Everything posted by mikeshoup
Quick answer - EA81 (carbed, this time)
mikeshoup replied to Ever Victorious's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You'd be okay driving it, but, if at any point in time, you feel uncomfortable to drive it further, stop and don't risk it. I'd rather pay for a tow bill than to pay for a new engine. -
If you didn't touch the distributor, you'll be fine. Its driven off of the driver's side cam, so if the cam is in time and the distributor was before hand, you're fine.
Serious leak help fast
mikeshoup replied to DiGiT_xero's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Depending on the crack, a machine shop might be able to fix it. Your best bet might be going to a junk yard, pulling a set of heads and having them checked out by a machine shop. -
What a night..Project Cheap *Almost* gets stolen
mikeshoup replied to DrKrazy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's crazy. I've had cars broken into when they were in Englewood, but have never had one lick of trouble since I moved to Golden. Maybe I'll wire up a hidden killswitch on my XT. -
You will need the wiring harness (or at least a part of it). Remember, the XT6 has two extra injectors. You will also need the ECU from an XT6. This would require a lot of fab work and probably relocation of the radiator. If you've ever looked at an XT6, then at an XT, you'll see the XT6's radiator is moved forward quite far to accomidate the larger engine. Good luck.
Anyone rig their lights to a toggle switch?
mikeshoup replied to SakoTGrimes's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Why not put the lights on a relay and have them powered off of the battery with their own fuse? -
Any thoughts on seat swaps?
mikeshoup replied to eponodyne's topic in Old Gen.: 80's GL/DL/XT/Loyales...
May want to look for XT seats... those would probably be easier to swap in, and they fit me great. (I'm 250lbs and 6') Everyone says that they feel better than the rest (I wouldn't know, never really sat for long in any other). -
Pictures and where you found them would be most helpful.
Love my XT Turbo. Keep it stock, and it will be very reliable. One thing to watch out for, is make sure the air suspension (if equipped) is in 100% working condition. It is expensive to fix, and usually cheaper to just convert to conventional stuff. Also, the digital dash (if equipped) is a pita to read during the day with sunglasses on. Otherwise its pretty neat.
How many of you have low mileage EA82T.
mikeshoup replied to Gl-boost's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I thought these cars came off the boats with at least 100K on them... -
Running on 3 Cylinders at idle
mikeshoup replied to mikeshoup's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm almost positive its a head gasket now. Pulled the dipstick and it was covered in milkshake, and I had to fill the radiator up about 3/4 a gallon before it was at top.... So, uh, do any of the colorado guys wanna show me how to do headgasket? -
So, today after driving around, I parked my car, and noticed it was idling very roughly and had what looked like steam coming out my tailpipe. After a little investigation, turned out cylinder #3 wasn't firing or something. I haven't tested to see if the spark plug is sparking, but there's a spark when I pull the cable off the distributor cap. The engine doesn't seem to run rough once I bring it above about 1000rpm. At least, it feels like all 4 cylinders are firing. Is this a bad HG? I noticed the coolant level was definitely low.
1992 loyale 4x4- HELP!?
mikeshoup replied to BANNYjibber's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's the same deal with the 4wd D/R trannys here. Its only the S/R 4WD trannys that are push button. -
Just purchased 1988 GL 10 with 56k original miles
mikeshoup replied to 88URABUS's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I always try to change the fluids when I first get a car. Oil, Coolant, ATF and Gear Oil mainly. I'd change those fluids right away, especially if you don't know when the last time they were changed. -
I thought the 4th gear was overdrive on the 4-speed? Yup, according to Miles Fox, the 4spd D/R's 4th gear is overdrive: http://www.economysuperstar.com/milesfox/subaru/service/ratio.htm
Please refrain from using custom fonts... its annoying. That's what he means by screaming.
Loyale/GL cupholders, Lets See Em'
mikeshoup replied to NewDriverOlderRide's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My car has one that somebody just screwed right to the center console, and hangs off the passenger side. It works. -
Figure out what your current gas milage is.
