ellets
About ellets
  • Birthday 01/07/1936
  • Location
    Lake of the Ozarks, mo
  • Interests
    woodworking
  • Occupation
    retired
  • Biography
    electronic tech
  • Vehicles
    gl wagon and coupe.94 leg
ellets's Achievements
Advanced Member
Advanced Member (3/11)
10
  1. Does anyone know where the sensor is that tells the dash indicater that the rear hatch ts open. mine is on all the time, 1997 Legacy wagon
  2. Does a 94 legacy instrument cluster fit a 97 legacy dash. also plug in's etc.
  3. By all means change to rear disk brakes. Check out parts wanted and parts for sale .A member can sell you a complete package from a gl10 or an xt. I paid around $100. That is about average. Easy bolt on install.
  4. I just bought bearings for my 88GL 4wd. Got them from Rockauto $65.00. Got seals also. Allan
  5. I have found that the only split boots that are ang good are the ones that are held together with a row of bolts. They work and last a while. I am on 4years on a set on front of my Luv 4x4. Google bolt together cv boots.
  6. I have determand that all the struts on a recently aquired 97 legacy Brighton are worn out. I was just wondering if just the cartridges can be replaced instead of entire strut.Sure would help the pocketbook. Thanks AL
  7. I have an 88gl hatch.Lots of rust but still driveable.The ea81 purrs like a top. Had to put a new muffler on it and couldn't resist a cherry bomb. Sounds great.Gave 400 for it. Havent found a carb for it yet. I need one for parts.
  8. Is there an easy way to tell if a 2.2 is an interfearance engine or not. I have 3. one is 94 turbo but the other 2 could be 91 to 97.?
  9. Would like to have that gas cover. My computer is cookie so will try this also.
    allan102@gmail.com
  10. Things are screwy With computer so will try messenger. please PM or email me with price and how you want to be paid.
    allan102@gmail.com
  11. Need some help. Had a ball joint come out and screwed up front end on one side. Are the axles different from an 88 g l coupe ea81 and a gl wagon ea82. Ea82 axle seems longer. I haven't been able to dissemble it all yet. Looks like i am gonna need parts.
  12. Some bad days are worse than others.To get out of my place and get to main road a steep hill must be climbed. Ie put in 4wd throttle up and hang on. No 4x4 forget it. I was headed out in GL coupe when I had a loud bang and car dove of the road. Pulling it out with larger 4x4 i see rt front wheel tucked up under fender and pointed hard right. A little more probing found that inner cv joint had exploded. There were little bits of it all over. everything is bent. Got a lot of parts to change. Good thing there is an old dl wagon up in the back As soon as weather permits will have to start pulling things off.
  13. This thing is weird. None of the usual places are there. The little doors on the side of the rear corners not there. I shall have to try to find an owners man. Silly little car.
  14. still don't see anything. my gl wagon has a cardboard cover but don't see one on coupe??
  15. Where do they hide the jack and lug wrench in these little subies. No I don't have an owners manual. And yes i am about half blind. Found nothing in search. 1988 GL coupe
