TedZ
About TedZ
- Birthday 03/30/1941
Location
Glens Falls, NY
Vehicles
2002 Outback
TedZ's Achievements
Member (2/11)
10
Having it die i can trouble shoot. What mystifies me is that it makes a strange noise when cranking now, like it has nothing attached to the crank but the front pulley turns, no clunks from valves hitting...maybe they have all been hit and there is no compression on any cylinder but that seems strange. I would chalk it up to a broken timing belt if it didn't sound so wierd cranking. Going to pull the cover and a plug this a.m. What i am asking is after a 2.5 valve crunch does the engine crank completely differently? Thanks. Ted
Just to close the loop on this thread, the tail lights are fixed. There was a short in the wire going from the under dash fuse panel to the Security Control Module. No one had ever run into this, so i want to post it here just in case there is another unfortunate. A dealer in Norwalk CT found it after hours of looking. They kindly only charged my for three hours labor because they felt they should have found it sooner! I didn't think there could be a wiring problem i couldn't find given enough time. So much for that thought. I knew there was a wire going to the SCM from looking at the wiring diagram but i never checked it. Thanks to all who responded with great info. I learned a lot for the next time! Ted
Hi and thanks. You are right, forgot about the original load providing a path to ground also. Fuse number 5 is a 10 amp fuse in the '02 Outback and that is the one that blows. I thought the deer crash and this problem were related right from the beginning but i came to doubt that after ringing out every connector on the car and finding no differences in right or left front connections anywhere. I have observed some issues in the right rear and that is where i am going to "play" with the test lamp etc. Thanks again for taking the time to answer my post and for the education on test lamps:) . Ted
That is a great idea. No light, no short to ground. I would still love to know if there is a tail light relay anywhere as the short may show when the coil is energized...fried coil, or the light may not light unless there is an energized coil somewhere revealing the short to ground and then lighting the test lamp. Thanks. Ted
I love this forum and have searched to tears on it for the problem with the clearance lights that don't work on a 2002 Outback. Looking for the tail light relay. It is not in the main fuse box under the hood and not in the fuses under the dash (behind the pull out junk "ashtray") Perhaps there is no relay, i don't know. I am a good "meter man" being an EE and i have checked every connector remotely associated with the clearance lights and all measure appropriately either to ground - where they should - or through the light filament where appropriate. Yet when turned on fuse 5 under the dash blows instantly. When i powered the clearance light directly (i have the alligator clips with small spikes on them...love them) i thought the right rear was showing signs of being dimmer but the 16 ga. wires to the lights were both getting warm equally. (I was connected to a low ampacity source...suppose i could try it from the battery). My questions are: Where is the relay, if any. Has anyone had a light fixture go bad and cause this? Could a bad bulb do this??!! Does the headlamp/tail light switch go bad ever?? Thanks
Hi, 2002 Outback. Hit a deer, fender and hood replaced, good job, all is well. Two weeks after the repair, fuse F5 blows, no parking lights whatsoever. Checked all of the light assemblies, all ok. Short in the wiring in the replaced fender as left front parking lot connector shorted to ground. How do you access the wiring in the fender between the light and where it enters the main harness to the under-dash fuse assembly? Does the fender have to come off i-hope-not? Thanks. Ted
Dmanaenk, The connector you found is for the cruise control...don't bother ripping the glove box out, it is not there. You will likely not find the 2 pin connector in the steering wheel either. Cut it off and put a 1/4" female spade connector on the green and connect it where there one you are discarding was connected. Good luck. Ted
Lots of ways...all take a little effort. You can make a fixture out of a broken spark plug, all-thread, flat washers and a couple of nuts. Turn slowly until contact is made. You can hydraulic a cylinder with 80-90 gear oil. Fill it with the piston down, put the plug back in and turn SLOWLY. Then after the bolt is out you have to wick the oil out by rolling up paper towels until you get it all out through the spark plug hole. There may be accessory drives that can be restrained but i am not knowlegeable enough on Subarus to advise you. Ted
Blower resistor
TedZ replied to gcleeton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I would look at the plug to the blower motor...chances are you have a high resistance connection there. If the motor (and resistor bank) get power and the motor doesn't start you are going to cook the resistors quickly as they are air cooled i.e. in the heater duct. One warning. My experience with this common problem is with all kinds of vehicles but not one Subaru. this is an electrical issue however and i believe the wiring philosophy is the same. Ted
