239
Everything posted by Loyale 2.7 Turbo
Well... I Removed the Bulb on my "BumbleBeast" because the Light was permanently lit since I removed all the Smog Stuff, when I did the Weber Carb swap. I'm Glad to Drive a Weberized EA82!
help with new weber on ea71
Loyale 2.7 Turbo replied to dickdirty's topic in Historic Subaru Forum: 50's thru 70's
I Run my "BumbleBeast" with 140 in Low and 162 in High on a Weber 32/36 Carb, that is the best balance I could achieve between Power and fuel consumption in a 1.8L engine used from the sea level up to 5K feet without issues nor tuning; I guess that for the 1.6L engine, 120 in Low and 140 in High will be sufficient. Kind Regards. -
Thank you for clarifying... Kind Regards.
I've got a brain teaser for you.
Loyale 2.7 Turbo replied to Steve W.'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, I Agree ... ... We need a "Like" button here. But one Question: have you changed the Oil viscosity? -
Something interesting that I want to Share is the Fact that all that three bad things that Happen in one Day, ended being Good Luck somehow ... ... let me Explain: ► The Fact that the Distribuitor's Module failed in the Morning of a Good Weather Day, was Good Luck; it could failed in one of my many many Night trips and here rains very frequently... so it could happen in an even much worse scenario. ► I was planning to do a Rear Parking Brake (e-Brake) Retrofit on my "BumbleBeast" since long time ago, but never had the Time to go Hunting for Parts to local Junk Yards (Called here ~► "Yonkers"), also the subie was working Fine; but since I was somehow "Forced" to search for the Ignition Module, by the way I managed to search for the parts for the Rear parking brake (e-Brake) Retrofit at the same time; and I did it! ... ... the Retrofit is successfully done, more info, ~► Here. ► Also I found many other useful subaru parts ► The bank refunded my money. ► The Ignition Module that came from the Local Junk Yard keeps working flawlessly; so I decided to let it stay working there, and now I have a Brand New Beck-Arnley spare ignition Module in its Box, which I haven't had when the problems started. So, somehow it was a God Blessing that day! Kind Regards.
Nice Pictures, Thank you for Sharing. This one does look like a Place in my Country, somehow... ...well, the Mountains and the Pinewoods are very similar here. Gotta Love those Landscapes. Kind Regards.
Your Subie looks Precious!!! ... ... I Really Like it and the Clean EJ Swap job done; also I Like the Aluminium tanks, does fit Perfect the Engine Bay. Could I Ask more info about the Battery Relocation? Does the car still has a Working A/C? ... because I see the Lines... Kind Regards.
The Oil Pan is the Same between EA81 and EA82? ... That's New info for me, I have never noticed that. Thank you for Sharing. Photos Please! ... ...
88 GL Wagon speedometer issue
Loyale 2.7 Turbo replied to TomRhere's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That is Good advice, but if you don't find oil on the Speedo cable, This: Happened to me once, in other car -non Subaru- I only cleaned the Gears and used a very small amount of 3-in-1 oil, and solved the Problem. Kind Regards. -
77 Nissan 280ZX independent rear diff swap
Loyale 2.7 Turbo replied to torxxx's topic in Subaru Retrofitting
There is another board member interested in the same idea, while I was writing to him about Datsun differentials, I found this interesting info: ~► http://datsun1200.com/modules/mediawiki/index.php?title=R160_Swap ~► http://www.franavehicles.com/diffsminispools.html -
EA82 sub-model question
Loyale 2.7 Turbo replied to glcoupeguy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, those Specs vary... that is the Reason Why I asked to the original poster, More details about the Old engine and the new engine, so we could help him in a better Way. Maybe he could upload here Pictures of Both distys, it will be even Better. Kind Regards. -
Lubricants & Additives / Myths & Reality
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Shop Talk
Thank you for that Great information, also I Agree about to avoid PTFE additives. I've Not poured Moly on my "BumbleBeast" yet, but my Wife's "KiaStein" has it and the engine runs smooth, but I believe it is too soon to make an statement about it. I Already purchased a Can of Moly for my BumbleBeast, I'll pour it in the Next oil change. Kind Regards. -
There are some USMB Members who professionally Build Lift Kits for Subarus, both Old School and Newer Gens. I personally purchased a 2" Lift Kit (For the Front only) from SJRLift.com, His owner, Scott (Screen Name: Scott in Bellingham) does Awesome Kits and I don't have any complain about the Lift Kit. Also, many others, such like Highguys, BOSS, etc... I've read good references about them I've seen Lift kits for Foresters, ~► Here. Kind Regards.
Aloha no, all from mtsmiths
Loyale 2.7 Turbo replied to mtsmiths's topic in Meet n' Greet. Your USMB Welcome Center
Sounds Awesome! ... ... Here in my Li'l Central American Country, I've seen Many USA Citizens traveling from USA to Panama, and even to South American countries, such like Peru or Argentina... in Motorbike and Bicycles... Could you Post some Photos of your Travel? Kind Regards.
