239
Everything posted by Loyale 2.7 Turbo
Suspension improvements for Subaru Loyale
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Suspension
You might find front Shock Absorbers on www.Rockauto.com and also, besides the ones for the Loyale, you can use the ones for the 4 Cyl. Subaru XT as I did. Better load capabilities are gained by using stronger coil springs, and thus means lifting, even a little, due to the increased resistance of the coil springs to get compressed by the vehicle's load. Tempo coil springs in front + honda coil springs in rear is my best bet and has been working awesome on my "BumbleBeast" since decades ago. Kind Regards. -
Already surpassed the 40 years milestone of being with my "BumbleBeast" in continous ownership and, despite that this SportsWagon is looking smaller as new cars around tend to get bigger; I preffer this Yellow noisy fellow over any other car, everyday in any weather condition. Lousy cellphone photo Kind Regards.
- 173 replies
- 1
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
Due to the Photobucket ban, I saved "Offline" versions of my main Write-ups, complete with all their photos, Each writeup were saved individually, inside a compressed .rar folder; which you can Download freely, in the following post, here: ~► The BumbleBeast feel free to leave a "Like" there if you find this info, Useful. Kind Regards.
Great Job, Share photos of your Lifted Subie with this Suspension Combo Kind Regards.
Talkeetna; the offroad 5 lug 85 wagon.
Loyale 2.7 Turbo replied to AKghandi's topic in Members Rides
Usually you will never get rid of your Favourite Project car I'll like to see photos of it. Kind Regards. -
Your Coupe is really Awesome! ... Glad to see you around here. Greetings from Honduras, Kind Regards.
Subaru EA82 to EA82T
Loyale 2.7 Turbo replied to mjqtown's topic in Old Gen.: 80's GL/DL/XT/Loyales...
somehow makes me Sad to see cars abandoned in such way to the elements... -
I Agree completely. As time passed by, the EJ conversion is the most reliable & cheap way to go, if you want / need to swap engines... Kind Regards. -
Timin' Belt Covers.
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thank You! ... it still is running Strong and smooth at the same time, no noisy lifters anymore, at least for this more than a year since the modified lifters were installed. Kind Regards. -
I already obtained the complete Timing Kit but I decided to don't change it yet on this Sorento, until it starts to make noise or until the engine needs servicing. So, I will store the Timing kit for the THETA II 2.4 GDi engine for this USDM 2012 Sorento, untill it could be needed; however I will share here a photo showing the part numbers for each component, as it might be useful in case of someone seeking for such information online: Thanks God the modified Sorento keeps going strong as a Champ. Kind Regards.
You're Welcome! Thank you for Lettin' me know. Greetings from Honduras.
- 190 replies
- Instrument
- Cluster
(and 7 more)
Tagged with:
4x140 to 5x100 bolt pattern adapters
Loyale 2.7 Turbo replied to matts87glsedan's topic in Products for your Subaru
Welcome fellow from Costa-Rica, Greetings from Honduras... ...The same thing here. Yes, you can see how I drive my Subaru "BumbleBeast" with a Redrilled 114.3 Pattern, since the 1990's Decade: ~► https://www.ultimatesubaru.org/forum/topic/174295-reverting-6-lug-to-4x140-then-adapter-to-4x100/?do=findComment&comment=1441832 Kind Regards. -
And everything worked fine, thanks to God:
- 173 replies
- 3
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
Changed all eight old worn Hydraulic Lifters with a set of brand New ones, with their oil filler holes already aggrandized. Changed the old worn valve covers' Seals. Changed both Timing Belts. Changed the worn old Pilot Bearing from the Clutch... ...completely and thoroughly deep Cleansed the Engine Bay and Painted it:
- 173 replies
- 1
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
Once the Lifters were Ready, I had to ask to a local friend who has a small repair shop, his kind help and letting me to pull the engine in its place with his tools...
