MilesFox
    30
Everything posted by MilesFox
  1. I got a generic Bosch unit for 2 bucks(tech's price) the other variant that was more expensive had the molded plug specific to a subaru. the generic unit was just a bare wire at the end. No other difference between them. This is often an arguing point or suggestion for advice. please continue this discussion here! OEM gaskets vs Felpro, and others http://www.ultimatesubaru.org/forum/showthread.php?t=108259
  2. look for chunks. could have lost a piece and jammed up the whole works
  3. I had a ford pinto. i changed the head because the old one was ate up from bad oil pressure. I torqued down the first bolt before threading in the rest. i found out why you dont do it like this when the last hole did not line up. i broke a TTY bolt on a ford 1.9 escort. It had a cracked head so i got a replacement head. I had the HO motor with domed pistond and the new head ras a regualr and did not fit. I used a worn down metal blade on a circular saw to ream out the combustion chambers to fit the domed piston. Then i broke the TTY bolt when it called for a 90 deg turn. i did not know to use new bolts! i was already used to subarus then:lol: I drove around for a while in one car for a good bit before i noticed i forgot to install a motor mount on the motor i used I had a vibration in my wagon once. thought it was the driveshaft or lugnuts. got out and looked at both fronts and the passenger rear. got in the car and drove a few blocks and made a turn. The driver rear falls off the car, and is punctured by the rusty fenderwell. It was the one tire i did not look at. I flagged someone down to borrow a jack. He asked if I had a spare, but i did not. I had to borrow the jack to remount my now flattened tire. I had to borrow 1 lugnut from the rest of the wheels to mount the tire, and drive another 45 miles home. I'll just say i had an 11 inch rim by the time i got there!
  4. ok. I guess felpro is a big enough company they have many outsources, including oem manufacturers to be sold under felpro kits. I would like to see some more input on this. I want this thread to avoid"this brand is bad, use oem only" and focus on the actual source of parts suppliers, and their relationships. For example, for something like a car battery, there are 3 manufacturers. for oil, there are a handful of manufacturers. And if you select different brands, you get a part, although maybe of a different grade of quality, from the same manufacturer. Every time i go to NAPA looking fo soob parts, they cross reference with other makes, especially true with a lot of jhapanese manufacturers. For example, i used a 86 izuzu impuls cap and rotor on my 86 3door, after cross referencing because the specific one was not in stock. I have seen the same NOK cam seals come from different brands of packaging. I have seen NOK or "made in mexico' for the same part in the same kit with the same part number at different times of purchases And OEM subaru oor nothing argument sounds more like brand recognition. If you get a subaru kit you wont have a 'made in mexico' seal, but that does not mean you will not have a subaru oem supplied part with another brand. you could use a turbo temp sensor from a nissan, would be the same part from manufacture, but would be 'genuine' to who ever you got the same part from I would have to show this thread to my NAPA guy, he could probably rattle a few examples off the top of his head I'll try to come up with a list of all the major manufacturers, and compare who gets what from who
  5. ouch! you should take off the valve cover and have a look inside. make sure the gear on the cam is intact
  6. probably has a bad valve guide, or somehow you flooded the cylinders with oil wrangling it around. do you know the motor you swapped was good? maybe you got the pcv routing wrong. make sure you got that right, that is the only thing i could think of that may be different now you completed the swap.
  7. There is always the argument about using Subaru OEM vs other makes for gaskets. I Have a felpro set for 2.5 dohc, head gaskets and all related. I know that NOK is the oem supplier for cam seals and the like. i have ordered sets or random brands, some have NOK, some have"made in mexico" Everyone is giving me hell for using the felpro gasket set. One thing i have noticed is there is the fuji logo stamped on the head gaskets in the felpro set. (2.5 dohc, 1997 outback wagon, 4eat) I have seen the same for ea82 gaskets in the victor reinz sets. I get the impression that although felpro stamps their own gaskets, they will source other makes to make a complete set for specific applications so what gives? is the argument superficial, or is the felpro fuji stamped head gasket originally made by subaru and packaged as a felpro set? seems to be more speculation than anything. the advice i have is to stop assembling my engine and go to the subaru dealer. I already have the parts. they have fuji stampings on them. My own judgement tells me to use what i have. as far as speculation is concerned, there are those who cant predict their under 50,000 mile cars, and there are those who routinely keep 200,000 mi cars going all day long. Speculate what to fear of the unknown, or go by what is proven over and over. If a new subaru is built as good or better than an old subaru, then why does it seem like the newer the car is, the more likely it will break? old school vs new school, etc.......
  8. where do you live? i would give you a little better than scrap value if its close enough for me to travel to
  9. I'll take in your considerations. I already have a felpro set, so i am stuck with that. I had to stop my install when the haynes book turned up blank. the head and gasket are already mated, just waiting to do the torque BTW, the head gaskets that came in the felpro kit actually have the Fuji heavy swish logo stamped on them, and are 4 layers vs the old 3 layer orig. gasket next time i have a project i'll consider your gaskets
  10. got it! i overlooked the arrangement of the numbers in the post. now it's obvious. copper spray?
