friedli
  • Location
    Petoskey
friedli's Achievements
Newbie
Newbie (1/11)
10
  1. I searched through many old threads and could not find enough information on this awd system. This forester awd system seems to stop working at 40 mph. I can't find a problem with the system and I'm begining to wonder if it is designed to operate like this. I found several posts regarding a switch which can change this system but they seem to be more for off roading. Is this system designed to stop working at higher speeds.
  2. I apologize I should have been more clear on original post. After not seeing the led through the flap in the carpet I removed the passenger seat and carpet and completly removed the ABS module and still could not find an led. Also the ABS module has only one large connector plugged into it. My manual shows two different smaller connectors on the 94 model. This is why I thought to look at the 95 model year and the process to pull codes for a 95, which says to short pin "L" at diagnostic connector under left side of dash. I believe I found this connector and the ground wire to short it with but there is no terminal in the position that the manual says to short.
  3. I'm trying to figur out how to retrieve an ABS code for a 94 Legacy. My manual says and Led is found next to the ABS module underneath passenger front seat that will flash code after driving 19 mph. I find the ABS module but not any Led. Any information would be greatly appreciated. Thanks. Kevin Friedli
