It's been a long time since I've been here, but my 99 Legacy is dying, and I'm looking for my 4th Subaru.
I'm currently looking at a 2003 Legacy Wagon. It's a little high in mileage (155k) but the head gaskets, timing belt, and water pump were replaced at 120k. It looks like it's in great condition, but there were 3 problems that I saw.
1) It has very new tires (less than 2000 miles), but they must have hit a pot hole and there's a bubble in the side wall of one of the tires. Would 2000 miles be enough wear on the tires to cause problems for the AWD system if I just replaced the bad one?
2) The check engine light wasn't on butI used my obd2 scanner, and there was a pending p0128 code. It seems like this is a problem with the thermostat or a bad coolant temperature sensor. Is this something to worry about, could the owner be hiding something?
3) Finally, and this is the least of my concerns, there was an issue with the lift gate. I saw the car after a rainy week, and when I opened the lift gate water poured out of the openings that you use to replace the tail lights. I'm guessing that there's some kind of seal between the tail lights and lift gate that's leaking. Am I on the right track with this?
Thanks,
Steve
