torxxx
Everything posted by torxxx
  1. thanks guys for the advice.. I think I'ma run 1 7/8' to the carrier bearing and then the glasspack startign right there and then just leave it with the glass pack right before the diff
  2. From what I've learned here, every speaks pretty highly of the ea81 and lack of timing belt.. Why did subaru change it to a less stable timing system? sucks you gotta change t-belts now every 40-60 thousand miles.
  3. Gonna have to hijack this.... For you guys that replaced the exhaust, did it require a lot of bending for the new ones? I was thinking about cutting off everything from the Cat back and putting 1 7/8" to a glasspack and then 2 or 2 1/4" from the glasspack to the back where the stock muffler was.. How complicated of a project is this?
  4. From my expirences up here: I like my 86 GL.. Its a great daily driver (driven hard too) A friend has a 92 Loyale and I had a 87 or an 85 with a AT and they were pretty ****ty cars. As for the carb, mine was fine for 18 years, and after I started messin with it, things started happening to it. The dual range is awesome compared to the push button 4wd. Lo gear really helps I've also been told my a parts store manager, and a few mechanics that in July 1985 (which would make it an 86) they changed the timing belts somehow and the years after 07/85 had more problems with belts breaking than the earlier ea82s the 86 GL is also nice if you like a car with no power steering/AC engine driven fan. I have tons of room to work on stuff.. no need to pull radiator to work on front of engine The 92 loyale has had tons of problems....
  5. I shift my EA82 (non turbo) at 5500 most of the time I've ran it to 6500 rpms in 2nd and 3rd.. still good power, but it starts droppin at about 5800 rpms
  6. I dont think its time to worry about all the oil seals just yet. if anything the front and back crankshaft seals and tranny seals should be all that car needs if it needs any of it done
  7. they are bad because they mass produce the filters as cheap as they can. Filter tests have been done (filters cut open) heres the link: http://www.scuderiaciriani.com/rx7/oil_filter_study/ Fram filters basically use toilet paper as the filtration system Where as WIX, Ac delco and puralator would use carboard Hope this answers the question
  8. there's a dipstick on the tranny fowards the firewall... May have to really look around to find it on the new soobs. You could change the gear oil, but look at it and see how the oil condition is. I usually change my tranny oil once a year. to do that, its about straight down from the stickshift on the bottom of the tranny theres a 21 or 22 mm drain plug. Drain and put plug back in, then fill through the tranny dipstick.. Slowly squirt the gear oil in, if you put too much in, it will burp out gear oil all over everything Oil seals go on the front of the crankshaft, back of the tranny, sides of the tranny where the axles stubs stick out, in the rear end, and on the oil pump
  9. no hte codes come out at the ECU under the steering column there should be a little red light that will flash a code
  10. dont waste the time on a 2wd disty I was looking at that before and people has said it was a myth for the ea82s the power curve deal was for ea81
  11. I gapped mine at .5 and then richen'd my mixture just a tad
  12. I drove a set of axles tile they snapped on the front all boots were torn, filled them back up wth grease and made ducktape boots they clicked and ticked and popped.. and I ended gettin 6 more months out of then before the shafts actually snapped if it does, just tie it up.. not tight on the shaft.. let it hang so the shaft can still spin I then drove for 3 weeks with busted front cv joints in 4 high made drivin a lil more fun
  13. nice job. I need to do that same cutting for my car here sometime. time taken to cut all 4 fenders?
  14. I noticed top end gain in acceleration with the accel in my 86 just my 2 cents
  15. 3 AT? why didnt you put a DR 5 speed in after the first auto went out? Automatics SUCK
  16. do you get higher compression in a EA-82 if you use EA-81 pistons?
  17. hahahahahaha. I'm found a 150 dollar 86 GL just like mine except its the rust colored paint...... so I'm either gonna attempt to ghetto-Fi it enought to make it look like a Fast and the Furious car with 3 foot tall spoilers, or make a Brat out of it.. (cut the cab off right behind the back seat and modify lexan glass somewhere aroudn there to close off the cab..
  18. carb is 80 hp I believe, 1.8L flat four cylinder not sure about the tq.. 102 ft/lbs sticks in my head
  19. Anyone ever mess around with running the AIS without the silencer? or maybe unpacking the silencer?
  20. sorry bout that man, I was in a rush tryin to get the parts store before it closed.. I mean Wasteland Subaru no Battle.. heh.....
  21. Yer mailbox is full so I couldnt pm you... Kelly - Hey just wondering if I needed to pull the intake manifold to take the IM stuff off my hitachi? Wasteland Subaru told me to hit you up and that you'd prolly know.. I got a rundown list from Wasteland Subarubut it seems like some of the stuff he said didnt need to be done.. Do you have a write up of how to do it? Thanks, Brad
  22. Wasteland Subaru - heh, I think it was your write up.. I dont remember who gave it to me, but they said they did the removal on a EA-81 and a 82....
