Everything posted by 2X2KOB
If (when) I get my hands on a new one and install it, I'll take the old one apart and see what's up with the extra wires. This sensor was changed several years ago on the recall, before I got the car. I may have a bad front oxygen sensor or possibly a bad cat, but I want to change the sensor first and see if that gets rid of the P0420 code. Last week I changed the rear oxygen sensor with an OEM replacement, didn't help with the code. Thanks...
No, I didn't get it from a dealer. It was identified and advertised as an OEM replacement, though. The connector I was looking at is located directly below the right side of the air filter housing, and it's a six pin rectangular connector. I'm about as sure as I can be that the connector and harness I was looking at was for the front O2 sensor only. The wiring went only to that sensor. This is strange - I would expect O2 sensor wiring to have four wires, also. The factory service manual wiring diagram shows four wires. The thing that I'm looking at that I think is the front oxygen sensor is screwed into the cat convertor close to where the left and right pipes join together, located right behind the right side inner CV joint boot. Is that right?
I have the P0420 code and I need to change the front oxygen sensor on my 2000 Legacy Outback. I ordered a new sensor from one of the websites, but I'm pretty sure I was sent the wrong part because it had a four conductor electrical connector and the existing part installed on the car has a six conductor electrical connector. The seller said return it, but that's the only part they show for this application. It's supposed to be an OEM replacement, not a generic. Has anyone here replaced an oxygen sensor lately on a 2000 Outback and can you tell me, did it have a four wire or a six wire connector?
Not Again!
2X2KOB replied to BIGBLUE1212's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
On a '97 you'll need a code reader to pull the codes. Most auto parts stores will use their reader to pull codes for you. Seems like this should be an issue you'd want to address to the person who did your head gaskets? -
Two things that spring to mind after an engine removal/head gasket job that could cause rough running/excessive noise & vibration are that the cam timing is a tooth off (although wouldn't the cam position sensor know this and throw a code? Are there one or two of these sensors?) or possibly the exhaust was installed in a slightly different position which is causing it to hit some solid part of the car underneath. The motor mount preload mentioned previously is also a possibility. I wish I could drive that car and see what it's doing, firsthand. Please keep us posted on how things go, we're interested.
