30
Everything posted by MilesFox
EA82 Rear Disc Swap Castle Nut Torque?
MilesFox replied to drugh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
make sure the washer is not on backwards -
Tow bar. I have one Tim hansen pointed this car my way. I was assuming maybe a work ignition switch, no starter action. It's possible to make this car run by pokng it with a stick. that ej22 you sold me would retrofit. Now i dont need it, since desmond agreed to sell me his parts only after i bring home a whole car and an engine.
you might be able to buy loaded ea82 rear calipers, but you still need a backing plate to mount them. i have read that you can fit an ej backing plate by making an extra hole or 2, and one or 2 of the holes line up, and do that. But you will need xt6 5 lug hubs.I am contemplating legacy rear brakes on my 86 3door w/xt6 hub
I got the framerail on the one side of the 3door 95% finished and then i ran out of wire. I forgot to take a picture. I think i have radiation sickness form the uv and xrays. I cut my helmet down to handheld and replaced the lens. And with spare tims, my welds are much better now. I made my tools portable, and now i can brek down the control arms in my backyard and degrease them, por15 them in the rusty parts, and paint hte rest chassis black, available in the can at napa. I am using a zink weld-thru prime as illustrated in a particular u-tube series on bodywork. I am together enogh i can mount the radius rod plate to the body. I am debating to do all the seam welds, and instead of welding on the edges, i am thinking f spot welding between the spots, for more penetration and a cleaner look. I am going to seam weld the radius rod plate body tampings, trans mount stamping, pitch bar mount, and around the strut towers. I may go down the whole trans tunnel. I will have to treat surface rust along the trans tunnel, and mount the xt6 shifter before installing the trans. I may go with mounting the trans, mount, and pitch bar to the body before installing the engine crossmember __________________
help with ticking lifters
MilesFox replied to mikewilke77's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You can service the oil pump simply by replacing its seals. The dealer would naturally sell you a new unit, for the sake of it being apart, but the oil pumps do not fail by themselves. Also , the gauge on the dash is notoriously inaccurate al tlow rpms, but the owners manual will state that it is normal to read towards 0 psi at idle when warm. The next thing is the cam tower o rings. Replace these when servicing the lifters. If they leak, this drops pressure to the lash adjusters. Whay commonly happens id the o ting and the oil pump seals will suck in like a pac man shape, and aerate the oil causing the lifter tick. This, and compounded by excessive carbon, sludge, maintenance history. Sometimes the marvel oil and sseafoam may clear it, a different weight of oil, doing some spirited driving may make it go away. Sometimes it can come and go, or go away when warm. I would recommend replacing the oil pump seals. If it perssts, do the o_rings. These engines are relatively simple to work on. I would recommend pulling the engine to take the cam towers off as assembly will be infinitely easier -
PArts do rust, and eventually disintegrate, in the rust belt at least. It would be worht your effort to pull the brake hardware off and clean up the rust, re-paint, ad then anti-seize all the bolts and silicone grease the caliper slides and rubber boots. Even if your brakes are not due for replacement yet, you will thank yourself that the parts come off easily. Otherwise, with a new car, going all the way till the pads are gone, can be long enough for bolts to seize and caliper slides to get stuck. Its a good rule to take something apart and put it back together, just so you can take it apart when its time for replacement
what to look for is if the engine is a 1.8 or 2.2 Usually the 2.2 is in the 'outback sport' package from 96 on. Also, anything older than 96 may be FWD. Although not horrible for someone desiring a 30mpg subaru. Other than that, its still a subaru, and mechanically identical to the legacy as far as the underpinnings
go for the gates brand. I used a used set of pull-off ITM rollers to replace some shagged oem ones. go for the cheap set for now, install them, leave all the covers off, and by 3oo miles, go buy a set of Gates or Goodyear Gatorback, or even Continental timing belts and change them out in 20 minutes.
Flat tow w/tow bar '84 Hatch
MilesFox replied to ihscout54's topic in Old Gen.: 80's GL/DL/XT/Loyales...
U-haul will not approve a hook-up to a vehivle that is not qualified. A dolly will be rented to mid size sedans and mini vans, most v6 size cars, with curb weights around 3500 lb, and a 3500 lb class 2 hitch, 1-1/4 or 2 inch receiver. The general rule is, the vehicle in tow should noy exceed the weight of the tow vehicle. The nice thing about a dolly or towbar is there is no tongue weight on the tow vehicle. What model of tow bar do you have? I use one to tow my subarus. I have the valley unit like the ones sold at u- haul. Coincidentally, the pins that go into the supplied shackles, just happen to fit the tow loops on ea81, ea82, 1st and 2nd gen legacy, using big thick spacers leftover from hitch install kits(ask the hitch pro for a handful) and the supplied pins and cotter pin. I never used the shackles, and i have towed so many subarus, universally fitting, across anywhere from a few blocks to 300 miles but if your tow loops are ruined, i would sat remove the bumper and try to fashion a piece of hot steel angle iron that bolts in place of the bumper, and mount your tow shackles to it. -
That is odd. Maybe the pic is just showing the different size of seals, although there should be 2 cam seals. The crank has no o-rings. you should have an o-ring for the cam seals, one for each side, about 2 inches in dia. for the oil pump, you shouldhave a large o-ring that goes over the housing that sticks into the block, the mickey mouse seal for the face of the block, and a shaft seal behind the pulley on the oil pump.
