30
Everything posted by MilesFox
Your Suby Snow Stories Good or Bad
MilesFox replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I once drove an 88 dl FWD 150 miles through a snowstorm to make a court appearance on feb 17th. I got there to realize and ask myself "who the hell schedules a court date on president's day) I did get stuck screwing off in that town, but i was able to borrow the police officer's shovel and get on my way. that was some 8 years or so ago. more recently my 88 dl wagon is a champ in the winter. The best times are during snow emergencies when we hit the downtown to hang sideways on all the curvy streets by the river. -
90 loyale 4x4 vibration + power loss.
MilesFox replied to tedbull's topic in Old Gen.: 80's GL/DL/XT/Loyales...
are all your wheels the same size? -
there are 2 styles of spoke rim, between ea82 and ea81. The ea81 spokes come all the way to the rim, where as the ea82 spokes round out into a triangle stamping that has a n edge where it meets the rim. the ea81 rims on ea82's will have caliper clearance issues on 4wd models. you can simply grind off about a millimeter on the edge of the caliper and be good to go
86 3door fueling issues, hitachi fwd 5spd
MilesFox replied to MilesFox's topic in Old Gen.: 80's GL/DL/XT/Loyales...
FIXED! i replaced the intake gaskets, but for some reason i lost spark in the wires but not in the coil. I changed the cap and rotor and now she runs and drives:banana: -
This car is junk. I'll do the headgaskets and the clutch to see what she does. otherwise may get a 3at and 4 lug swap to make parts for my 3door:slobber:
If you try to make something custom, the bottom studs line up the same, and the pilot hole (in a manual) lines up the same. The adapter plate needs to be 12mm (or 1/2")thick to make up the difference in the EJ22 bellhousing vs the ea82 motor. I would imagine the ej22 flex plate would bolt to the ea82 torque converter the same. use the ea82 starter
you can cut up all threads all day long if you already have the stuff laying around. the thread size is m10x1.25 Typically this thread is harder to find in hardware stores. You can buy studs at an auto parts store, maybe from a bin, but usually the pre-packaged "HELP!" brand in your typical Autozone type stores. Look for 'import exhaust studs' or GM/Toyota exhaust kit. The latter will provide you with 3 studs and 1 bolt. install the stud first, and when you do so the torque is applied to the stud once you put the torque on, vs a bolt that has to thread up first. this will cost you less than 10 bucks. it should hold its torque until you take it out again. By then you still have the option of helicoil with proper thread without compromising the diameter of the hole. The kits i have used have a nut that is tight on the first thread (hand tight), so you can install it like you would a bolt. It will instert the stud first before turning the nut. Hope this helps you. good luck:)
Totally sweet! I like the in-shop engineering. i see welds on the up-pipe, what did you do? I noticed your ac alternator bracket with no pump. I had that setup not having a proper non-ac mount. good work
the driveshaft and clutch/flywheel are the same between the 2 trannys, use the bet of the 2 sets
its possible the clutch cable is too tight
you have a big canister filter under the hood behind the driver strut. the fuel pump is located on a mounting plate just ahead of the passenger rear tire, there are 3 bolts, the pump sits on top. you will more than likely break the bolts taking it apart, but that is to be expected. first check for voltage to the pump. if you have volts, check for ground. the fuel pump grounds to the ECU, but you can bypass ground straight to the body. you can use any spfi or turbo fuel pump frpm parts cars. otherwise you can buy a generic universal in-line fuel pump for about 60-100 bucks, depending on store/online, etc. if the parts counter has a hard time finding one under a subaru listing, try a ford f250 with secondary tank, main thing is in-line unit and fuel pressure rating of at least 40 or so lb.
dont be afraid of this car. if everything is in good working order, then it is worth between 500 and 1,000 if it was not for the rust its an easy 1200-1500 dollar car. for less than 1000 expect to find something with a bad automatic, blow head gaskets, or millions of miles, or completely rusted out. and if that scares you off, then finding something newer with less miles will be more prone to head gaskets than the older design. i would say this car is worth getting into, just work the price down what you can. otherwise if you walk away from it, you will have to tell yourself 'you either want a subaru or you don't' personally i would go towards 750 for this car, if i had the money. you should expect to do a water pump and timing belt at 200,000 miles if it has not been done already. this engine can easily see 300,000 miles on its original head gaskets. other than that, typical axle boots or wheel bearing. the mileage is just right to have plenty left
i was going to ask if you had an aftermarket radio. there is a green wire behind the stereo that is hot all the time, and if you short that out, there goes your #5 fuse. double chack your radio harness and make sure this wire is not grounding out. that may very well be your issue. i had the same issue and tore half my dash out, backfed power to this green wire, to later discover i had blown the same fuse!
