235
Everything posted by Loyale 2.7 Turbo
Kia Sephia Sporty
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Non Soob Cars and Bikes Discussion
Since the Flush & Cleansing, the Auto Trans on my Sephia worked smoother than ever, but I Noticed that the Speedometer Needle is Wigglin' and sometimes it Drop to Zero when the Car is Still in Motion at Cruise Speeds... That makes the O/D Light to Blink. ...and that O/D Blinking makes the 4EAT to Shift too soon or too Late Sometimes. Since there is Not enogh "Clear" info or Pictures for easy understanding the Sensors Question on internet, I did my own Pictures and here comes my Guide; I Hope it will Help many People with Same Problems. -
Kia Sephia Sporty
It is Electronic, so it Shall Not wiggle at all. I Did not removed any amount of ATF Oil from the 4EAT before to pour the Seafoam: I Poured it over the Old ATF so it was Overfilled, but that amount only lasted for Fifty Miles. The Followin' Picture shows you the Metal Chunks that came of the Flushed 4EAT along more dirt, gum, barnish and mud: -
Kia Sephia Sporty
Avoiding Electrical False Contacts. If you look behind the Radiator, at the driver's side, next to the Batterie's Base, you will see the two main electrical plugs with the Transmission's Wiring. One of those is Wide and is above the other, this one is wider and is for the Shifter / Gear Selector. The smaller one, which is Squared and located in a placement under the other, is the one that could be the Culprit of the Transmission's issues, because it is the Link from the internals with the Computer, for processing the Speeds, Signals, etc... I marked it on the following Photo, as the "Seven Wire Plug" see: In Short Words: If this Plug develops an Electrical False Contact, will cause to the Automatic Transmission to Shift Erratically / Stay in Neutral 'till you press the Gas Pedal, and display a Blinking O/D Light + Check Engine Light in the instrument Cluster. Usually this Plug gets Loose, Dirty and / or Breaks, which lets it develop such Electrical False Contacts... So, I carefully removed that Plug for inspection and did a complete Cleansing to both ends. I used Electrical Contact Cleaner in a Spray Can and a clean Soft Brush. ► Cautions! ... If you want to service the Electrical Parts on the Automatic Transmission, this ideas could be helpful: ♪ That plug has a Plastic Tab that usually Breaks easy, and it needs to be Lifted, to let you pull that Plug, so lift it slowly 'till you can remove that Plug. ♫ Wait 'till the Engine is completely Cool prior to place your hand there, it get extremely Hot and could be Dangerous. ♪♫ Don't Forget to Disconnect the Battery, prior to start these Procedures. Disclaimer: Use all the ideas / information \ photos I post, at Your Own Risk. -
Kia Sephia Sporty
The Cleansing Procedure Worked... Let me Explain: I Drove my Wife's Sephia two days with the SeaFoam Trans-Tune, but only for a total of Fifty Miles, I Drove it on 1st Gear only for ten Miles, then on 2nd Gear another Ten Miles, in Slow Traffic, The Rest where Driven on Highways at Cruise Speeds. Then I Went to Remove the Oil Pan of the Transmission while the Car was Still Hot at its Normal Operatin' Temps. I Cleaned both Metallic Filters and everything I Could clean there with Kerosene; and I had to Say: Holy Cow! Why: I Found around an Ounce of Metal Chunks... Some of them where very Big like a Bean, and there was Metallic Dust on the Residues; also the the old ATF Mixed with the SeaFoam Detergent, came Plenty of Nasty Lookin' Muddy and Greasy appareance. The Thing Looked more like a Dirty Gelatine than ATF oil... ... I only could remove a total amount of Four complete Quarts of Oil, from the 5.7 that the 4EAT Trans uses... So after Closing the Trans with both Filters already Cleaned, I Poured four fresh Quarts of Valvoline ATF oil. The Results: That thing Drives Smooth as Silk, is Really unbelievable how the Trans has Smoothed like That, because I already was thinking (before the problem happened) that the Auto Trans on the Sephia was Smoother than many others I've drive, but now I cannot "Feel" the Gear Changes, only I Hear the Engine doin' Rpm Changes. But I've Noticed that the Speedometer