schlit
Everything posted by schlit
Unless you have a chemistry degree and understand what the tolerances are, how the catalyst degrades, and the effects on the environment I think you're talking out of your rear.... an unguided guess at best. Sounds like you're just angry at "the man". Sorry. For the record, the fact that most of the posts on this site are by two people is why I don't visit much....as what I've heard from many other Subaru owners.
Just wanted to get some opinions about using a dedicated set of winter tires for the Forester primarily for interstate travel in the midwest and east this winter. I wont be venturing north of Nebraska, Illinois, Ohio, Pennsylvania, but assume I will be encountering some snow. There doesn't seem to be many options for performance winter tires, so I'd probably be forced to use studless tires like Blizzak WS-60's. I guess my question is how poorly do studless winter tires do at high speeds on dry interstate? Will I be kicking myself?
It took me the same amount of time to change the 200,000mi clutch on my Civic SI last year as it did to do a few tune up items on my forester. To name a few, Sub spark plugs and front diff fluid changes were huge PITA's. Foreign cars are packed tight and their parts are expensive. Some items will be easier on a Sub and others on a Honda. I personally feel more apt to work on my honda because of the MUCH better (and about $250 cheaper) service manual, and that there's no VIN guessing game when getting parts.
I think you guys are getting a little out of hand there. From regular maintence to major repairs, Subarus are not any easier or cheaper to work on than Hondas. At least for my 2.5L Forester almost everything is a PITA compared to my Civic, my moms Accord, and dad's CRV. Back to the OP, I wouldn't buy any foreign car with 150,000mi on it if I weren't a do-it-yourselfer and was afraid of paying $500 for a repair.
I've used one before on my daily driver just to get through the winter months so I could replace the joint myself once it warmed up outside. It's a temporary fix that works if you catch the rip before you lose the grease and contaminate the joint with grit. Consider it like driving on a doughnut tire....it'll get you around but it's not something you want to take a 400 mile vacation on.
I wouldn't want to put up with the poor handling of a Blizzak over the entire season just for a few ski trips. I tried a set of Blizzaks one year and thought it was a complete waste of money. I didnt see enough improvement over my allseasons to make it worthwhile unless I was driving in snow/frigid cold more often than not.
I doubt you have much of a case here. They didnt lie to you. The engine "appeared" to be strong. The only thing I see is they didnt state the limitations of thier assessment. You'll try to say they should have been more cautious, but who's to say how many checks they should have performed? What is due dilligence? It will vary from mechanic to mechanic. The engine would have needed rings no matter what, so it's not like they're repairing more than is needed, and they're not charging for tearing it back apart. $1200 sounds reasonable for ring work in your case. I would hang my hat on the fact they didnt properly inform you of the well known risk of head gasket work on a high mileage engine. You need to play the ignorant customer while they're the experts. If they dont budge, you gotta decide to give up the car, fix the rings and take a chance something else is damaged, or drop a new engine in and take a chance it wasn't rebuilt correctly. I sure as hell wouldnt trade it in to them though if you give it up.
I wouldnt recommend CVM based on my inlaws experience. Strike 1: They replaced a cat converter with 80,000mi on it due to a P0420 code without even trying to see if it was just an 02 sensor. Strike 2: On the 10 min ride home from the cat repair, the inner cv boot just above the cat spews out it's grease due to a big gash. CVM called it coincidence and charged full price. Strike 3: They charged my inlaws to put the slime in the radiator...I made them go back and argue that one. Yea, their service techs did all that with a smile, but I think at the same time are not being honest with people.
You can rack your brain over what actually happen, but I'd hang my hat on the fact it failed 15 minutes after taking posession of the car. Any other approach will probably not work. Remember, you probably signed an arbritration agreement so no easy way to take them to small claims court. In my experience, all dealers are shady. Check out the new edition of consumer reports, they did a study on it.
No, it is a waste of money to replace your rear O2 sensor as preventative maintence. What are you preventing? If it goes bad, you will see a cel, but will not leave you stranded. IMHO, replacing front O2 is also a waste of money unless you have symptoms of a bad one. It's not the cheapest part to replace either.
What Year To Get?
schlit replied to 9098's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
My 02 Forester has an external headgasket leak that will need to be replaced soon. The warranty extends to most 2002's, so the problem is still in that year. If I were to buy another $ubaru, (after all it's problems there's no way in hell I would), I would stick to 03's and newer.
