MilesFox
    30
Everything posted by MilesFox
  1. hjow did you hook up thge pushbutton? ypu will want your wire to come from +12v to the switch, and then from the switch to the starter from what i read you connected a wire from the starter to the switch to ground? you can use the fuse panel for 12v+ from the accessory and run pos, so the starter works only with the key on
  2. both of these cars are 3spd autos. this is a rare model are they mpfi or carbureted. you found yourself a good score the 4wd tranny will bolt on exactly the same, same torque converter, bolt pattern and mounts, shifter. you will want the button and handle from the 4wd handle and may have to make a wire for the switch the entire rear suspension will have to be swapped out, as the main portion of the assembly has the differential mount. other than that, the trailing arms(hubs) and diff will have to be swapped over, along with axles you will have to swap the gas tank as well becuse it has an indentation for the rear diff once you get the rear end in the driveshaft will go between
  3. i personally would go with the ea82 myself. since you have the parts source and plan to so spfi swap might as well have the motor and all plug and play to it. spfi on ea82 requires disty mods and the ea81 carburetor, if not going with the spfi, will bolt onto the ea82 motor(the intake assembly) the ea82 gets more revs than ea81, the ea82 trasmission is geared appropriately for it. the only modification to make with the ea82 motor is to move the hill holder back a litt,e, and install the motor first, then the distributor so you can clear the master cylinder relocate the coil to the other side, use ea82 battery cables to relocate the battery to the othe side, if you wish. but you will have to remove the jack mount make a carrier bearing mount and the ea82 driveshft will be the right length for the tranny and the car going into
  4. Glossary of Terms http://www.economysuperstar.com/milesfox/subaru/service/glossary.htm
  5. all ea82 timing belts are the same between aspiration, see if you can find gates brand or subaru oem. anybelt will do, really, so long as anyone has them in stock! i would go to napa for them here is the timing belt article http://www.economysuperstar.com/milesfox/subaru/service/timingbelt.htm
  6. also from this the injector will not pules, and the fuel pump will not come on
  7. look in the subaru section http://www.economysuperstar.com/milesfox/
  8. yo i am planning a trop back to indiana and ohio by the first week of september, to run after my parts. since i will be around i can come and fix the timing belt, have the part already and i will come down, and maybe go to columbus too i should be around for a few days, the timing belts will take within 2-3 hours
  9. look up iluvdirt as he wired up the mechanism for a pushbutton 5spd using 2 toggle switches, for lack of a dp/dt switch
  10. how did you deduce the heads are cracked? let me guess, non turbo, popped a head gasket. took off the heads and behold, the infamous crack between the valves. those cracks are normal, heads are likely good cracked heads in the true sense would be cracks in the exhaust port, engine runs fine but loses coolant out the exhaust get a set of head gaskets and be good to go
  11. put an ea82 in it, bolts on the same. its a wagon, the hatch back is 2-door
  12. an ej18, with fwd 5spd, has the same clutch disc and AXLE SPLINE as our ea82/82 fwe 5spd trannies. easy conversion for the FWD crowd
  13. the noiise is probably the ball joint, not the steering
  14. it's still a subaru board. well, someone should know about an ecu. afterall, what do they think thir car engineered from? going to the old school side is the same as going to usmb. so there are other expertise in the other forums as well. its easier buy a car than put one together with someone elses money its all hype from what i have experienced there. have fun!
  15. the tire i have will go on the loyale but i will be going to indiana for some of my stash i have some 175 tires on painted wagon rims
  16. i work at u-haul and we service propane. this lady rols up in a cavalier and she goes to ppen what i thought was the trunk for her cylinder but she popped the gas cap. filled up with propane. it had an evaporayot/mix unit on the intake tube where the MAF would be, and a generic round air filter. the engine itself still had the fuel rails for gas. anyway we had the right fittings so it tool 10 gallons of propane (opd valve and all)
  17. the metal line running from the head turns into a rubber hose under the turbo
  18. dude you are from milwaukee! so am i. well, i just moved here anyway. i have soobs which one are you? im on the east side, the loud rump roast sedan withthe lights and antennae i may have a taillight i have quite a stash down in delavan milesfox@yahoo.com
  19. remove the cap and see if the disty is turning. sounds like no signal from disty, check the timing belt http://www.economysuperstar.com/milesfox/subaru/service/timingbelt.htm
  20. i have seen the same red xt6 2 days ina row just the other day, the first and only xt i have seen in all of wisconsin since i moved here. the only other xt i saw was off the side of the toll road between fort wayne and chicago
  21. swapping an ecu from am at to a maunual body, the ecu will recognize itself as an MT, as its connected to the MT's harness which will ground it appropriately and have no need for the inhibitor circuits
  22. winter is coming. dont be caught without a subaru
  23. all ea82 flywheel clutch setups are the same for 5spd 4wd. so a pushbutton 5spd clutch, flywheel, pressure plate, and driveshaft(you will need a driveshaft) will all fit the same
  24. 1. not without lower control arm modifications, or without a ea82 strut conversion(drilled strut tower or modified strut cap) and custom axles(ea81 length with ea82/xt6 ends) 1. it can be done with the right combination of stock parts 1. the axle is the key to this conversion, should someone match the right combination of axle parts