Needle tends to Wiggle at Slow Speeds, in example: if I Cruise at 35 Mph on a Street for more than Ten Minutes, I Notice that the Needle Drops for a second to Zero, then it Goes to 35 Mph; and / or the Needle decreases to 20 for a second and then goes Back to 35, while there is No Real Speed Change on the Vehicle. But that Flush I Did seems to work as Magic to Renew a 140,000 Miles old Auto Trans on a Sephia. My Next Step was: To Change the Vehicle's Speed Sensor. That is the one that sends the Vehicle's Speed to the instrument Cluster, so the Speedometer Works and the Auto Trans really Depends on that Reading to measure the Proper Speed to do a Gear Change. -
Kia Sephia Sporty
About the Four Speed + Overdrive Electronic Automatic Transmission (4EAT) on my Wife's Sephia, it started acting some months ago... First my wife Noticed the the Speedometer Needle started to read Lower Speeds than the actual car speeds, in example, the car was runnin' on a Highway at sustained 45 MPH speed and then, without any vehicle's speed variation, the Needle went down to 25 MPH while the car was doing the same speed... Sometimes the Speedometer's Needle was reading Zero while the car was still in Motion... That caused the Blinking O/D (overdrive) Light on the Dashboard. We went on a Weekend trip to a Mountain village in unpaved roads with the Sephia... and I had to do an Emergency U-Turn and Run Fast over Rocks, and that car Handles AMAZING on such hard Conditions, the Poor car suffered constant vibration for around Half Hour and Nothing got Damaged, no Shock Absorber, Coil, Steering Part, Brake, nor a Rubber... But the O/D light still Blinks and the Check engine came On along that. Since the Automatic Transmission is the Original on the Sephia and it has 140,000 Miles (the Spectra engine on it, only has the Half of that Miles) and I Doubt that the previous owner ever changed the ATF Fluid; (I changed it when I Purchased the Car, I just used Chevron ATF.) I Imagine that there should be lots of greasy, Muddy Buildup, Gum & Varnish... The Overdrive button on the Shifter, Still Works! ... ... Because the Transmission downshifted when I pressed the O/D button, and it Returned to Shift Up when I pressed the O/D button again; like if it where working Normally... Now that's Weird... Because the O/D Light continued Blinkin' and the Speedometer (the Low reading needle) Dropped to Zero when I Was Cruisin' on the Highway at 45 MPH... for about ten Minutes and that Thing suddenly started to Show 5 MPH... Then Returned to Normal Reading at 45 Mph... Hhmmm.... So, beside the Dirt on the Trans, I Suspect on Loose Wiring / Bad Solenoids \ Bad Sensors... but I started to Clean the Dirt first. So I scheduled a weekend to Clean it the Best way I Could without removing the Trans from the Car. My Idea was: if that deep cleansing Fails, I will remove the whole Transmission to do a better inspection of its internals. I went to our Local NAPA Store and I obtained a Can of "SEAFOAM Trans Tune" and I poured it all (a pint) to the actual ATF; then I Drove the Car for an Hour on hard "Stop'n Go" Traffic. We Drove it with the Seafoam Detergent on it for a couple of days. After that, the next weekend I removed the Transmission's Bottom (Oil Pan?) to Clean it all with Kerosene; and to Clean (wash) the two metallic ATF Oil Filters it has inside. -
Kia Sephia Sporty
Yes... Remember that Ford has agreements with Mazda and the Kia Company usually remake Mazda Products ... so Being based on a Mix of the Ford Scort / Mazda Protegè and the Lotus Elan, the Kia Sephia / Spectra is somehow a great car for its little value... I Know it has thin sheetmetal and could easily have dents... but is a Highly underestimated car for its real being. Yes! ... it is Automatic, it has the 4EAT transmission: Four Speeds plus Overdrive. Did you Know that the 4EAT that first appeared on the Subaru EA82 GL10 is not a real "Subaru" Transmission? ... it also appeared on the Nissan Pathfinder from the Same era... by that time Subaru and Nissan were somehow Partners... But the 4EAT isn't a Nissan transmission either. The 4EAT is Designed and Patented by JATCO (Japan Automatic Transmissions Company) and they changed some specs as each car maker asked. Want more Info & Technical data? - For Subaru 4EAT, click ~► http://www.northursalia.com/techdocs/pdf/transmission/4eat.pdf - About JATCO: ~► http://en.wikipedia.org/wiki/Jatco - More info on Wikipedia: ~► http://en.wikipedia.org/wiki/List_of_Subaru_transmissions#4EAT Kind Regards. -
