Everything posted by 2X2KOB
Ping
2X2KOB replied to a095208's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
He's right - don't accept this, it's not right. Keep taking it back until they fix it. The least they can do is throw in a new knock sensor, or plugs, or something. I've had the same problem for the last five years on a 2000 OBW, the dealer said "use better gas". I should have pushed him to fix it then, but I didn't. I'm going to try cooler plugs and see if that helps. Note that the BOOK says it should run fine on 87 octane, but we have to buy 89. I don't like this much. -
Do you have a voltmeter/DC ammeter? If not, perhaps a trip to the local Autozone or equivalent, where they have things like battery and alternator testers and people who will use them for free, would be advisable. I'd say you have at least a dead battery, and possibly a dead alternator or a short somewhere that is draining the battery. If you have a voltmeter/DC ammeter and know how to use it a little bit, we can discuss further driveway troubleshooting steps for happy fun good time electical success story! Also please include year/make/model/car details...
If it was mine, I think I'd like to see what ALL the codes were. Next, I'd get the wiring diagram, and make sure the wiring between the OBDII port and the ECU was good. If that wiring checked out, then I'd probably get a junkyard ECU to swap in and see what happens. Like Wayne said, that's too many codes to be believed, and the fact that they don't go away when the battery is disconnected also points toward a funky ECU.
Engine type?
2X2KOB replied to 2X2KOB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The VIN breakdown sheet that I got from techinfo.subaru.com shows a single option for the engine code, and it's a "6", which matches my VIN. Guess that clears that up. I'm glad to hear that the head gasket problem should be cured on this engine. Thanks - -
Technical Service Bulletin 1510401 addresed this wind noise problem on some of the Outbacks. I think the fix was to add some vinyl tape to cover an open slot on the bottom side of the crossbars. Sorry I can't find a direct link to the real TSB - It's probably in alldata.com or techinfo.subaru.com $omewhere. I'm pretty sure I saw it on mycarstats.com.
Engine type?
Good tip there - Thanks -
2000 Legacy Outback wagon, SOHC 2.5, 4EAT On http://www.partsamerica.com, when selecting the vehicle/engine type, I get two choices for the engine: H4 2.5 Liter FI EJ252 2458 cc VIN 6 -or- H4 2.5 Liter FI EJ251 2458 cc How can I tell which type is the right answer? What's the diff between an EJ251 and an EJ252? Is this the series I and II 2.5's I've been reading about? Does this mean that some 2000 OB's came with the DOHC 2.5?
It is my personal opinion that regular antifreeze changes can help one to avoid the headgasket problem, and other radiator problems. I like to change it every two years, dilute 60/40 it with distilled water, and use the coolant treatment from the dealer, which costs less than two bucks. I don't know if this will prevent head gasket problems, but it certainly can't hurt.
It doesn't make any sense to me to attribute a "lack of power" to a defective clutch, unless it was clearly and obviously slipping. Have you gotten a professional opinion and/or estimate? There should be no real difference in wear symptoms or behaviour between a hydraulic and a mechanically actualted clutch.
