235
Everything posted by Loyale 2.7 Turbo
Loyale 4WD indicator light
Loyale 2.7 Turbo replied to jazzmandolin's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Certain models have a Vacuum activated Mechanism to Engage / Disengage the 4WD ... So I Kindly Suggest you to Check the System starting from the Switch, Replace Worn Hoses and check for loose parts. Kind Regards -
170° ea82 thermostat
Loyale 2.7 Turbo replied to dudesmccool's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hmmm... Well... I Agree with That! I Run my EA82 Without Thermostat since Many Years Ago and I've Noticed other Benefits... but here in the Caribbean tropics it's not Needed: Never Snows. Kind Regards. -
Factory part # for '85 oil filter...??
Loyale 2.7 Turbo replied to starkiller's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I Use This one: Or This One: on my '85 Subaru EA82. -
Idle problem 90 loyale
Loyale 2.7 Turbo replied to SoobDood05's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have you Already Checked for Vacuum Leaks? Those Old Tiny Hoses become Brittle, Hard and Crack easily with Age... Sometimes those aren't Closing very well their Ports. Kind Regards. -
I Run the Front Marker Lights on my Subie with Those SuperBright Leds since Years Ago, They Work Just Great since Then up today. Kind Regards.
Legit Once More!
Loyale 2.7 Turbo replied to lostinthe202's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This: is a Very Good Job, Well Done; The Car Looks like if the Deer Hit Never Happened. I Like that Subie... Looks Very Good. Kind Regards. -
newly redone subaru justy, with pics
Loyale 2.7 Turbo replied to zyewdall's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Beautiful Justy! ... Good Job! -
Bypassing the hillholder
Loyale 2.7 Turbo replied to thebr0wn0ne's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just Disconnect the Cable, it Works. -
Stolen 95 wagon purple
Loyale 2.7 Turbo replied to Yo'J's topic in Meet n' Greet. Your USMB Welcome Center
So sorry to hear about that... I Hope you can get it Back Soon... -
Main fan not coming on? - Fixed (page 2)
Loyale 2.7 Turbo replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I Believe Yes, 'cos those Grounds send the Switchin' Signal to the Relays. I Believe that there could be a Worn Relay... Have you tried to use other Known-Good Relay? ... Also there could be a Short-Circuit Wire. I Kindly Suggest to Start by Switching Relays... Good Luck! Kind Regards. -
Need Help Replacing CV Boot
Loyale 2.7 Turbo replied to nbrown's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No, the Pic isn't Working... Try copy the Pic in its Site / Paste it Here. Or Copy / paste the Entire IMG Code. Good Luck! -
Let me Kindly Suggest you This Writeup, it Might Help: http://www.ultimatesubaru.org/forum/showthread.php?t=118248 Kind Regards. -
My Prayers will be with You...
I'm back, again....
Loyale 2.7 Turbo replied to Frank B's topic in Meet n' Greet. Your USMB Welcome Center
Welcome Back! Yes I Agree! -
1983 1.8l Fuel Injected Tubo Wagon
Loyale 2.7 Turbo replied to tomd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1983 and Fuel injected... is That the EA81T or Does that Ride had an Engine Swap? More Background info is Needed. -
First time Off-roading w/ Wagon
Loyale 2.7 Turbo replied to gokoolab's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Good Lookin' Subie! if you Want the Complete information about Suspension Mods Using Parts from Other Cars, I Kindly Suggest you to Review this Writeup: http://www.ultimatesubaru.org/forum/showthread.php?t=110546 Kind Regards. -
Tom: I've following your Thread and let me Tell you that I Really Like your Red Wagon, its Beautiful! But... ...that comment does Scare me!... Are you Writing about your Wagon or about some Person? in any case I Hope that everything will be Alright Soon... Best Wishes... Kind Regards.
Lookin' for a Front Li'l Lift
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've just Posted this on the "Subaru Stuff Wanted" Area: ~► http://www.ultimatesubaru.org/forum/topic/120332-2-lift-kit-just-for-the-front-ea82-gl-loyale/ I Hope Someone will have the Right Kit for Me.- 88 replies
- JesZeK
- Modifications
(and 6 more)
Tagged with:
The Starter has a Set of Carbon Contacts inside that Wear by Normal Use, once those gets very Worn, they make the Problem you Have: The Starter Clicks Few Times and Gets Worse. I Kindly Suggest you to Take out the Starter and send it to a Service Shop to do its Needed Maintenance, wich includes a New Carbon Contacts' Set and Grease the Bearing. ...or Try to do the Maintenance by yourself: http://www.doityourself.com/stry/engine-starter-repair-how-to-fix-the-carbon-contacts Kind Regards.