Oil Catch Can in EA82
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No, Absolutely Not. If you read carefully, the First pic explains that it must be Placed between the Driver's Side Head and the PCV on the intake. The Full explanation is, ~► Here. Kind Regards.- 42 replies
- Oil Catch Can
- PCV System
(and 8 more)
Tagged with:
Kia Sephia Sporty
The Second Gen T8D engine that came originally on my Wife's Kia Sephia and the Third Gen T8D engine from the Kia Spectra are almost Identical engines. The Spectra (Third Gen T8D Engine) has one Hp Less than the Sephia (Second Gen T8D Engine) Engine, but it has eleven more ft lb Torque. But the Third Gen Engine is Built with Better Quality Materials, Better Castings and also has an improved Design. In example: the PCV Valve on the Sephia's engine is Plastic, mounted on a Rubber O-Ring directly to the Head's Cover; while the PCV Valve on the Spectra's engine in fully Metallic, threaded and directly screwed to the Head's cover, as you can see in previous posts of this thread; also the Screws that holds the Oil pan are Nº 6 on the Sephia's engine, and Nº 8 on the Spectra's engine; etc... Funny Fact: Yamaha has a "T8D" engine designation, designed for outboard small ships. The Main Advantage gained with the Swap is to have a Very Low Mileage, better Built engine which doesn't leak or drink a single drop of oil nor coolant, plus it doesn't blow any noticeable smoke, unlike the huge cloud of smoke of the previous one, due to its internals' damage; as shown in the pictures on the previous posts. Driving Differences: Almost unnoticeable difference, because both engines are smooth, easy revving engines! But now the Car Holds the Gear a Little Better on Low Speeds and it has way more than enough power to Pass, even on a Steep Hill Climbs and very Loaded... almost unbelievable Performance for a 1.8L engine ... see the Wikipedia info Below. You might ask: Which was the First Gen T8D engine and in which model did it came? When Kia Purchased the Lotus Elan Design License, They Built the Kia Elan and they Developed the T8D Engine for it, as a Huge Upgrade over the Isuzu 1.6L Engine that Lotus used on the Elan; so the Kia Elan was the Model that came with the First Gen T8D engine; as Follows: ► First Gen T8D engine = Kia Elan. (1995 ~ 1998) ► Second Gen T8D engine = Kia Sephia (Second Gen Model) and Kia Clarus. (1998 ~ 2001) ► Third Gen T8D engine = Kia Spectra (First Gen Model: 2001 ~ 2003) More info on Wikipedia: ~►Here. Please, note the Engine used on the Kia Elan... ...is the Same T8D which is a DOHC 16 Valves Non-interference engine. So my Wife's Kia Sephia still runs on a T8D engine, but the Third Gen of it from the Kia Spectra, which is improved; and that is the Reason why it was Renamed as the "KiaStein" Kind Regards. -
1986 2wd 3door coupe leveling question
Loyale 2.7 Turbo replied to ckgeorge's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If your Subie is 2WD, you can use the 4WD version of the Shock absorbers, because those has the Base for the Coil Spring, welded Two inches Up on the Shock's Body, so they will Lift your ride a Li'l bit. If your Subie is 4WD, you can also use the Coil Springs from the Front of a 1992 Honda Accord in the Rear of the Subie. More info: ~► Here. Kind Regards. -
Kia Sephia Sporty
I Already Swapped a Gen 3 T8D Engine from a Kia Spectra, instead the Gen 2 T8D that came with the Sephia; Look above here, at Post Nº 84. Kind Regards. -
Now my Subaru "BumbleBeast" has a Couple of Weeks driving with the Rear e-Brake and it "Feels" So Natural to the Car; works Awesome and is somehow unnoticeable as a modification... even the Park Brake Light Works: everything works Flawlessly!!! Look for more Photos at my Writeup! I'll Like to know What do you Think about the Retrofitting and the Complete Writeup about that on the Link above. Kind Regards.
