![](https://www.ultimatesubaru.org/forum/uploads/set_resources_9/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
one eye
2
Everything posted by one eye
As the strut compresses it moves away from the the front near the door as the trailing arm pushes it back. Jeff
I cut the hell out of mine to get 30's on it here are a couple others too
The control arm was making noise all day, I think it was on its way out but the longer radius arms where the Icing, as for the Swampers...... amazing, they bit so hard I couldnt belive it, the hooked up so good that I need and EJ swap, the ol' EA81 just dont have the power to really even spin them. I was very impressed with them, but my clutch thought otherwise Im sure...lol Jeff
Right on I like filled up fender wells, the 2" is a good lift for a little bomber like that. :cool: Jeff
So I did a search to see if EJ18's have as much power as an EJ22 but the seach came up with 60 bazzillion results that didnt hit what I was lookin for. So My question is, In the EJ world, do 18's have as much power as a 22? With my new tires I need more power, the EA81 is not cutting it. Any info is good info................. unless you dont have one and you are just assuming............. Jeff
So Andy and Brian came over, and Tex came up, for the weekend and we went wheeling...... image that huh? here are the pics Thanks for takin pics Tex, And just remember Ranch goes on anything!! Then things went south a little, I broke my control arm, then my axle and bent my Raidius arm, about an hour later we where all good to go.........home lol, could have been worse......... Jeff
Right on sounds good, I'm looking forward to this big time!!! Jeff
And it begins!! There will be a big thread for the Mid Summer run in the next few days or so. Mike do you still have my number? I would like to B.S. with ya about a few things!!! Jeff
this is where things got hard core........................ Jeff
Ya Bill did that on his too, I think I might have to do it just to get it to turn and not tear the knobs off on the Tires.................... Jeff
I just got them on this afternoon, picked them up in White Center around 10am and had them on my car at about 3pm, I cant wait to use them, but I got a little work ahead of me before I can go wheeling again. This last Run was a bit hard on old Butters, I broke a couple of welds, tore a mirror off and smashed some of my pannels up. Not to mention I need to pound over the pinch welds and trim a little on the fenders, 30s would work with little cutting and pounding but the 31's with lots of tread, need some clearance............................ Jeff
So I was checkin out CL a few days ago and found some new tires, they where a little big but I figured...... I will do it............... here is what it look like now 31x10.50x15 Super Swamper TSL's and a new set of wheels too............ Jeff
Ya I went through 19 axles before I caught that one.......... once I did changed that out, never had one go again..................... Jeff
Looks like Rick, Pat, Dan, Matt, Yohn, Me and Woody's Jeep buddies are in. Jeff
The time is almost here!!! Jeff
3" is going to be hard on those axles, its worth a try though...... Jeff
This is mine off my car its an 8" lift but you can see how you cut the eye off the bottom strut and add how ever much you want for your lift......... 3eyedwagon added that piece on the back to make it stronger, on the 2" you dont need to do that................. Jeff
Lookin' for a Front Li'l Lift
one eye replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have put a ton of 2"lifts on with not dropping the crossmember at all, one inch blocks would be fine, no problems at all, the only problem is getting them in there, the bolt and the stud will want to hit each other I think...................... If you do a 2" cut them at 17 degs it makes it even better for dirving on the road, your tires will sit a bit flatter to the road... Jeff- 88 replies
- JesZeK
- Modifications
(and 6 more)
Tagged with:
Im sure the one in the 87 GL10 Turbo Wagon is good, I Drove it to where it sits. If you wanna pull it out you can have it................ Jeff
Ya it might take a few fuel filters to get that cleaned up, but at least your on the right track, I figured since there was no Gas in the tank and that the cap was off that might be an issue, at least you got it figured out.... Hope you like it. It looks really good, Sorry Rick and I didnt get those fenders cut, we went up to dinner at Grandmas house and I for got about it..................... sorry..... Hope you like it!!!! Just need to weld the rearend up and your race ready!!! Jeff
Nice that looks good!!!!! A bit bigger tires, and it will be set up perfect!! It does look really cool right now though!!!!!!! Jeff
