SOOBOUTLAW
About SOOBOUTLAW
- Birthday 06/30/1979
Location
EVERETT
Interests
SUBARU OFFROAD,AUTO MECHANIC
Occupation
FRAMER (CONSTRUCTION)
Vehicles
80 wag,83 Brat,90 Legwag
SOOBOUTLAW's Achievements
Subaru Nut (7/11)
12
I just installed and wired dual filament bulbs and sockets to put the turn signals in the parking light lenses('90 Legacy). For some reason, I keep burning out my parking light fuse. Before I replace the 10 amp fuse with something like 15 amp, I'm wondering if the original parking light plugs, which I spliced onto the socket wire, could be causing too much resistance. Looking at it, the prongs are as thin as accupuncture needles. I'm using basic 1157 amber bulbs, reamed the lense holes out to make them fit. The turn signal lights are crimped on spade connectors well wrapped with electrical tape, the parking lights are the stock plugs spliced on(the bulb side). I'm thinking the plugs are the problem, but wanted other people's opinion and advise.
I'm rolling on 195/75 R14 passenger radials, stock suspension, no trimming whatsoever. Just a tiny tappy tap where it was kissing the fender on takeoff. I got pix but I really suck at posting them.
I used whitening toothpaste on my Legacy headlights, then sealed them with three shots of clear. Came out pretty nice. Much better illumination at night.
Damn, if Autozone pulls that $#!t on me, they'll get sued. The replacement GCK axles, that I got used at PAP, are now starting to act up and vibe. Wonder if it's the excessive low end torque output on my motor. It's like a f'n diesel, 1200 rpm burnouts. BTW, seems like only one axle ATM. The one I just replaced. Going camping this weekend up in the mountains so I'm bringing spares. And RWD stubs, just in case I break something in the front diff in the tranny (done it a couple times or so).
Been away for awhile... The problem turned out to be the DOJ on both axles, easy rebuild. Meanwhile I replaced them with..... GCK axles:grin:. Drives so much smoother. The problem axles were getting so bad I thought they were gonna break. I even pushed them hard to see if they would. Gonna take them apart and have a look see.
Axle cluster&^@% please help! Updated
SOOBOUTLAW replied to zenofchaos's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the axle is 180* off, the pin holes won't line up right. It may look like they do, but they only line up one way. The resistance the mech felt may be the misalignment of the holes. -
k I just bought a 81 hatch 2wd with ea81 for $50 the other day. was told it had a broken baseplate on the carb, so I replaced it and cleaned the carb out while I was at it. then I tried to start it, nothing, then I went through and checked plugs (bought new ones), coil wire(new one too), put on a new cap n rotor. tried again, nothing. so i hooked up my lil trigger started deal so I can watch the engine bay while starting it. pulled the #1 plug wire off of the spark plug and with a screwdriver in the end of the plug wire cranked the engine over with the key in ON position. and got no spark with it close to a good ground area. so i tried it with the coil wire and nothing. went and checked all the fuses, was told to check fusible links, but the hatch actually has none. so then I checked for voltage on the coil +, and there is power to it and its close to 12V. I have the feedback carb with the ecm under the steering wheel, there is a ballast resistor and an igniter. im told that it may be the distributor. is the little light on the ecm supposed to light up when the ignition is in the ON position? is there anyway I can get around having to use the igniter without having to change out carb, which is the 2bbl hitachi feedack carb. The disty is not a points style and has one vacuum port on it, Ive also followed the wiring to the carb and disty and coil/igniter/resistor, all of it is fine as in good grounds, no shorts or burnt wiring. dont have a manual yet so I dont know what to look for like resistance/voltage/amps of any of the circuitry. Im going to put the coil in my brothers (SOOBOUTLAW) brat tomorrow to see if thats the culprit. any ideas? or is there any gurus out around the everett, wa area that wouldnt mind stoppin over to try n help me out. is there any way that i can get my disty tested out? or could any of the electronics on the feedback carb may have crapped out? I may just end up doing an SPFI swap if possible if I cant figure this out within the week.
junkyard prices for D/R 5 speed ...
SOOBOUTLAW replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
$50.50 plus tax and a $9.50 core charge at PAP. Bought a few trannys there over the years for various vehicles. All worked fine. One blew up from running 13 lbs of boost too much. And that one was the replacement for the other one that blew up. Gonna get another $50.50 tranny and see how long that lasts. -
I've put like a mile on em so far. Only one axle seems to be the issue. I have a pair of old GCK's I scored from PAP that click a tad. Gonna put a few highway miles on them(new ones) and hope it smooths out.
I just installed brand new GCK axles (bought a couple years ago) along with new wheel bearings, seals and lower ball joints (also swapped primo vented rotors and calipers with brand new pads from PAP!!) in the Brat. The GCK's are so tight there is no play at all. They will even hold their position of whichever I turn it to, like up. But, it's so tight it gives me vibrations from a dead stop under acceleration. Anybody ever have this issue? If so, how long until they're "broken in"? I believe only one axle is really tight which makes it harder to turn (the CV/DOJ) that causes the vibes.
Brakes vibrating like crazy
SOOBOUTLAW replied to Caramanos2000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Your wheels could be out of balance. -
I have '04 Sti springs pending installation on my '90 Legacy wagon. The front springs are too short for the Legacy struts, and the top spring perch has to be replaced with Sti ones, so I gotta get Sti struts and put Legacy tophats on them. The rear springs are tapered just like the Legacy rears. They almost double the stiffness over stock Legacy springs. (125 lbs per inch WTF?? mushy). Supposed to drop the ride an inch or so with Sti strut/spring combo.
The seat refit write-up thread
SOOBOUTLAW replied to Ever Victorious's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I put Legacy seats in the Brat. I used 3/4"x1" steel stock to make adaptor blocks. The Legacy seats are a bit wider than the stock seats. The first blocks I made for the driver's seat were just 1/4" off center, but it really bugged me cuz I could tell it was off center just by sitting there. So I used those blocks on the passenger seat and made proper blocks for the driver's seat. The seats sit 3/4" higher because of the blocks. Plus, the Legacy seats are already taller to begin with, so it kinda makes the Brat feel like a big go cart.
