Everything posted by 2X2KOB
some inspiration
2X2KOB replied to leon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Looks like about zero body roll. -
Whining? I hate whiners. If I were you I'd slap it good and tell it to STFU and GBTW. But really, it might be just one of those things that you choose to ignore, especially if you have tried other fluids and additives with no help. Unless you want to change the pump, which is not warranted in my opinion. Lots of them make noise like that with no other ill effects.
http://www.por15.com/ This is very good stuff. Also a rust convertor. "POR-15" When using this type stuff, pour out a little bit into a separate clean container like a disposable paper cup and use it out of that, and don't return the used portion to the original container, because getting rust crud in the product can ruin it. Activates it or something like that, I don't know, I'm no paint scientist.
The VIN breakdown is like this: 1 manufacturer 2 manufacturer 3 manufacturer 4 line 5 body type 6 engine type 7 model 8 restraint type 9 check digit 10 model year 11 plant of manufacture and transmission type 12 sequential 13 sequential 14 sequential 15 sequential 16 sequential 17 sequential This is from the factory manual on my 00 OBW; yours may vary.
Tech Manual tranny noise troubleshooting section: [K100] 3-1 DIAGNOSTICS 1. Manual Transmission 3. Unusual noise comes from transmission. NOTE: If an unusual noise is heard when the vehicle is parked with its engine idling and if the noise ceases when the clutch is disengaged, it may be considered that the noise comes from the transmission. (a) Insufficient or improper lubrication. Lubricate or replace with specified oil. ( Worn or damaged gears and bearings NOTE: If the trouble is only wear of the tooth surfaces, merely a high roaring noise will occur at high speeds, but if any part is broken, rhythmical knocking sound will be heard even at low speeds. Replace. ===== Check the fluid level!
Ping
2X2KOB replied to a095208's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Find one in every car... You'll see. -
Perhaps instead of "dead" I should have said "discharged" in reference to the battery. Most likely it will charge back up when the defect is corrected. You can make sure all the fuses are good and that the battery cables and big red wires under the hood are in good shape and connected properly. I don't know if there's any fuses in the charging circuit, but I doubt it. If you jump it to start it, then turn the headlights on, then remove the jumper cables, do the headlights dim a lot right when you disconnect the jumper cables? If so, this would indicate a bad alternator. edit spelling
