT4WD Tranny w/ manual center diff lock and dual range. They have an EA82T (EA82 Turbo) engine, which cranks some where around 115 hp out. Definitely a very nice car, and would be great rally crosser.
Saab wheels and sube == saabube?
mikeshoup replied to bgd73's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm afraid the saab 4 lug bolt pattern is 4x114.3 and NOT 4x140. Dunno where you see that they're 4x5.5. -
'81 Wagon Vandalized...possibly for sale
mikeshoup replied to Diamond's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I might be interested in taking it off of your hands for cheap. I know a few people who could use a good vehicle. DrKrazy: Any chance on helping me get a good deal for a windshield for my wag? I've been pulled over again since I got it for how bad the windshield is. Elite quoted me $155 to do it at my house. -
Ask, and ye shall receive: http://mshoup.us/docs/fsm/EA81/ Its not on the quickest of hosts. I use tektonic.net's VPS, and I have a plan which limits to 1.0mbit/s
L = Blue B = Black Y = Yellow G = Green R = Red W = White Br = Brown Lg = Light Green Gr = Gray C'mon, not that hard to figure out -
http://mshoup.us/images/radio.jpeg There's the diagram. Just follow the lines (shouldn't be too difficult to figure out what goes to what). cd45: You did a nice job of outlining what the aftermarket connector's colors are. Unfortunately, they're not the same colors as the stock subaru connectors. -
Who can Identify this noise?
Definitely check the tensioners and the idler sprocket. -
Starter from 87 GL into 93 Loyale?
mikeshoup replied to ronnie johhhnnn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've seen 4EATs in later model non-turbo Loyales. I'm not sure exactly which models came with them, but when shopping for a wagon, I've seen 'em. -
Finally washed my new car
mikeshoup replied to kennyvb's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Beautiful. Wish my cars were that clean. -
I can scan in the wiring diagram for the radio later today. The colors may not match up as its for an 86, but the pin positions on the connectors will be the same. Just remember, Subarus use a common ground for the speakers. You will need to seperate the grounds from rear to front. Easily done by running new speaker wire to either the front (easiest), or the rear speakers. If you run it to the front, there's pink plugs behind the kick panels on either side. Just cut and splice in there. -
My wagon seems to be about the same. Its an 88 SPFI, just like your 92. Seems the hot weather really seems to drag on it. I'm of course at a higher elevation. Borrow a timing light and check the ignition timing. I found I can run the wagon up to 30 degrees without any ill-effects and still use regular gas.
