30
Everything posted by MilesFox
anyone ever reupholster their door panels?
MilesFox replied to suprjohn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have put carpet on the door panels, and on the headliner. Novel but jank. My las 95 legacy has camouflage fabric 3m adhesive sprayed tot he removable section of the cloth covered panel. Cloth with 3m spray would be neater than used carpet for sure. -
Props to Dustin schmaus for shooting the video for me and the raw files. I have edited this up so far. There is more to put together, but some of the files dropped audio, so i will need access to the original tapes. I plan to do something like "A Closer Look At" series highlighting individual parts, such as taking a head down to the valves or disassembling a single component to its bare bones. I have lots of junk parts i can sacrifice to the video camera before throwing them out. Also, if anyone has suggestions for video topic, i'll need ideas. Thanks for watching and i am glad these videos are useful.
try to feel for an 'in-between' gear on the dist. Mind you that the rotor will rotate some as the gear engages the crank
Yes it will work. Just bolt on the carb manifold. The worst to expect with this engine and its miles is installing new timing belts and seals. It will get you another 100,000 mi for sure if you do so.
"The Art of Subaru Maintenance" video series (EA82)
MilesFox replied to MilesFox's topic in Vehicle Videos Online
photo slideshows EA82T MPFI Turbo heads CV Axle Rebuild -
#22 EA82 Front Wheel Bearings -
Car getting hot offroad
MilesFox replied to 82bratdude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds more like an inefficient radiator or fan -
Fair price for an '86 GL Turbo Coupe?
MilesFox replied to Ziginox's topic in Old Gen.: 80's GL/DL/XT/Loyales...
no, the dealer add on will have a crudely mounted stakl where someone would have to make a hole for it. By design, it looks added on. the add on unit has a big daiphragm connectd to some bracketry under the hood, with a lamp pull chain connecting it to the throttle. A factory unit would have a daphragm under the dash connected to the gas pedal -
The dealer cruise should be an add-on stalk on the steering column. The vents on the side of the car let the cabin air move through, behind it is a rubber flap that lets air move one way. -
Composite HG with frankemotor (ej22e heads, ej25d block
MilesFox replied to MilesFox's topic in Subaru Retrofitting
I found an article pertaining to subaru HG failures, and in the article it states that the 1996 ej25d used the composite HG before switching to MLS in 97. http://allwheeldriveauto.com/subaru-head-gasket-problems-explained/ -
With ea82t, you should have the wherewithall to make major repairs if oyu want to keep the car up economically. Not that it is prone to fail, but don't spend money on something you can do yourself. Preventive maintenance is key, be sure of taking care of the cooling system to avoid trouble, and change the oil often enough. Watch the temp gauge like a hawk, as it is your most important gauge, more so than oil pressure. -
Timing Advice Needed
MilesFox replied to mandalore4411's topic in Old Gen.: 80's GL/DL/XT/Loyales...
google search the term 'ea82 timing belt' and your answer will bei nt he first results
