Grubby Paws
  • Location
    Bowdoin
Grubby Paws's Achievements
Newbie
Newbie (1/11)
10
  1. Hmmmmm---I suppose it almost acts like a huge "lean-air" mixture. But it is soooo defined by such a tiny fraction of a touch to the accelerator. As I mentioned in another reply here---it acts so much like it is an electrical sensing of the throttle being moved. But let's say it is that. Is there something else that could electrically trigger a massive air leak---once the throttle was recognized as moving? I believe there is an electronically activated solenoid that allows air to flow and move the EGR. But that wouldn't trigger to full bore would it? I suppose I should look that area over though. Again--thanks for the thoughts. I guess I still have a lot of stones to turn over before I give up on it.
  2. There are some great ideas showing up here. But because I replaced the whole carburetor, with the sensor already installed (from junk yard) and the situation is identical, I tend to be eliminating any wrong sensor setting. I haven't been able to pull any codes out of it though. Or at least last spring I couldn't. I can only get a repetitious flash of 7, which I believe simply meant it was a California emission spec vehicle. And yup---I've checked for air blockage. I haven't replaced the air sensor yet. But again---this is sooooo strange with the throttle. You barely have to touch it. It's hard to believe that I'm even moving the throttle plate enough to matter. Yet I'm assuming the minute the throttle sensor detects this tiny movement---something is electronically signaled and fails.
  3. Good idea on the temp sensor. That might explain why it now stopped while driving---if the sensor went bad and now thinks the engine is still cold. Hence it being back to the cold idle-only situation. But I still wonder where that would be coming from. Also I thought fuel pumps usually ran or quit on Subies. can they have low pressure and idle only> If so---I can check for pressure tomorrow. what range should I be in? Around 35 or 40 pounds?
  4. Have a 92 Loyale with around a 1988 1800 throttle body injection engine. The engine will start and idle, but I can't give it gas. Just the slightest hair-touch of the accelerator and it dies. It started this last spring. I would let it warm up for a few minutes and then it would be fine. It sat for the summer and now I went to get it ready for another Maine winter. It played the same game with me again, but this time decided to die while on the road and going up a hill. It has now permanently gone to only starting and idling, with much effort, but will not take the gas. It doesn't matter if it's cold---or I let it idle and warm up. I took a guess at the "throttle body sensor" and replaced the whole carb and sensor as one unit. Still--it has the identical situation. Had an extra computer--so swapped that too. Still the same. Any thoughts would be greatly appreciated. Thanks;-)))
