Everything posted by 2X2KOB
Newbie
2X2KOB replied to Rob Kuhlman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That's right, AMM, ECU, CPS, ETC. Good stuff. Subarus are interesting. We have two now. I like the AWD and the interior quality, but the transmissions are WAY more expensive to replace. And there's too many wires and computers. -
I just checked the book on my 2000 - it says 105,000 miles for the timing belt change - however, now is the perfect time to change yours, because it hasn't broken yet. Optionally, you can change the water pump and cam/crank seals as preventive maintenance, and reseal the oil pump, and check all the idler pulley and tensioner bearings for grinding noises. A search in the forums on 'timing belt' will provide lots of info.
Newbie
Welcome Rob! Righto - the late 90's Phase 1 DOHC 2.5 is not the most highly regarded engine. BTW, it's not like you came in not knowing anyone - you sold me some 240 fuel injection parts last summer. At some point in the future, my daughter is going to appreciate that. Mark -
The owner's manual doesn't specify the fuse size. Use a 10, 15 or 20 amp, any of those should be OK. Owner's Manual says: NOTE (If your vehicle is AWD with automatic transmission) Before driving your vehicle with the temporary spare tire, put a spare fuse inside the FWD connector located in the engine compartment and confirm that the Front-wheel drive warning light comes on. The all wheel drive capability of the vehicle has now been deactivated. After reinstalling the conventional tire, remove the spare fuse from the FWD connector in order to reactivate all wheel drive.
Not sure on your '96, but on the '00 it's something like: press on the belt midway between the crank pulley and the alternator pulley with a force of 10kg (22 lb) and verify that the belt deflects as follows: replaced: 7 — 9 mm (0.276 — 0.354 in) reused: 9 — 11 mm (0.354 — 0.433 in) I generally SWAG this measurement. Also, if it squeaks, it's too loose.
