Loyale 2.7 Turbo
    235
Everything posted by Loyale 2.7 Turbo
  1. I Believe that the Owner is the one that Owns this Website: http://subarubrat.com/
  2. I Believe that the Easier and Cheapest solution is This: Those engines are more Reliable than the Turbo EA81... I'll Like to see Pictures of your '84 RX, so Could you Post some? Kind Regards.
  3. Some Missing information here, but let me Guess in Order to Help you: Does that Behaviour happens only at Idle (Needle Jumpin' a Li'l)? or the Needle Goes Up (I Guess) Near the 18V at High RPM's and Lower when RPM's return to Idle? in the First Case: Normal Behaviour. in Second Case: The Alternator's Voltage Regulator is Wrong. Furthermore, You Need to Define "New Alternator" : Was it a New-to-you Alternator from a Junk Yard? or a Remanufactured / Brand New one? If it came from a Junk yard, maybe it was Weak and Just got damaged, like the Older one. If it was a Remanufactured / New one, you must have a Sales Receipt / Guarantee, so you must go Back to the Seller and Ask your Guarantee. Beside that, there could be some Short Circuit on the Alt's Connections that Might be Causing Damage to the integrated Regulartor Circuit. Hope this can Help... Kind Regards.
  4. Me too! Well... That's my Weberized EA82 Engine Hood, I Removed a Lot of Stuff:
  5. Yes! ... Those are Very common here known as "Two Steering Vehicles" and are used on Driving Schools.
  6. Why does anybody Restore any car just to let Rust taken it away?
  7. I Believe Yes, it is... Cylinders got Coolant / Wet Sparkplugs. I Had that issue when I Did the Weber Swap in my EA82 long time Ago... Then I just cranked the engine with the Gas Pedal at one half, many Short times, until it Started Roughly... once it Revs and gets Warm, it went to Normal again in about ten Minutes... ...and a Huge Cloud of Smoke came from the Exhaust pipe.
  8. That Symptoms makes me Think about a Worn ignition Coil... So I Kindly Suggest you to Check (Carefully) if it Overheats during the Next time the Engine Shuts Down. Also I Never Heard about That Man: Good Luck!
  9. No Problem I Know that there's not easy to Find Old information accurately on internet... But Lots of Sites trend to not only say the Bogwards-Subaru Conection on the Engine Design, but also in other Engineering. In Example: Here is a Great Website with Lots of information and Technical Data about the Subaru 1000: ~► http://http://www.uniquecarsandparts.com.au/car_info_subaru_1000.htm This is an Extract of the Massive Article: Kind Regards.
  10. Just Place it on the Ώ Ohms Position to Test Continuity; So when you touch both Multimeter's pins Together, the Needle Goes Up all the Way (Or the Unit emit a "Beep" depending on the Model) That's Continuity. Then you just Place the Multimeter's Pins in Both Sides of the Fusible Links and See if it has Continuity. Kind Regards.
  11. I Believe that will Depend on How the Cylinder Wall is... Have you Checked if the Pushed Piston did damage it? ... By Seeing the Photo I Don't Believe it could get Damaged, but it Worth to Check that, to Avoid future Problems. Kind Regards.
  12. Hydro Lifters + Oil Leak at the Oil Pump and Tickin' Noise: Seems like your engine's Oil Pump is Sucking Air thru a Worn Seal...
  13. if Everything, including Timing is Allright; then I Kindly Suggest you to Check the Fusible Links.
  14. Have you Read the Post Nº 2 on This Thead? So, if you Follow the Link, at the Third Paragraph's end, you can read: There was Licensing. No Urban Myth at All. Kind Regards.
  15. Yes, You're Right... its a Risk Somehow and an added mess of Hoses. Those Oil Catch cans Aren't for the Average Driver... Thank you Shawn for your Kind answer. Best Regards.
  16. I Already ordered another one and this time I Double Checked that it Really has 5/8" (15 mm) Fittings. This time I asked for a confirmation to the Seller by e-mail Before buy it. I Sold the 3/8" one to a friend who also is mechanic, for his 22R 'yota. Kind Regards.
  17. Just Upload 'em to a free Pics Hosting Website, such as Photobucket, Flikr, Webshots, etc... and then do the Copy / Paste them Here. Kind Regards.
  18. See this Picture, the EJ engine Prototype, based on the EA81: (notice the Single Timin' Belt for both heads)
  19. This is another View of the Arabella's Flat Four Engine: I've posted Before the Relation Between Subaru and the WWU's VRi in the Past, Look at post Nº 359 of this Thread: ~► Here: http://www.ultimatesubaru.org/forum/topic/50983-strange-and-weird-subaru-stuff/page-15?do=findComment&comment=765610 Kind Regards.
  20. People here Trend to be very Friendly, much more if you have Something in Common. Especially if it is an Old-School Subaru! ... you know ... Subarus trend to make Friendly Connections, Somehow ...
  21. But Subaru Still Needed a New Engine and a New Designed Car to Compete in the Modern Market, they Wanted to get Rid of the Aging EA Platform. The creation of the Legacy was influenced by Subaru's desire to Compete with Successful Japanese carmakers Toyota, Nissan and Honda; and the Legacy was Targeted against the Camry, Stanza, and Accord. The Legacy was Considered Mainstream in its Appearance and a Departure from previous vehicles, which had earned a Reputation of being "quirky". So, by the Time when they were Developing the EA82 in Japan, Subaru asked to the Vehicle Research institure, of the Western Washington University, (VRi WWU) to Develop a Brand New Boxer Engine, more capable and reliable than the EA Series. Yes, the VRi Developed Three Engines for Subaru, one Became the Very First Prototype of the Actual EJ Engines Series, the Other one was Powered by Natural Gas Somehow, and the Third one was the EA81D ... Yes, a Diesel EA81. The First Subaru Boxer Diesel engine, that Powered the VRi's "Viking V" Vehicle: as you can Read Above.
  22. Do you Know where Did Subaru Based their first EA engine Design? Yes, is Based on a German car but No, it is Not the VolksWagen. It is the "ARABELLA" made by "Borgward / Lloyd" in Germany. Subaru based its "Subaru 1000" (FF-1 / Star) Design on it. That info was Posted here Before, by Kiwi Subie, as you can Read: ~► Here. But now you can Confirm the Bogward-Subaru Relation in the Official Bogward's Website: http://www.borgward.org.uk/brief_history_marques.htm Read it at the End of the Third Paragraph...
