Everything posted by 2X2KOB
I typically get 370 miles out of 14 gallons in the 00 OBW. That's about when the light comes on. The owner's manual says the tank capacity is 16.9 US gallons. So with these numbers you could expect 61.86 miles after the light comes on. I have found the light to be consistent and repeatable. Is that redundant?
Lots of people have done this. Check and be sure that you didn't drain the front differential! The dipstick for the front diff is on the passenger side on a North American car, and the dipstick for the automatic transmission is on the driver's side below the brake master cylinder. If it was transmission fluid that you drained, replace it with Mobil 1 ATF. In fact, do this every time you change your engine oil and you'll never have a transmission problem. You should get just about 4 quarts of ATF out of the transmission pan when draining, so it makes a good partial change.
But they aren't turning when the car is not moving. No movement, no vibration. I doubt that the axles play any significant part in the physical restraint of the engine/trans assembly, all these loads are taken by the motor and trans mounts. The previous explanation doesn't really make any sense to me, although I'm not going to worry about it too much.
The dealer can run diagnostics on the TCU with the Select Monitor. However, I don't think you have a TCU problem. Both of our 2000 OBW's do this to some degree. I think it's more related to the gradual weakening of the motor and transmission mounts and the gradual loosening of interior parts which vibrate and make noise. I would almost call it normal for this car. Annoying, but normal. Or not uncommon - how about that.
