ellets
Everything posted by ellets
I think I have gotten up the creek. Major computer crash and lost all the pictures of engine in 94 Legacy. I didn't tear it down and the guy who did can't help. (stroke) It is a turbo model and I don't have access to one to see where all of it goes. I have a 91 but it isn't a turbo and is completely different. I am open to any suggestions or ideas. I hate to scrap it as it is very nice.
hose
ellets replied to ellets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
to try to explane it better it is about 3/4" diam opening. it will lay in palm of hand. It runs from bottom of intake manifold to a nipple just below it. Hence the tight 180 or U shaped bend. -
on my 94 legacy turbo there is a little (U) shaped hose under the alternator that goes to intake and motor It is apparently only on the turbo as I don't see it on a 91 non turbo. Does any one know what I'm talking about and has anyone ever found one. I have no subie dealers closer than a hundred miles and they don't even want to talk to you without a part number.
Guy's is there some trick to getting the timing belt back on this thing. It seems to be 1/2" to short. It was on this engine so I know it did fit. This has been the worst subaru I have worked on. I'm just about to pull turbo engine and put 91 non turbo engine in it. It is a nice looking car and I need it running. Regular trips to Doctor.
I am trying to reassemble my engine.I didn't take it apart. (long story) I can't locate timing mark oncrank gear.Iknow that it should be opposite the key and supposed to be a mark on crank position sensor but I cant find it. Also is the little line on cam gear the timing mark? And on this engine (ej22t) how are the cams set. I see the mark on plastic behind cam above gear. I am comfortable with ea82 but am lost with this thing. Help please
fuel pump on my 88gl spfi came apart. must replace. anyone have a working used one i can try to buy?
engine swap.
Car is a 94 my typo. Engine was pumping coolant out the tailpipe. Pulling the heads didn't show any problem. Had the heads milled but shop couldn't pressure check them. On attempting to reassemble couldn't hook up oil drain on turbo. Guy who was trying to help injured his knee and is out of business for months. I managed to injure back and am not much better. We couldn't get the turbo off to hook up hose.have considered pulling engine to access the d----mn thing but can't even do that now. Getting old and on ss makes everything even worse. -
Well I got it going. I rechecked timing belts and tighten them a little. Checked dist and set timing mark on flywheel to #1. put cap on and no go. to get it to start dist had to be set 180deg off??? finally after resetting dist about 3 times it suddenly fired up and purred like it should. New timing light came today so was able set ign timing. sounds good. has a cherry bomb on it. Now if only I can get legacy to run like that.
The easy to get crank pulley loose is to put breaker bar with socket on and let bar handle rest against the frame then bump starter. bolt will come right off. There are timing notches on top and bottom of rear covers. at least on my ea82 88 gl there are. The timing kits from ebay are fine. I just found one for 50. Getting the springs on idlers hooked up taxed my old joints a bit.
put a weber 33-36 carb on it. will run better more power and problem solved. I got one from a member with adapter very reasonable. run search for weber carb, there should be some good writeups on conversion.
Millage unk guess 170k compression all cyl 160 or better no backfire but a weird kind of kickback then it will start. all timing and ignition replaced and settings triple checked. This tees me off as this engine always started easy even when temp was below freezing. as far as the comment of flooding engine if it is it must be in controler as this is spfi.
My 88gl is slowly grtting its problems resolved. Here is the latest one. It acts just like a carbed engine with no accelerator pump. Ie if you throttle with a cold engine it will quit and die. If you let up on throttle it will pick up to 1k rpm. Ne1 have something like this and resolved. (it runs fine when warm.) Here are most of what it has had done. timing kit jy fuel pump (good pressure) jy distributor new plugs and wires dist cap jy mas coil and ignitor from member tested good. and it is spfi
Car is an 88gl 5sp d/r It has developed a wild problem. It idles pretty good but if you give it throttle over 2500 it sounds like a diesel with the jake brake on. I have checked timing belts (deadon) put in a known good coil and igniter. put in a known good distributor used but good fuel pump. old one had 5lbs of pressure. car is a spfi. Some good points I haven't tried yet. fuel filter plugs and wires. also tried another computer. no codes showing. Sure could use this car.
Have to do hg on 94 lego I just bought I also decided to do the valves since the heads had to be shaved. What in the world do you guys use for A valve spring compressor. I have 4 different kinds here and none of them will work. Trying a Little Home mod on one right now. This is a real pretty car with no rust.Besides it has a turbo.
Still having fun with old 88. It decided to backfire a few times then quit. life is over. Thanks to 94Loyale a good coil and igniter Got it to start but it ran terrible. Pulled the front apart and checked timing belts. All ok. Checked fuel pump and it was low pressure then all of a sudden it came up to 40lbs. Next on the agenda was the mass airflow sensor.Swap it out and ran better??? Next was to check timing and sub out disty. Ran much better. About normal for this car. One of the strange things was the plugs on left bank were all sooted up. Right bank ok. (new plugs) It never did throw any codes. I will finish putting it together tomorrow and drive it a little. I think this car has a hex on it.
94 Legacy
I may try to pull engine. Truly a shade tree operation. I can throw a tranny jack under auto and take engine out. Will consider that. This is my first lego and it is so different fron old GL. -
just when the legacy goes down the gl decides to have a fit. Go down the road and it will buck severely. No codes??? I suspect fuel pressure. 88 spfi. I think I will see if someone has a good fuel pump setting around. Also need to change ignitor and cpu to see what happens.
I do believe this is the nasties car I have worked on. Service info says heads will come off with engine in car. Left side NO WAY. Never saw so many hoses and wires. Car was pumping antifreeze out the tailpipe so hg or heads are suspected. I always gave the baddest title to the Mazda MPV awd I had.I got so mad at it I parked it for 3 mo when it blew hg. I'm going to loosen engin mounts and try to move engine over a 1/2" to try to clear left frame. If I don't find the cause of leak I may have to park it untill I find a ej22t. Oh Well.
