subjfd
Everything posted by subjfd
	Alternator change time ? For the last year, noticed that my light were dimming slightly while idling. Then lately, all my electrical such as wipers would slow down as I would slow down as well. Today, my radio turned off as my rpm went down, and back on as my rpm went up while idle or running. Turned my car off, and it would not start again. My battery is exactly 1 year old (a 5 year warranty one). AM I correct in assuming time for a new alternator ? BTW, 93 Legacy 4WD wagon, 5 speed, no air. Thanks JF
	Hi, I have a 93 Legacy wagon 2.2 4wd non turbo 5 speed When driving at low speeds, I hear squeaking from front driver's side that goes away when driving faster, and sometimes when I go over bumps, I hear a metal klunking sound. I just bought new brakes I am installing on Friday, so IO want to check other things. I was thinking wheel bearing, what do you think ? Thanks JF
	I know...dumb question.... But I cant find it, and my milleage is baaaad, and I have a code 21...So I got a new one from the dealer. 2 questions: 1) Where is it lovated (idiot proof) 2) Is it necessary to remove coolant, or a quick swap will do it. In my vw, it says to remove the coolant, but I can manage with a quick swap ! And I know....Not to forget to apply teflon to thread ! Cheers JFD 93 Legacy L wagon 4WD, 5 speed
	Between my GF and I we will kill this car... It was cold and I tried to release the frozen cable that releases the fuel door...Anyhow, it fell beneath its housing, and I am trying to figure out how to get it back. I know it runs underneath the rear seat, but after, I am stumped.... Help please ? Thanks ! JFD 1993 Legacy Wagon L
	I need help figuring out, my cigarette lighter (which I use to power my iPod since I do not smoke) died today ( I will explain how underneath should you care). I checked the fuse in the fuse box (15A, third from the top), and it was ok. Changed it anyhow, and it still does not work. It worked flawlessely before my gf left the pool with her hair wet, decided it was too cold (- 18), and had the brilliant idea of plugging her blowdryer to the converter I have in the trunk for emergencies. She said it simply stopped working. Now the lighter wont power up anything. Help appreciated. 93 Legacy L Wagon 4wd 5 speed Thanks
	Well, lucky for me, the rear panels have no holes, just surface rust. So I can work on the car directly. The front ones bothe have a whole of about 2X2.... I also removed that rubber moulding in the fenders...humidity trap that they were....oddly enough that's twhere all the rust started. Dumb dumb dumd...
	Hi, First, My car; 1993 Subaru Legacy L Wagon 5 speed I am taking care of some rust. Instead of working on my car directly, I am removing the following: 1) Front side panels (Easy, 4 bolts) 2) Driver's side mirror (electric), and I need help to figure out how to remove it please) 3) Rear side panels (Could anyone help me out here as well please , I want to take them off ) My plan is the following: Take them inside, sand thoroughly, and where I have holes, cut around the rust, apply a kevlar coating with felt(such as the kind you put on a whitewater canoe for repairs) from the inside, which will bond the 2 sides of the hole, wait until it dries, and then add putty from the outside in order to even out the surface, then sand and prime, sand again, and paint. I think it should do an awesome job, but I need to take off the rear panels and side mirror first. As well, I have rust on top of my windshield, and when it rains, it also rains from the headliner where it meets the glass. I was going to sand to metal, add putty to even it out, prime and paint, then add a strip of kevlar felt from the windshield plastic trim to the metal, then sans prime and paint as well. This week I would take it to a shop and have urethane shot from the inside to seal well. It should take care of the leak. Any comments or suggestions ? Thanks, Cheers JFD
	Unlikely, As I put in brand new 75W90 synthetic when I changed my clutch 2 weeks ago, and I keep checking the levels. All OK ! It always happens in 4th-5th, between 2000-3000 rpm under load. My guesses are: 1) 4th-5th gear pinions 2) Clutch bearing 3) Simply normal noises In any case, I will keep on driving and see what happens I guess, unless someone convinces me otherwise ?
	Hi all, I have noticed that on my car, the electrical intensity varies depending on whether or not I am driving. For example, at idle, my headlights, and interior lights will be a little dimmer than once I am driving. Nothing too bad, but still able to notice. I have a 2.2 Legacy 1993 Non Turbo, stick shift. BTW, I do have a brand spanking new battery, and am able to start at - 25 degree weather no problem. Thanks in advance ! Cheers JF
	My car: 1993 Legacy 2.2 stick shift, non Turbo. When I drive in 4th or 5th gear, I hear high pitched whining noise coming from what seems, either the engine or the tranny, only when I press on the gas pedal. I am a new Sub owner, so it might be a normal noise for an AWD, but I am quite unsure. It might (or not) be related to the fact that my speedo is not working, but I thought I might ask if this noise is normal. It vaguely ressembles the sound of an jet engine warming up. Cheers JF
