Everything posted by Hondasucks
is the dizzy properly timed to the crank and cam?? Remember that there are TWO TDC's of the #1 cylinder, needs to be @ TDC of the compression stroke. (With the timing marks at 0, both cam lobes for the #1 cylinder should be up)
Oregon Dunes, Memorial Weekend
Hondasucks replied to Adam N.D.J.'s topic in Meet n' Greet. Your USMB Welcome Center
hell yeah, I'll take my s**tbox out there! count me in -
EJ20TT in place of EA82T
Hondasucks replied to domator's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You will need an EJ series gear box, teh EA gearbox will not hodl up to the horsepower at all. As for the wiring, you should be able to get a stand-alone fuel management system for it, check http://www.haltech.com -
WEll we're gettin snow! Woke up this morning at BajaSoobNuts house to it snowing outside. Within 2 hours there was an inch or two on the ground, thank God for the Soobs! Don't tell Heather but we got the Forester sideways ;-) Got my Turbowagon a little squiirrly too :-) Not any snow on the ground down here in Albany, but my friend says that there is snow in Eugene too :-) and it was snowing earlier, so hopefulyl it will snow here soon, I need some stuff to play in! Plus, I can use my tow strap and drive around yankin the idiots out of the ditch :-)
Check this out, Subarus on Jones Soda :-) http://www.jonessoda.com/gallery/view.php?ID=155174&search=subaru&offset=1
MY 91 had a badge on teh dash that said "Full Time 4WD" with "ABS" below it. Since it was not really AWD but it was fuill-time 4WD with an automatic viscous locking center diff. (Would have rocked if they had added in a diff lock like they did on the older FT4WD, since that viscous lock took some considerable wheelspin for it to engage.)
Spanish Fork, I know where that is. Know where Price is too :-) I'll have to check that yard out when I am down there for Christmas :-)
Hitachi-carbed '87 GL Wagon: all this gutless?
Hondasucks replied to jdub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've driven my friends 87 carbed wagon, and it's about as fast off the line as mine is, but there's no turbo to kick in and make it faster like there is on me :-) She loves mine, but she is afraid with her lead foot that a turbo would get her in trouble :-P You want to talk about gutless, drive my 83 GL-10 I used to have, I remember going over Siskiyou Summit going to Calfornia floored in 3rd gear pulling 55 MPH. Not too bad though, I still managed to get 32 MPG between Albany and Redding, CA (380 miles) Still had 1/8 of a tank too! -
87 4WD carb wagon cooling system issues
Hondasucks replied to Hondasucks's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Leakdown tests show the cylinder's ability to hold air. Normal leakage is about 10%, much more than that and you know you have probs. I've seen engines develop compression pressure that was low but within spec, but have 40% leakage. Not good. Although if her head is cracked in teh exhaust port like they usually do, a compression or leakdown test wouldn't show it, since it;s not in teh combustion chamber. -
the wagon springs did not increase the height of my car all that noticably, it didn't sit "raked" or anything, it maybe raised it a half an inch to an inch. The only way I could tell that it raised it up was that the muffler tip didn't scrape pulling into my driveway anymore. And yes, the springs ALONE are responsible for ride height; the shock does not support the vehicle weight, it only prevents the spring from oscillating (i.e., keeps teh car from bouncing up and down when you go over a bump)
although I talked to her today, and she says that now it is acting fine, although she did find another puddle of mixed water and oil underneath it this morning :-( but she said it didn't overheat at all last night. She said it got a little hotter than normal, but then like 30 seconds later it was back at normal again. Would a compression check make a cracked head show up if it was cracked in teh exhaust ports? I know there is a check to determine if there is hydrocarbons in the coolant, but I don't want to go spend $30 on a tool, does anyone know if you can get test strips to determine this?? I don't want to tear into it if nothing is wrong with it. -
Loosing power on hills/ no codes found
Hondasucks replied to Chris W.'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
well if you are loosing power you might want to tighten it When my 87 Hatchback started losing power like you describe, it was teh first sign that the fuel pump was going out. If the fuel filters have been replaced, I'd suspect the pump. -
good mechanic in Portland,OR
Hondasucks replied to rabbit_39's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah Richie is a good guy, he's never worked on anything of mine, but I did buy a car from him a while back that I never had a problem with, and I've seen his work. -
Hey are we gonna have an Oregon Off-Road Subaru Club tree run this year still? If so I guess I need to get some meats for my sedan....
