Everything posted by torxxx
pretty sure they will measure the axles and count the splines in the end of the axle. I assume you are going to do a cv axle swap correcT? I imagine 92-96 legacy are all the same size. If you really wanted to know, call a parts store and ask them. I do that to Napa all the time. Just make it sound like your interested in buying from them.
shean I went and bought some pvc end caps (3/4") and then wrapped a lil bit of black tape around the hoses and then threaded the caps on to the end of the hoses for the AIS system (the "exhaust recirc" deal you were talkin about) I bought some caps tonite. Theres some parts on the carb that have hoses but I wasnt sure what the were so I didnt cap them off. can u take a picture of the top of your carb and the front and back views of it for me? Then I can circle the hoses that I didnt take off and see if you did (compare the two carbs)
pull that damn charcoal evap canister off you dont need it
I've been really bad on saying thank you to all the people who've helped me on the board. So: Thank you for all your help!
it all depends.. how does the clutch feel? I've burned the hell out of my clutch on my EA82 and I like the way it feels slightly burned. No one can judge how much life you took off it because they havent driven it before and after. Thats where you come into the picture. Does it still engage at the same spot as you let the pedal out? And does it slip when you are engaging it?
I'm going to plug off all the IM stuff on my car so I'm wondering what size plugs/caps I need to get to cover all the sizes of vacumn lines.. Anyone know whats sizes they are on soobs?
to all you mmo users?????????????
torxxx replied to beachbum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1 qt in your oil? You must have some thin rump roast oil then 8 oz on with 15w 40 makes it almost too thin -
the bottle says 4 oz /tank I put 8 oz/tank because I'm up here in Alaska and the fuel we get is kinda dirty -
Dont think BYB released the EJ lifts yet Should be soon
Running with 18+volts. AAHHH!!!!
torxxx replied to MaroonDuneDoom's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you are charging at 18 Volts. Your VR is blown a 12 volt car is a 12 volt car not 18 volt -
measure how big around they are?
EA81 U-Joint confusion
torxxx replied to GeneralDisorder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
EA81 drivelines are serviceable You have to cut the + out from the middle of the joint and then pound the caps out If they have zerks in there, they have been replaced before Stock ea81 ujoints dont have zerks in them As for your ujoints they have been "converted" typically the ujoint is staked into the spindle in 3 or 4 spots (like someone ran a punch down the side) -
yes you can overcharge your battery and it messes with other things in your car because its charging so high -
Pics of new dash gauges 86 ea82t
torxxx replied to Subi81's topic in Old Gen.: 80's GL/DL/XT/Loyales...
is that plate that you used premade? or did you have to fab it yourself? I want some extra gauges in my car, and i could never find a good spot. That center console spot is a great idea -
Push Button 4wd switch question
torxxx replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Skip, I forgot to mention that I have a DR 5 speed. I'd love the wiring diagram. -
you need a 3/16th punch not a 3/8th
I run it in my oil every oil change, every 3 tanks of gas I add it to the fuel And Once a month I pour some in through the carb -
First off, I've never looked at a single range push button 4wd closely. Is the push button switch electric, and if so what kind of stuff "could" I use that switch on the stick? Say fog lights?
Rotary RX? What kind of engine?
I started a thread a few days back. The title was EA82 Engine Swap Search for it. Theres a lot of good info in it