I would beg to differ that if the shifter would not go into gear, the car will not be in gear for the 4wd. And i also would say that if the front diff was shot, the 4wd still wont go, since it drives the PTO to the rear. I do like shawn's idea of the 2/4 wheel engagement being stuck n the middle, but i still maintain that a stripped hub is the likely acute culprit.
Based on my experience, a subaru is the only car that can break down, and still drive home:banana:
connect the yellow wire from the car's original coil to the tach wire on the ej22
goes in 4wd is a dead giveaway. I broke an axle in arkansas, removed it, put in 4wd, ad drove another 600 miles. I managed to get another car home 15 mile on a stripped hub(fwd). I had the rear diff fall out of my sedan, and drove it another 250 miles before fixing it(now i am bragging) You can literally drive a subaru with the axles dangling off the ground. My answer is based on what is MOST LIKELY to happen and is usually the culprit when this situaion arises. So if it is a stripped hub, it is caused by improper torque or installation of the axle nuts(washer on backwards) and based on all of this, what may or will happen as a result of this is a compromised wheel bearing. i suppose i could direct to an article on how to do the axles and wheel bearings, what tools to use, etc Have fun and enjoy the subaru!
What happened? *Coolant Blowout*
MilesFox replied to RedRat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
drain plug -
SE WI, Milwaukee Regional/Subaru Alliance
MilesFox replied to MilesFox's topic in Meet n' Greet. Your USMB Welcome Center
deebo goes beyond Tiny Lister -
explain how it goes in 4wd. what the OP is implying is that the car will not go, when in gear, in 2wd, but does in 4wd. This one is so obvious
broken axle or stripped hub. if the diff failed, you would have had problems over some time beforehand Set the parking brake, put the car in gear, ipen the hood, and see if the axle is turning. then look and see if the axle nut is turning. if the nit is turnoing, you have a stripped hub. If only the axle, or one of the axle cups is turning, then replace the axle
Yeah, this is a good idea. What i am saying is the felpro will have oem HG/s and cork oil pan gaskets are really arbitrary compared to durability of head gaskets. I used to have a list of napa/victor reinz sets for ea82's, high quality, but napa no longer carries victor and the part numbers no longer apply. if anyone were to look up napaonline.com for their subarus, it will give a whole list of diferent part numbers an manufacturers, price for the same part such as a wheel bearing or a gasket or sensor. there is really an art to shopping for auto parts around suppliers, retailers, manufacturers, and mark-ups.
buying second subie to modify....
MilesFox replied to bjonga's topic in Meet n' Greet. Your USMB Welcome Center
Your best bet with modifying a legacy is to retrofit goodies from other subaru models and build from that. you can do outback struts and wheels for lift. you can swap a 2.5 in place of a 2.2, or get a header and a delta cam. Make your build based on your preferred driving environment, off road, street, track -
Clutch replacement on '85 GL
MilesFox replied to Arghetlam's topic in Old Gen.: 80's GL/DL/XT/Loyales...
pull the radiator. umbolt engine and pitch bar. jack uo the trans to make the engine clear the motor ounts. have buddy pick u one side of the motor and move it forward away from the trans. tie a chan and a 2x4 and 2 piople can pul it out. 2 people can carry a soob motor, one person can squat to lift it into a 5gallon bucket to set it on. you can drop the trans if you prefer, but i think cleverer ways to yank the motor is still easier than dropping the trans -
Be aware that the hatchback is an ea81, and for 1987, the ea81 hatch and brat(80-89) were in production alongside ea82 wagon, coupe, and sedan(85-94. your key words will be 1800 SOHC or OHC, and NOT OHV 85-94 in years listings try an order for a 1990 loyale to eliminate ea81 cross references
Pulling the engine is easy if you want to do other service like timing belt or engine selas. A motor can come out within one hour. if you are good, you can partially pull the motor and move it forward, leaving a lot of things still connected like throttle and heater core if you are just trying to slip in a new disc. if you drop the trans, you may have to pop the ball joints to get the wiggle room to move the axlesm and contend with the shifter, driveshaft, and exhaust. standing over the car with a crane is much easier than on your back in a puddle of gear oil