- 169 replies
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
Congratulations!!! The Weber Swap Looks Very Well Done, Clean Job!
Kia Sephia Sporty
So, my Wife's Sephia is now the "KiaStein" A Little Update: Do you Want to Know & see what Happened to the Removed, Old T8D engine? I can go further and Show you: I Dissasembled it... ...and Checked its inner parts Carefully... ...Piston by Piston... ...Everything! The Welded Sprocket only took a Couple of SledgeHammer Hits to be Removed... I Decided to Keep the Head, as it was in Good Shape... ...and Guess what I Will Do with the Rest of the Engine? It is on its way to be transformed onto... A Glass Table! ... Like This one: Kind Regards. -
Kia Sephia Sporty
This is the Sephia's original T8D engine (First Gen, says K6-1) when I Just Removed it from the Car: Compare it to the Spectra's (Second Gen, Says K6-2) T8D Engine: And here is a Picture with Both engines and their Differences, so you'll easy Understand how the Swap Worked: The Port Shapes & Sizes are Different: The Sephia'a T8D engine Ports are Oval while the Spectra's T8D Engine's Ports are Squarier and bigger, But the intake Manifold of the Sephia Cover Perfectly the ports on the Spectra Engine: I've Just "Been There, Done That" So I Used my Sephia's old Engine Stuff on the Spectra engine and Worked 100% Well! Now it has more than a Whole Year Working Flawlessly. A Closer View of How the Sephia's Manifold cover the Spectra's Engine: Here Both engines together, the Spectra's one is Inside the Car, while the Old sephia's one is Lying on the Floor: I had to use the Sephia's engine Valve Cover, because the Spectra's engine came without the Oil filler Cap, and the Older one does Not match the New one. -
Kia Sephia Sporty
When my Wife and I Purchased the Kia Sephia, it came from USA to Honduras in Regular shape, but the engine was Blowin' a cloud of white smoke that with time got worse, as you can read about that in prior posts of this Thread. After changing the Muffler with a Brand New one and other minor jobs, we used the kia Normally as Daily Driver without issues but the White cloud of smoke became even worse; the Head gasket was Fine: I Test Compression plus there was no oil in water, nor water in oil and everything was working just Fine. I thought it had worn Valve's seals and the engine was Leaking Oil; so I scheduled a Complete Engine Reseal, but then, after Checkin' everything around... I Found a "Dancing" (Wiggling) Main Pulley, let me Explain: I Noticed that the Main Pulley, that comes at the Bottom of the Engine, was moving almost an inch side by side on each Turn, so I Obtained a New one... ...Thinking that maybe the Old one was somehow, Bent. I started to Change that Main pulley and What an unholy Surprise I Found!!! The Timing Belt's Sprocket were Loose and the Previous Owner (or its Mechanic, I Don't Know), instead of Obtaining it New, or at least a Good used one, did This: With That Stupid Idea of Welding the Sprocket to the Crankshaft, not only the Sprocket wasn't well alligned (Making the Main Pulley to "Dancing" -Wiggling- as it is attached to the Sprocket) but also the Welding Burnt the Oil Seal there!!! So the T8D engine was Leakin' Oil from that seal and the Welded Sprocket to the Crankshaft makes to Change it a Nightmare that involves to Change the Crankshaft and the Sprocket too... First I Obtained a Good used Crankshaft at a Junk Yard, then I Was Searchin' for a Good Sprocket and evertything involved, but then I Realized that the Pulley's Vibration must have "Eaten" part of the Engine's Life with its Vibration that should damaged the engine's inner parts... We continue to use the car as