237
Everything posted by Loyale 2.7 Turbo
when putting 14's on my gl wagon
Loyale 2.7 Turbo replied to noob2soob22's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I Kindly suggest you to check the off-road section: http://www.ultimatesubaru.org/forum/forumdisplay.php?f=30 There are all your answers for that Questions. Kind Regards. -
Cooler Temp Thermoswitch.
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, I found it! This is the Old original pigtailed Thermoswitch: This is the New one that I Had as Replacement, long years ago: This Pigtailed Thermoswitch has the Part Number: 83052GA041 and it has its Temperature stamped in Celcius Degrees, as we use in Latin-America: 92º C equals to 198º F The other Style: Has the Part Number: 83052GA040 and it has its Temperature stamped in Fahrenheit Degrees: 203º F equals to 95º C- 22 replies
Loyale 2.7 Turbo replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Gotta Love those Stomper Subarus!!! Real 4WD power! Do you Remember the Brat on the Simpson's TV series? -
This is how Both fans Looks Together: Here the Old Subaru one just needs its screws, but is in its original place.
- 70 replies
- Fan
- Pulley Fan
- (and 8 more)
This is How I Bolted-on the New Slim electric fan: I used two thin pieces of metal plate (1/2" wide X 1/8" thick, one on the left side and one on the right side) between the radiator and the fan's mounts to act as a washer for the Screws and spacer for the fan at the same time.
- 70 replies
- Fan
- Pulley Fan
- (and 8 more)
I Went to pick up my Repaired & Repainted Radiator today, yes it had a minor leak due to a minor hit done by the old pulley-driven fan, when it failed... Now it Looks like New!
- 70 replies
- Fan
- Pulley Fan
- (and 8 more)
I Tested the New Slim Fan there, at the Radiatoir Shop... You can see the Original Subaru A/C fan, next to the New slim fan.
- 70 replies
- Fan
- Pulley Fan
- (and 8 more)
When I took out the Honduran-Made double row Radiator, I Noticed that its paint was almost gone and had some scratches, as you can see below: This is how it looked like after being in its place for more than ten years of non-stopping hard work and it still worked fine, but I Took it to the Radiator Shop for Maintenance, so they could check for Leaks and repair if needed.
- 70 replies
- Fan
- Pulley Fan
- (and 8 more)
My 1985 BumbleBeast came Running from California (USA) to my Country (Honduras) that year, My Familiy and I have Traveled All Across Central-America with it; Guatemala, El Salvador, Nicaragua, Costa-Rica and Panama... Always Fully Loaded with 4 or 5 people & Baggage... Something interesting I've found on the EA82's is that the More they Run, the Better they Behave!!! Have you noticed that? Kind Regards.
I Finally Got Lifted! Now With More Vitamins! Pics!
Loyale 2.7 Turbo replied to Vegablade's topic in Off Road
If you swap the Mirrors, please keep their Rubber Base for Me, I'll buy 'em from you. Kind Regards. -
RX 3 door rarity?
Loyale 2.7 Turbo replied to cal_look_zero's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here, a Couple of Threads with Pics, of the... EA65 Coupe: http://www.ultimatesubaru.org/forum/showthread.php?t=75938 EA71 Coupe: http://www.ultimatesubaru.org/forum/showthread.php?t=50229 Kind Regards. -
RX 3 door rarity?
The Local subaru dealer sold some of those Coupes in the 1980's era, I saw one with the Late (Fat Case) EA71. Yes, the Coupes for Latin america and asia came with 1.6L engines, the 1.8 was an option. Kind Regards. -
First of all, You'll Need the 14" Rims ... ... Peugeot (pug) are the usual, for the 4X140 Old-School subaru setup. After that, you won't need to "Play" with the Suspension, unless you want to put Really Big Tires... Then you'll need a Lift kit for your GL. -
Here, The New Fan's Box: Here, the Fan Details & Measurements: and Here, the Fan Characteristics:
- 70 replies
- Fan
- Pulley Fan
- (and 8 more)
Where are RELAYS located?
Loyale 2.7 Turbo replied to benjamachine's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here's a Writeup about how to Swap the Stock Relays for Bosch Standard Relays, that includes their location with pictures: http://www.ultimatesubaru.org/forum/showthread.php?t=90403 Kind Regards. -
Recently, I Went Weelin' on my Lifted "BumbleBeast" here is a Short Video: Let me Know what do you Think about it... Kind Regards.
- 420 replies
- Loyale 2.7 Turbo
- JesZeK
- (and 8 more)
Yes, Pics Please! ... I'll like to see that Thermoswitch, also I want to know if you Wired it to the Stock Wiring... Kind Regards.- 22 replies
1985 I can search for a Picture of the Old Pigtailed Thermoswitch....- 22 replies
Lookin' for a Front Li'l Lift
Thank You, I'm Glad that you Liked it ... ... Your Lifted EA81 wagon Looks Awesome! Regarding the Lengthening job to the Steering Shaft's linkage, this is exactly what I did: Because: However, then Gloyale posted this very interesting information: Taken from Here: ~► http://www.ultimatesubaru.org/forum/topic/153748-steering-extension-length-ratio-to-lift-block/ I edited this post because such information is worth to be Saved for Future References. Kind Regards.- 88 replies
- JesZeK
- Modifications
(and 6 more)
Tagged with:
My Lifted BumbleBeast! -
I Found interesting that No one said on the other Lift Threads, that when you Drop the engine Crossmember (and with that the engine sits Lower on the Engine bay); the Pulley driven fan, found on some EA82's will Hit its surrounding Frame that is mounted on the Radiator! I Know it is Logical... but it worth be written here because someone could forget about that and Damage the Fan. Kind Regards.- 88 replies
- JesZeK
- Modifications
(and 6 more)
Tagged with:
Yes, the Stock one comes with a Twin wires' pigtail connector... (my BumbleBeast came from California, USA) ...the replacement I Obtained at the Subaru Dealer (Long years ago), is identical to the Stock one, but has the Twin spades connector built in because it was for the LADM (Latin American Domestic Market) Specs; the only difference is the Connector itself, the temperatures are the same: Both Kicks on at 203º F and has the same thread & Size. Kind Regards.- 22 replies
Maybe I Can Refine my Question: is there any other (Subaru or non-Subaru) Thermoswitch that is designed to Kick on at lower temperatures than the Stock one, that Fits on my Subie? ... I Need the Year / Model \ Part Number.- 22 replies
