235
Everything posted by Loyale 2.7 Turbo
Kia Sephia Sporty
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Non Soob Cars and Bikes Discussion
The "KiaStein" featuring Four Disc Brakes, Stops much Faster during Panic Braking, using less Space and Without Lockin' the Wheels too Hard. The Front Calipers: the Rear Calipers: -
Kia Sephia Sporty
Immediately I noticed two things: ► Increased brake Pedal travel: I was expecting that, due to the increased size of the chambers for brake fluid at the rear Calipers; so that is "Normal" and that was the Reason why the Kia Engineers increased the Bore of the Master Cylinder from the 7/8" used on the Rear Drum Brakes' Setup, to the 15/16" used in the Rear Disc Brakes' Setup. In my Case, despite that I increased the Master Cylinder's Bore to 1", the increased brake Pedal travel is Noticeable, now the Pedal went back to "Normal" because it was pretty Tall with the Rear Drums Brakes still in the Car. ► Increased Sensibility on the Brake Pedal. Now, the Pedal Features a Great Sensibility for Modulation of the brake force / Stopping Power, wich means that the first half of Travel is for Slow Down and you can modulate how fast you want to do that; but the Second Half is for Braking: Stopping Fast. So, the Pedal & Brakes Behaviour is just like a Brand New Car coming from the Dealer... The Pedal Travel is Adequate, the Modulation is Great, and now the Whole Car stops Super Quick, almost without Lockin' the Tires. (Tested several times on Dry Pavement and Dusty Roads) the Danger from Locking easily the Tires during Panic Braking, is Gone! -
Kia Sephia Sporty
Yesterday (Friday) I almost finished everything, because I had to fix a Couple of things more that has nothing to do with the Brake System, such like a Bad Starter and a couple of Engine Mounts, pics soon. Today (Saturday) everything was finished early morning, then I first washed the car Clean, and went to do the Tests; I went alone and initially I used the brakes Slowly, to let the new parts to settle as they should. -
Kia Sephia Sporty
This is what I did: I fabricated an extension bracket using a piece of flat stock modified to use the existing clips, and I welded it in the Best position that such thing could be. Let me Show you: Left Side: Right Side: -
Kia Sephia Sporty
To chose between the K2700 one and the Rio One: That was the Dilemma. The Salesman at the Aftermarket Parts' Store, was very kind and let me try the Rio flex line there first, before buying, so I went to test it on the "KiaStein" and I noticed that if I don't attach the Flex Line to the Shock Absorber, there is more than Enough Total Lenght to the Flex Line for Working Safely, as it Should; But I need to "invent" something to Hold the Rio's Lines, instead the Shock Absorber's clip. The K2700 ones cost Twice the Price of the Rio ones, and also I would not be able to use the Shock Absorber's clip with them... So, I Purchased two Brand New Rio's Flex Lines and went home, thinkin' about using -maybe- the Clips that held the Old, Removed Parkin' Brake Cables, modified to Hold the New Flex Lines in place. Tomorrow will be another Day... I had Enough for Today. Kind Regards. -
Kia Sephia Sporty
Also I Found that the Flexible Brake Line, Kia Part Number 0K30A-43-980E which belongs to the Front of a '00 ~ '01 Kia Rio, also is almost identical to the Sephia / Spectra one I carried as Sample; it even has the placement for the part that holds it to the Shock Absorber's body at the Same Lenght; it also has the same Diameter of ⅛" and identical end fittings; plus no coil spring. The only Difference is that the Kia Rio's one, measured exactly 2" less in Total Lenght, from the part that holds it to the Shock Absorber's body, to the mere Caliper. Here is a Photo of the Kia Rio's one: -
Kia Sephia Sporty
At first, I found what seemed to be a Direct Replacement somehow: ► the Same Total Lenght of 22", ► the same Diameter of ⅛" ► identical end fittings. I took with me a short 10 mm X 1.0 pitch screw to do tests and the results were Perfect. The Flexible Brake Line, is for the front of a Kia Frontier (K2700) 4X4 Truck, let me show you a Comparison Photo, taken with my Cellphone, that K2700 Flex line, next to the Sephia's / Spectra's Sample I have: The only differences between the Flexible lines were two, the placement for the part that holds it to the Shock Absorber's body is at different lenght, and the main part of the K2700 one is covered with a protective coil spring. -
Kia Sephia Sporty