- 173 replies
- 3
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
My "BumbleBeast" it has being running with Valvoline's "MaxLife" semi sinthetyc multigrade oils; however it ran on mineral multigrade oils in the past and after all these years and miles, I decided to change the Hydraulic Lifters with a fresh set of new ones with their tiny holes already Drilled in order to improve the oil flow to them. The back from a 5/64" drill bit, fits perfect on the tiny holes, but its cutting knives on its other side are wider up to the next size of it, you'll never know how many of these bits I wasted until I found a suitable one that could drill their metal, it is amazingly hard and even tungsten carbide drill bits were wasted by the dozen... so, it is better idea to get the Hydraulic Lifters to a professional lathe shop and let them do that aggrandizement for you, if you can... in my case I done that manually. Then, a deep cleansing of each Hydraulic Lifter were nessesary. Eating your Favourite Snack and Soda will help you to be Patient enough...
- 173 replies
- 1
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
I decided to remove the Engine from the Car for three reasons, one was to do a deep Cleansing and repainting all the Engine bay; other reason was to change the Pilot Bearing from the Clutch, as it became loudly Noisy; and finally I decided that it was time to change the old, worn Hydraulic Lifters with a fresh set of new ones... even change the timing belts is easier outside the car, so I did everything at once. I obtained a set of new Hydraulic Lifters' at eBay: My beloved Subaru "BumbleBeast" has the oil pump and its Mickey Mouse Shaped seal, in healthy conditions, so the noise that the old, worn Hydraulic lifters were doing, was not the TOD ("tick-of-death") sound; the clockwork noise were coming from their normal wear at this age and mileage... As I've read several times, long years ago on these Forum; certain members exposed that the oil access holes on the Hydaulic Lifters' body, are so tiny that with age and usage, the varnish and sludge of these engines could restrict and even block the access of the oil at them, making them to work dry and noisy. Furthermore, experienced mechanics suggested that such small openings on the Hydraulic Lifters' bodies, could be drilled and opened to the next size, in order to minimize clogging and let them get the oil pressure in a better way which may lead to a self cleaning operation. Here's an example:
- 173 replies
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
- 173 replies
- 1
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
So, I did a Double challenge, long term experiment with these Coverless Timing Belts, One challenge was mileage lifespan (to reach certain Mileage) and the other challenge was time lifespan (Endurance in time); and the Coverless Belts definitely Surpassed both challenges by far, with flying colors, way better than the covered ones, due to multiple reasons; but someting to consider is that here, in Central America / Honduras, climate tend to be very Stable and Never Snows; however, the belts were exposed to mud, dust, small gravel, small branches and different fluid spills, even an accidental screwdriver dropage during this more than a decade long test / experiment, everything was Repelled by the spinning belts, even they cleansed by themselves, due to their centrifugal action. You can read Further, see photos and discuss the subject, Here: ~► https://www.ultimatesubaru.org/forum/topic/123470-timin-belt-covers/page/3/#elControls_1408538 Kind Regards.
- 173 replies
- 2
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
Pretty interesting... except for the part when you got hurt. I hope soon you'll be alright and Healthy again. Kind Regards.
Thank you for your Kind Words which I really appreciate. in fact, I just had a surgery on the other Knee too. _____________________________________________________ Greetings fellows, I have Just a Little Update and a simple Question: - Update: Thanks to God, this Lifted & slightly modified 2012 Sorento has been Running Flawlessly, we have done hundreds of errands locally and also too many weekend voyages of hours on highways too, with all the family and even our paranormal Dog involved. The engine runs equally on Super gasoline and Regular Gasoline, despite the low quality of the fuels available locally, I guess the GDi computer adjust the fuel / air mixture on the fly... - Question: as far as I know, the two Timing Chains on this 4 cylinder, GDi 2.4L (G4KJ) "Theta II" engine, are intended to be used during the engine's Lifetime, theres the main timing chain and a smaller one for the oil pump; However, local mechanics has emblazoned the idea of changing them, along their tensioners and related paraphernalia, somewhere around the 100 K or 150 K miles, depending on age and usage. The user manual is not clear regarding the subject. So, what is the best interval to servicing the Timing Chains on these engines? Any information / experience \ suggestion about this, will be welcome. Kind Regards.
Also I'm doing the same, since 1985 However, he has everything to go to the dark side EJ route already, So I wish the best luck. EJ engined old subies feels like another car, by the way... Kind Regards.
