one eye
    2
Everything posted by one eye
  1. Right on if you change your mind I got one for ya......................... Jeff
  2. 300 E College Way Mount Vernon Wa 98273 Jeff
  3. Eric do you need a welded rear end to borrow for that weekend? I got one if you want to barrow it............... Jeff
  4. So What does the group look like................. So far it's Me Richard Rick Scott Eric Bill Woody Brian J. T--------Roy?????? Cody possibly and someone Possibly Pat Driving my White car........... Anyone else want to come Play??????????? Jeff
  5. Well Since Nov 7th is the big day for Wheelin I figured We would go check out what Walker looked like...............it looked good!!!!! Me, Rick and Dan went up.................. Open Diff............................. Jeff
  6. I went up there today..................... Things are looking good!!! Its going to be real fun. It was nice and slick, went down Lower Mainline and halfway up Upper, it is going to be a challenge........... Jeff
  7. Ok sounds good, Up lower mainline to B1000 and to the Upper side of upper mainline!!!! Make sure you are welded !!!!!!!!!!!!!!!! How do you change the Header on the top to say Walker not Rieter????? or can a mod change it for me????? Thanks!!! Jeff
  8. Cool Want to make it a Walker run then? Eric and Scott........ what do you think? Jeff
  9. T-roy you want to go on a Walker run?
    Jeff
  10. Not that I'm saying none of the guys that are from out of my area count but most of us are from Up north, Skagit Snohomish, and Whatcom Co's, I think to have a decent Group, I would need to be in this area, I'm thinking Walker would amost be best...................... Bill It would still be sweet if you could make it over.................................. Jeff
  11. Just get really really pist off, and drill them out to 29/64 and run a 1/2 20 tap in it............. thats what I ended up doing to day...................... Jeff
  12. Its an EA82 car with an EA81 in it, The other tow holes where for the evironmental stuff, the Steel spacer blocks, they are what broke, there are bolts broke off in the heads where they are supposed to be, I only have one option for holes, and thats the way the exaust bolts up....... Jeff
  13. I'm going straight in the aluminum head and the bolt is Steel........... can't weld that.......... Jeff
  14. I tore my exaust out last week, and I went to fix it today, I tried the Heli coil kit first bit that went south quick, then I tried to tap it out a little more, I now have the hole up to a 1/2" and I think I screwed up those threads too.................................. Has anyone used JB weld in the hole before and had it work? I think I'm running out of options other than replacing the head................... Any Ideas would help............... Jeff
  15. wouldnt the Naches trail be hard to get to for you? 410 is closed since that slide right.............. or is that not part of your route? Jeff
  16. Could do a walker Run................................. This sucks, I wanted to run down there and play................... What other Ideas does anyone have? I dont want to do a EC run. We where just down there. Jeff
  17. Nov 2nd is the last day of Rieter I guess........................ http://www.nw-wheelers.com/forum/showthread.php?t=44474 I think you have to be a member to see it but its all there..............game over........ for now.............. Jeff
  18. What????????????? I'll check it out.................... Jeff
  19. Right on, I look forward to Wheeling with you Bill, I hope you can make it!!!!!!!! Jeff