I already knew that I would face issues like this with used parts, it is normal; so I started to search for suitable replacements today. It took me all day long, but seems like I solved the Problem, let me Explain: First I went to many Junk Yards hoping to find a similar one with no avail; then I searched among many aftermarket parts' stores, there were so many stores, that I almost used half tank on my Subie, goin' from one place to another; 'till I ended at the Aftermarket Parts Stores' District, which is a Huge portion of the Downtown of "Comayagüela" City, dedicated only to car parts... there are hundreds of stores in all sizes & shapes. Let me Show you What I've found: -
Kia Sephia Sporty
The Original Flexible Brake Line (Hose), has Kia Part Number: 0K2A-24-3810 ending with an "A", "B", or "C", the end metallic fittings are like Follows: ► To the Car's Brake Lines side: Female thread of 10 mm x 1.0 Pitch, with Concave (Flared) Seat. ► To the Caliper side: Banjo Fitting with 10 mm opening for Banjo Bolt, it has a Hook on the upper side to avoid movements that might get loose the bolt's clamping force. -
Kia Sephia Sporty
Now, the only problem I'm Facing, is with the Rear Flexible Brake Lines, those rubber and nylon Hoses were OK, but after Cleansing their metal end Fittings, I discovered that they were Rusted, to the point that even I punched an ⅛" hole during the cleaning procedures, as you can see: -
Kia Sephia Sporty
Right Side Before... ...and After! -
Kia Sephia Sporty
Left Side Before... ...and After! -
Kia Sephia Sporty
Finally, thanks God, I Got Rid from the Rear Drum Brakes Also, there lies the old Parkin' Brake Cables. -
Kia Sephia Sporty
I Also Cleansed & Painted the Front Calipers: -
Kia Sephia Sporty
The Painted Rear Calipers: -
Kia Sephia Sporty
The Painted Wheel Hubs: You can see the Caps and the Screws also Painted, on a Cardboard in the Background. The Painted Spindles: -
Kia Sephia Sporty
Finally, I had the chance to park the "KiaStein" enough time to do the Rear Disc Brakes' Swap job. First I started by Cleansing & preparing everything for painting, using High Temp Ceramic anti-Rust Paint, which I had some Leftovers from my Subaru "BumbleBeast", in Yellow & Black. I chose to use the Wheel Hubs from the Drum Brakes, as their Ball Bearings were in Better Shape; the only difference between them and the ones for the Rear Disc Brakes' setup, are the small teeth on their inner side, to be used for the ABS Sensor; which will not be used at all, since the "KiaStein" doesn't have ABS Brakes. -
air intake assembly for EA82
Loyale 2.7 Turbo replied to makermk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Post Photos of the Carburator on your EA82, so we could help you to identify it. Kind Regards. -
1988 Subaru GL exhaust
Loyale 2.7 Turbo replied to Yagster's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't know exactly the inner size of the original exhaust pipes on the EA82's, because I removed them more than two decades ago; but seems to be a little less than two inches; I bet it is around 1¾", and they have a Heat Shield in certain areas. Do you want to change the Whole Exhaust or certain parts of the Pipes? My Weberized EA82 Subaru "BumbleBeast" Runs with same full 2" from engine to the tail pipe, since year 1993, as I explained on my Build thread with Photos (Link at my Signature). No pre Catalytic nor catalytic, only a "Y", a straight pipe and a simple muffler, and it never Backfires at all. Kind Regards. -
Welcome Alexander! / Добро пожаловать Александр! Could you Post a Photo of the Engine on that RX? / Не могли бы вы опубликовать фото двигателя на этой RX? Kind Regards. / С наилучшими пожеланиями.
- 420 replies
- Loyale 2.7 Turbo
- JesZeK
- (and 8 more)
Australian side corner lights EA82
Loyale 2.7 Turbo replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Those also were available in the LADM Nope on the Wagons nor Sedans, but Yes on some of the XT6, as far as I Know. Kind Regards. -
Kia Sephia Sporty
Finally, the local Kia Dealer gave to me Both Backing Plates, which was the Last Thing Needed to Start the Rear Disc Brakes Swap, onto my Wife's "KiaStein" Despite that Gottacruise sent me a brand new set of Ceramic brake pads for the Rear Discs, I Purchased another brand new Set of brake Pads, because I wanted to have a Spare already on my Shelf, making use of having already a Sample in my Hands; to be Sure by the way, that those are available, here. Now I know what I'll be doing the upcoming weekend... Kind Regards. -
I Cured Completely, similar symptoms on my Wife's car, which is Automatic, by pouring a full can of Seafoam's "Trans-Tune" on the old ATF and driving one hundred miles with it, prior to drain it and pour fresh ATF back... also I add half pint of Lucas ATF additive, for smoother shifting. You must be aware how the different kinds of additives, affect the Differential in the long run, on those Transaxles that shares the ATF as Lubricant for the differential. Worth read this small writeup: ~► http://www.ultimatesubaru.org/forum/topic/148220-automatic-transaxle-lubrication-the-differential/ Kind Regards.