Daily driver while we got enough amount of Money to do a Complete engine Overhaul. The engine was Blowin' White Clouds of Smoke and leakin' oil from that seal, but otherwise it was working Great. That days, my other daily driver, my Subaru "BumbleBeast" Wagon, was in need for brand New two timing Belts, plus tensioners, etc... and we were short of Money & Time. So instead of Doin' a complete Overhaul... I did a Crazy Engine Swap! I Obtained another T8D engine but Second Generation. (From the '03 Kia Spectra, the Sephia came with the First Gen T8D engine) but I Only Purchased the Block along with the Head (Long Block) Already Assembled as it came from Factory, in other Words: my Wallet wasn't enough big to purchase the Complete engine from the Junk Yard, so they Taken off This Parts from the Engine: (Parts Removed from the new Engine, in order to Lower the Price) ► Intake Manyfold complete. ► Exhaust manyfold Complete ► Flywheel. ► Front main Pulley ► Engine Mounts, except the one in front of the Timin' Belt Cover. (The old one was Damaged) ► All the E.F.i. Stuff, including ignition Coils, etc... My Sephia still Ran with its original engine (Blowin' a Cloud of Smoke) and I Went to Purchase the New engine Driving it. The New (to me) engine was Pretty Clean, came from a Spectra with 67,000 Miles; the car was in a Huge rear Crash and the engine was inmaculate, even its oil was Clear. Since it came without intake or exhaust manyfolds, Flywheel, etc... I wanted to Use the ones from the old engine on the New; that way I will be Able to Run the New Engine with the EFi / Computer Stuff from the Old one... and the Swap becomes Cheaper! Here you can see the Spectra's T8D Engine, inside the Sephia's Trunk, as it Came from the Junk Yard: -
Kia Sephia Sporty
My first Posts on this thread, has the Text in Yellow Colour, so they're almost unreadable... so Sorry for that. I Explained why, ~► Here. So I will post a Short version of the Story on those posts, here in the next two posts. -
This Looks Very Nice on the Subie: This thread is Missing Many of the Pictures on the old posts... I would Like to see them... it is a Shame. Kind Regards.
Problem. With loyale
Loyale 2.7 Turbo replied to Craigsti's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This might sound even Sillier, but... have you checked if the Ignition Coil is Receiving Power? -
Yes, it is. Well, it is Baby Blue with a Chromed accent (Vein) ... I guess it was the Sun Light that makes it to look like Cream. I'll figure out how to Change that somehow, someday... Good Luck in your Voyage, Don't forget your Camera! Kind Regards.
R.I.P Roger "Tobias" Roberts
Loyale 2.7 Turbo replied to Skylar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am so Sad to know that, and So Sorry for the Loss... You have my Condolences. My prayers will be with him and his Family. Kind Regards. -
Plug EGR Valve Vacuum? EA82
Loyale 2.7 Turbo replied to JEBalles's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well... The EA82 engine has a faulty EGR design and Subaru knew that, so they eliminated the EGR pass on the Third Gen of EA82 Heads. (There are Three Gens of EA82 Heads, more info & Pics, ~► Here) So, since my Subaru "BumbleBeast" Runs on the Third gen Heads, I just Removed the EGR stuff from the Intake, as you can see pics, ~► Here. And I haven't had any Issues related to the EGR. So I Kindly suggest to let it Unplugged, just close (cap) the vacuum hose that goes to the EGR valve, to prevent a vacuum leak and Try your subie like that for a while; if you don't like the Behaviour, you can either reconnect it or buy a brand new EGR for 70 Bucks... but it worth the Test. Kind Regards.
