Everything posted by SUBARU3
A hello and my new 79 Wagon
SUBARU3 replied to Tensen's topic in Historic Subaru Forum: 50's thru 70's
I agree...think seriously about leaving it original. A 2.2 IS FAR HEAVIER. You will have suspension issues. Also you have to destroy the car to get it in! Bigger is not better in the Gen 1 case. JMHO Todd www.vintagesubaru.com -
Are Gen 1 and Gen 2 (EA 81) the same? I seem to think they are. Todd
Is all this noise normal for my problem?
SUBARU3 replied to SakoTGrimes's topic in Historic Subaru Forum: 50's thru 70's
Your new drums should be there pretty soon. TIGHTEN up this time silly!!! LOL Todd -
Remember these mileage estimates are with the vehicle in top shape. You are going to most likely be dealing with a neglected vehicle with high mileage. Thing to look at: Carb will most likely need rebuilt sparkplugs and wires. (Bet they are from 1984) Valve adjustment Air and fuel filter Clogged EGR port? Tire condition and pressure Disty cap and rotor...should be electronic ignition. Oil condition. Synthetic will get you higher mileage Change transmission gear oil. Absent top condition, your gas mileage will be much less than you think. If you "floor" it often, your mileage su_ks. So tune it up and get in the 30s Todd
He can only use a trans with a top /center mount starter.
These cars are collector cars at this point. Yes, you can use them for daily drivers, but there will be on-going "tweeking and fixing" needed. They are nearly 30 years old now! Thats 210 in human years! If it's not rusty, PLEASE keep it out of the salt!!! Wash well and frequently under the front wheel wells toward the top. Consider selling it to a collector home. Most mechanical, brake, steering and suspension parts can be found fairly easily. Interior, sheetmetal, glass and rubber are a different story. The cars are rock solid though and can take a beating! Todd
got my new 1980 Brat
SUBARU3 replied to danrenfroe2016's topic in Historic Subaru Forum: 50's thru 70's
OH.... Daniel: Check www.car-part.com 1979 Air Box/Air Cleaner Subaru BratOK 0 2080$25Mid City Auto Supply USA-NE(Hastings) E-mail 1-402-462-5121 They might have an aircleaner. Todd -
Daniels a good guy! His BRAT sounded good and it's a nice rust free example!! Can anyone help with a GEN1 "round" aircleaner for him?? I saw his Weber working, may need adjustments, but it's good for someone that knows Webers. (Something I don't) He even has the nice aircleaner for it!! Todd -
will a weber clear the hood of a gen 1?
SUBARU3 replied to the sucker king's topic in Historic Subaru Forum: 50's thru 70's
This guy: danrenfroe2016 is selling a weber and a brand new air filter for it. Contact him. Todd -
removing a/c condensor **PICS ADDED**
SUBARU3 replied to REXSPEEDWORTHY's topic in Historic Subaru Forum: 50's thru 70's
Well, it looks like it will work! Compressor gone! -
Strange low rpm hesitation
Often the little jet that the accelerator pump pushes fuel through clogs. Use a small piece of wire to clean the opening out. Todd -
SEVEN Gen-1 Brats in White City, OR
LOL.. I'll be conducting :"Introduction to Subaru 101" soon. Tell him to enroll. Todd -
price on a 79 brat
SUBARU3 replied to milkman111083's topic in Historic Subaru Forum: 50's thru 70's
They are going up in value. 3-4 K is not uncommon for good clean, unmolested BRATS. Consider it an investment. $1500 is not bad. Todd -
Yep, accelerator pump, or clogged accelerator pump jet. Todd -
Use razor blades! DO not try to save the dried,old rubber. (Unless it's a replacement seal and fairly new) The glass is more valuable than the rubber at this point. Cut straight down around the edge and then in between the glass and rubber. (all the way around) You know when you have cut enough, when the glass just lifts out. Todd
I believe the 1600 will fit fine. As I remember from the shop days, that happened a fair amount anyway. As for 4WD...bugger of a project. Capture nuts not present, crossmembers, gas tanks, exhaust all different. Paul...chime in on this. Todd
Hmm.....pics would be good! Todd -
Both my 95 Imprezas and my 95 Legacy all don't seem to allow the compressor to cycle on and off in cold weather. If I select defrost, the compressor turns on to decrease moisture and fogging, but when it's below 50 it seems that they cycle on for about 3 secs and then rarely turn back on. This doesn't allow defogging to be effective. All these car's A/Cs operate VERY well in the summer. Is there a temp sensor, or is it just that the evap sensor gets cold fast and cycles the compressor off? I'm confused. Thanks, Todd
Actually, I am doing "headshots" of all my cars and placing them on my actor's site. Shooting them in a nice field , in a parking lot ect. I also have used my1980 VESPA scooter in film. There is a growing need for 70's cars!! I keep all mine original and unmodified. That's what directors look for. http://www.todd-peters.com Todd