  11. you drill out spotwelds for the control arm mount off the ea82 crossmember, and weld it on the ea81 crossmember behind the original mounting point, essentiall relocating the control arm one width back. so the back side of the original mount serves as the front side for the new location. you will have to swap over the ea82 radius rod, or modify the ea81 original i did this on my 83 wagon. it was horribly sloppy, eyeball job, but if i took my time better, this is geometrically correct true for an ea82 track you will have to mix and match tie rod ends, it may even be possible to use a whole ea82 rack. on mine i had a mix and match of manual steering inner and outer tie rod ends. you may just have to lengthen the inner tie rod, otherwise. with my setup i use ea82 knuckles, brakes, axles, and struts. I had to hog out the center of the ea 81 strut hat to fit on the ea82 strut shaft. I later parted off my car and donated the parts to a hatch build, where the next guy drilled out the strut towers to accept the ea82 strut top my build was based on information posted by rguyver. you may find it in the archives, or in the old ezboard version of usmb from about 2002-2003 the parts will fit correctly as long as you are good with comparing, measuring, and welding. mine was a bit of a hack job considering the precision of my eyeballing skills the front track will be wider than the rear. you can go as far as using ea82 trailing arms and larger brakes in the back if you use the ea82 pivot bolt and enlarge the mouting hole. my example had a complete ea82 driveline: Motor, dual range 5spd, complete ea82 front end, and ea2 trailing arms installed on the e81 torsion tube, and the addition of ea82 coilovers in place of the shocks, doubling the spring capacity. All swapped into an originally FWD 5spd car sorry i do not have documentation or pics of my work, other than random posts you may find over the years. I got rid of this car in 2004
  12. SWEET! stupid haynes book it reads like: generic body of text, insert fsm diagram. Read one subaru specific caption, followed by vague general info. Haynes has been good to me for ea82's but i find it lacking with the legacy, it doesnt go into the 2.5 in good detail, although it covers 2.2 well enough If you can source a diagram to which bolt is numbered what, that would be great. otherwise, if i am looking at the head, i would consider the top left #1 bottom left #2 and the bottom right #6, tops are odd and bottoms are even, and keep track of my sequences based on that. let me know if that assumption is wrong What are your opinions on the permatex copper spray on steel gaskets? I have used it on ea82's with the graphite gaskets, but i have not done an all steel multi layer gasket before
  13. My haynes book cover 2.5 and 2.2, but only illustrates the 2.2 head bolt sequence in the diagrams, and in the torque specs. I am doing head gaskets on 97 outback wagon, automatic, ej 2.5 dual cam dual port exhaust. How many torque sequences are there, their values, and are the bolts torque to yield? if i were assume, i would go by what i know with ea82's, make 3 torque passes, from 22 on the first to some 60-70 on the last. this engine has 6 bolts vs 9 on ea82 the haynes book illustrates for ej22 some 8 torque steps, skipping bolts in between steps 5 and 7 for 8 bolts. the ej 25 heads are entirely different then the 22 i figured i would stop right there until i research, and since then i have thought of using the permatex copper spray.
  14. I had similar problems with mine, but would idle and not rev out. I claned out the carb by removing the top. I ended up doing intake gaskets. probably not your case. anyway, after all that the car would drive, but not idle well. I turned up the idle to compensate, was rough. I ran some fuel treatment through and it cleared out after 80 miles, i was able to turn the ilde down. I used a 23 dollar bottle of treatment that is designed for removing varnish and rejuvenating old gas. My car had sat for 2 years before i got it running. I used 2 oz to a full tank
  15. try jumping pwer from the battery to the + coil terminal. this backfeeds power to the ign and will turn the car on. if it runs like this, then you have trouble in the ignition circuit
  16. gl-10 WAS THE UPSCALE MODEL SO TURBO WAS OFFERED AS THE PREMIUM. i THINK YOU WOULDHAVE HAD TO SPECIAL ORDER(srry caps) a non turbo. the 86 gl-10 had spfi when the regular GL line was carb. There are gl turbo models out there, turbo as an option to the gl trim line
  17. depending on if you have an analog gauge, or a dummy lite, one or the other of the plugs is used depending on the sending unit.
  18. just some advice in going with a used subaru: I am doing a head gasket in a 97 outback, dohc 2.5. As i am doing the work, i noticed the orig. gasket is 3 layers, and the new head gaskets are 4 layers(felpro) Maybe soob switched to 4 layers in newer models? it would be safe to assume a subaru that has had the head gaskets done already would be a permanent fix(if the motor was not too cooked to begin with)
  19. maybe the accelerator pump is going out, or you might have a clogged secondary jet. maybe aloose vac line for the secondary. i am assuming you have a hitachi carb, which this car would have had from the factory. i had fueling issues in my 86 gl coupe. after rebuilding the carb, i found my issue to be a bad intake gasket and bad rotor. I have been running 2 oz of high dollar fuel treatment. Car quit smelling like varnish, and the sporadic idle has now settled down the cats were glowing red hot when i first got the car, and had to poke them out and repair the pipe. this was before doing anything else to get the car running properly
  20. the gl10 came with all the accessories of the gl, with the addition of cruise control and trip computer, sunroof as standard equipment. Also the pluh seats with height adjust, and fold down rear seats in sedans. Digital dash also for 5spd they had 25 spline axles(turbo) and the later models had 4eat trans(full time) with 25 spline axle as well. if its a 3spd auto, it came with 23 spline axles, but the DOJ is swappable with 25 spline. full time 5spds and rear lsd were available as options
  21. do a new radiator and new hoses. a lot of times these engines overheat due to some obscure hose blowing out. do all of them now and never worry about it. the car will be reliable in stock form with good maintenance
  22. you can disregard the distributor codes, since they will show when the key is on when the engine is not running. in your situation, i would replace the engine temp sensor, the one on the thermostat with the green connector. a new one will cost 80-90 bucks unless you can find a used one. try cleaning out the idle air valve by tking it apart and spraying it with carb cleaner, or try soaking it in sea foam. the white plugs are the clear memory connectors. the green plugs should remain disconnected
  23. i have had success running mpfi turbo on a carb block, 9.0:1 compression. Running stock boost and timing