Opinion: may be replacing my old GL wagon
MilesFox replied to RacingFlyer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the car is still worth a whole stack to someone actively looking for that particular model with that engine, to someone familiar with this car. -
first thing to look at is the tiny little coolant hose that runs from the bottom of the thermostat housing to the top of the block. its about 6 inches long. of this leaks it can run down either side or the back of the engine. otherwise it can be the intake gasket. there is a coolant passege through the intake itself. the intake can be removed as an entire assembly. you can take up the intake just by unbolting it and moving it away enough to change the gaskets. or you can undo the throttle cable, the fuel hoses and the harness connectors to remove it completely. if you have to go that far, you can leave the throttle body, the intake boots and the charcoal canister connected to the intake. this isn't white wagon with blue interior you have, is it?
the bonus side of things is the rarer parts can be swapped out and retrofitted with current models that have lots of parts availability. the rarest arts are going to be related to the engine itself, mainly the cams/heads. the piston and rods share dimensions with ea82 engines. the alternator/waterpump/timingbelt are xt6 specific the front hubs and axles are xt6 specific but can be directly replaced by newer impreza or legacy parts all of the rear suspension is the same as any other ea82, so wheel bearings are universal, brakes are same as ea82 turbo, and trailing arms are same as any ea82 (dimensonally) or turbo models that had the rear swaybar. transmission will swap out with any ea82 so long as you know what gear ratios and axle splines you are working with
If the car is reliable and doesnt cost you anything to keep it, then you may as well hang onto it. but also, a well maintained clean example would be appreciated by any subaru enthusiast. i you do sell it, please don't sell it to someone who is buying it as 'just a car', but sell it to someone who would desire such a subaru and appreciate everything that YOU have done to it. -
the original turbo in this car is IHI rhb5 water cooled unit. A tdo4 will mostly fit if you modify a mounting stud, and you use a wrx downpipe i know of one particular XT ('monsterwedge from http://www.subaruxt.com) that has a vf39 turbo from a legacy, on a TWE uppipe(one of some 15 made, special order) if you want to lowe this car properly, swap out the front struts for a FWD subaru XT, and rear struts from a 4wd xt. if you source an xt6 for parts, you can convert to 5 lug and mix and match wrx parts for suspension
OFF-Road. You either are driving up a mountain, or bombing around in open fields. If you are going up mountains, get a jeep. otherwise the xt6 will do ok. the diff lock operates the center diff. you can swap in a dual range transmission if you swap on 23 spline axle cups from turbo axles onto the xt6 axles, or swap in 23 spline axle stubs onto the suspension. clutch and driveshaft will fit the same. you will have to modify the center console for the d/r lever the lift kits you see around here will bolt onto the xt6 outside of a lift kit, you can get FWD rear struts from ea82 wagons or sedans to bump up the rear, even use honda accord springs on the ea82 struts. The fwd struts are longer below the spring perches. the front struts can be changed out with outback or forester struts since they are taller. the xt6 has 5 lug hubs that are similar to that of impreza and legacy, you can even swap in the whole front knuckles and have larger brakes, even brembos. doing this will allow you to use fwd impreza axles which will fit on a 23 spline trans(dual range) the car has a 3.9 final hear, so you can swap in a vlsd rear from a turbo legacy, or find any regualr 3.7 lsd from turbo ea82's and swap in the ring gear. chances are the xt6 may already have a vlsd in rear The car has potential and a lto fo stuff can be swapped on. bonus oints for the motor since it has 145 hp vs 95 in ea82, 110 in ea82 turbo, or 135 in a ej22(which will require bellhousing mods. the xt6 trans crossmember will allow you to swapin legacy/impreza transmissions, and with that you can go with ej22, ej20, ej25, and with the room under the hood, an eg33 svx motor or the 3.0 outback h6 if you study your subarus, you will learn that the xt6 is a bridge somewhere betewwn ea82 and legacy, being a hybri of both technologies and subaru was developin their current technology
I did the RPM challenge (closed course event) the days after christmas. first round was in the silver RS without ABS, on regular street tires. 2nd run was in the blue RS with snow tires, and ABS. The blue RS got going, but would not stop. I hit a cone because the ABS prevented intended lock-up for my turning maneuver. I was not aware this car had ABS until that moment. in essence, i momentarily lost control due to functioning ABS
Legacy, Me, Alcohol, Tow Strap, Bonfire Vs. Tree
MilesFox replied to 574-240sx's topic in Vehicle Videos Online
that is Indaiana, folks. The land of where i moved away from.
