mtbe
Everything posted by mtbe
Too much oil?
mtbe replied to mtbe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Okay: I do not give it enough time to settle. I will give it some time on my next test, but it will have to wait until I return from China. When I say 2x, the level was up to the point on the stick where it curves (or bent?), not including the curve...just up to the point where the curve begins. -
Too much oil?
Okay: First, thank you all for your replies. I took it to the dealer for its 120K checkup. I drove it for about 3000 miles. I decided to check because I did smell oil, that may have been coming from my car, or it may have been someone elses. When I checked it with the engine warm, it indicated about 2x the full level. I checked it in several places and all were the same with the engine warm. I took it to the dealer with a nasty gram. They called later in the day and said that the level was not over FULL and in fact was below FULL. WTF???? So, after work I went in and he showed me the stick. It in deed was below the full mark. It was showing slightly above the 3/4 mark. WTF was going on here??? He said I had to be careful how I read the stick because some of the oil can 'cling' to the side of the stick. YES, I know how to read a stick! So, I pushed it off on Murphy's Law, not wanting to suggest they changed/drained the oil. I get home and check it again. It was 2x the level again!!! I'm an idiot! While at the dealer, the engine was cold. So, do we check it while warm or cold? -
Too much oil?
Checked it 3 times now in 3 different places. I'm taking it in tomorrow. -
'99 Forester, 124K miles, Manual. About 3 months ago, I took it in for the 120K service. It came out and the tires were still low. I walked back in to explain and they agreed. When the maintenance supervisor drove it back out and handed me the keys, he joked, "It makes you wonder what else they missed". So, over the next several thousand miles I smell oil off and on. Not very frequently so I speculated it was coming from autos in front of me. At about 123.5K miles, I smell it closer to home. So, once there, I check the oil. It was about 2 times over the Full limit!!! This was 2 days ago. I will be taking it back to them tonight or first thing in the morning to at least show them and get an oil change, but what else will this do to the engine? Should I have them take it apart and inspect the valves or anything???? I'm no mechanic, so any help is appreciated.
Being non mechanical: Yes, I'm the one that had the VCU failure. The car has an unalignment problem now. It has been that way for maybe 1000-1500 miles. I thought maybe that could have caused the viscous coupling to fail and wanted to kick myself if that was the case. Plus, I probably had the alignment done, at the dealer, 5000 miles ago. And now, it is worse than what it was before. I did take it to a respected tire dealer and asked him about the wear (I wanted to change the tires) and he said that they were fine and I probably could get another 10,000 miles out of these. I do rotate them at 7500 miles, sometimes less.
Two Questions: Is there any mechanical damage to an un-aligned car? I know there will be damage to the tires and difficult steering/handling, but can this lead to mechanical damage in the differentials, or something else, also? Once aligned, how long should it last? Is it pretty much once you drive off the mechanic's lot after alignment, it's in your own hands. 100... 1000... 2500 miles down the road and you're paying for a new alignment?
Took the manual 99 Forester with 114K miles on it to the dealer due to an 'umph...umph....umph' sound coming from the front right wheel (or so it sounded like that area from inside the car) when turning slowly and sharply, like into a parking spot. I brought this up before and many thought it was the torque binding, broken axle or CV joint. At first, they could not duplicate it. The car had sat in their shop all night. I ran into the same issue: if it sat for a while, I would not hear the sound. But after driving a while, it would happen. So I asked them to drive a while and sure enough they could hear it also. The said it was the center differential. Does that make sense? They also said when sitting on an incline with clutch in (not many inclines in Columbus Ohio), that the car would not roll backwards and this is another indication it is the center differential (maybe I should keep it this way for the hill brake? ). Also, if it could be the differential, does $1000 sound like a decent price? Thanks in advance for your help.....
Clock issues?
mtbe replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Check out the picture here!!!!!! http://www.scoobymods.com/forums/showthread.php?t=5028 -
When making tight turns, like parking, I only hear and feel the 'skipping' in the front passenger side. My wife got out to see and, while she didn't say she saw anything, the noise was definately coming from the front. Other board members here associated that with the torque binding issue others are having.
My 99 forester clock went out too. It's a very simple fix with a soldering iron. No need to go out an buy anything. I'm assuming your's is the same. If you remove the clock (use a small screwdriver - there are two tabs that you need to undo), then unplug it. Remove the clock from the plastic front (I actually broke one of the tabs doing this so be careful). On the back of the electronics, you will see several small rectangular pieces with numbers on them. Look for the one that has 510. Part of it is partially under the display and seems difficult to reach. This is a resister and it has lost it's connection to the board. Just resolder to the board it it'll take care of it! Check out the picture here!!!!!! http://www.scoobymods.com/forums/showthread.php?t=5028
Sorry for bringing this up again. I've searched the sight and found many issues and fixes for torque binding on auto transmissions, but not manual. I did find one person here that had problems but it was with his rear axle. My problem is the front passenger side wheel. I just dropped it off at the Subaru dealer, but after reading some of these posts, feel I may be getting the shaft there and it may be as simple as flushing the transmission fluid???? Any thing I can try before putting $$$ into it? I don't mind putting around $1000 into it, but any thing more than that I may just be selling the thing. Too bad too because it's been a great car up till now. I need some ideas....
