Hi folks,
My 2nd thread ever, woo! *cough*
Trying to mess a little with the clutch, I noticed two things going on under the hood of my '89 Subaru GL. First item is clutch-related.
Item 1: Mysterious Clutch Thing
The cable from the clutch pedal is connected to an arm coming out of the gearbox. Now, there runs a second cable from this arm, running the opposite direction of the clutch cable, makes a lazy loop under the air filter (carb'd) and ends on top of a little device on the other side of the car (opposite side of the one the master cylinder is on). This device has the cable terminating on a little wheel and spring assembly, and from this device there runs a (hydraulic?) line, looking much like the brake lines running from the master cyl.
The question I have about this device is - what the heck is it? :-\ The thing is, it's not connected to the clutch arm that the clutch cable is connected to - it should be it seems, because there's a screw thread running through the arm, but it doesn't have any nuts on it.
Item 2: fuel filter?
On the right-hand-side of the carb(s) there appears to be a smallish pump type thing, about 1" in diameter. From this, as far as I can remember, one smallish hose runs to the carbs and one larger hose runs to the intake manifold on the right-hand pair of cylinders. From the bottom of this device, however, runs a hose which is connected to a white plastic cylinder, with the words "alcohol fuel compatible" on it, with an arrow showing the direction of flow pointing towards the little pump device, and a level indicator on it.
The thing about this is, the end the plastic canister seems to be intended to suck whatever from is just hanging in empty space. Nothing connected to it, and nothing nearby that appears to have to be connected to it. Also, this plastic-looking thing is not fixed to anything. It just sits there smiling at me.
Can anyone tell me what these are? Any help would be greatly appreciated!
