235
Everything posted by Loyale 2.7 Turbo
86 Subaru GL
Loyale 2.7 Turbo replied to kimgarden's topic in Meet n' Greet. Your USMB Welcome Center
Welcome! A Basic Tune-Up just involves what you Already Wrote: New SpakPlugs : NGK Brand works Best in Subarus and those are Cheap. BPR6ES11 are their Usual Number. Set up the Timing to the Required Degrees... That Basically only needs a Light Gun. New Oil + Oil Filter: Just in case the ones on the Engine are Old. A Carburetor CleanUp + New Air Filter Element: Again, just in Case the one it has is Worn. if you Suspect that the Carb is Dirty, sometimes This Cheap Procedure could Help you to Solve the Problem: In a Near Empty Fuel Tank, Pour a "Carburetor Cleaner" Bottle for Fuel and then Pour Three Gallons of Gasoline: This will make it to be very Concentrated and will Help to Solve Gum & Barnish inside the Carb; Also Grab a Can of "Carburetor & Choke Cleaner" Spray and Use it Carefully as Follows: When the Engine Reaches Normal operating Temps: Shut it Off and Remove the Air Filter Box's Cover, then Spray the Carb Cleaner to the Carb's Opening, but be Careful: That Fluid is Dangerous (Specially to the Eyes & Skin), so you must Read the Can's Safety instructions before Use it. Spray some Shots to the Carb with Engine off, you can Use the Tiny Hose to reach the Deep Openings / Areas... Let it Rest for a While... (at least Half Hour or More to let it Solve the Dirt) ...then the Car will be Rough to Start. Once the Engine started and is Running Normal Again, you must Hold the Accelerator Cable with one Hand to make it Rev at Around 3K RPM's and with the Other Hand, Shot some Short Carb Cleaner Spray Blasts to the Carb. Warning!: Be Sure that you Already Removed the Tiny Hose from the Spray Can and its Nose is Pointin' Right to the Carb's Opening; also that there are no Loose objets hangin' Around the engine when you Doing this, including your Clothes. With Every Spray's Shot, the RPM's will Drop but you must Hold the Accelerator cable in order to avoid the Engine to Shut Off... Let it Back to Normal and then Repeat that some times Untill you Feel that the Engine goes Back to Idle Smooth. That's it! Replace the Air Filter Box's Cover and The Carb must be Half Cleaned: The Deep inside Carb Cleaning will be Done by the Fuel / Carb Cleaner Mixture on the Gas Tank, so Don't Refill the Tank untill it Goes Near Empty, to allow the Concentrated Mixture to Clean up your Engine's Carb & Fuel System... I Kindly Suggest you to Drive it in Low Gears at Higher RPM's than Usual for a While, to Let the Carb Cleaner / Fuel Mixture at the Fuel Tank Clean it Right. But Other items could need Replacement, Such as SparkPlug Wires, Disty Cap & Rotor; Etc... I Kindly Suggest you to Check Everything. Hope This can Help. Kind Regards. -
You Mean H6, isn't it?
Lookin' for a Front Li'l Lift
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
For Easiness... (and Cheapness) ...I'm Thinking in maybe use only Single 1" Blocks to lift the Front, but I'm not Sure how much Axle Stress could that Bring to the C.V. Joints and how much the Alingment could be Affected... Any Ideas?- 88 replies
- JesZeK
- Modifications
(and 6 more)
Tagged with:
Any Posted Pics? ... I'll Love to see That! Kind Regards.
Clutch cable snapping
Loyale 2.7 Turbo replied to Sioux-baru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
...Specially if the Costumer knows Nothing about Basic Mechanics nor Maintenance. -
well, its finally done, i hope
Loyale 2.7 Turbo replied to soobie_newbie67's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm Glad to Know that your Subie is Runnin' like a Champ Now! ... ... -
Meet Stanley the wonder Van
Loyale 2.7 Turbo replied to Subie Gal's topic in Historic Subaru Forum: 50's thru 70's
The Big Subaru Van came from the Subaru-GM Era, so No... No Flat engine There, but also the Beautiful Stanley Does not have a Flat engine 'cos only has Two Cyl... Unless you want to see that Two Cyl. engine as a "Half Flat 4 Engine" Kind Regards. -
Welcome! ... I Like your Lifted Justy, its Nice that you found this 'ol Thread and Resurected it with Fresh info. I'll Like to See Pics of the Undercarriage setup and the Engine. Good Job! Kind Regards.
Could be Possible it is Dieseling Somehow? ... Does it Has a Non-Stock Carb, like a Weber in Example? 'cos those Doesn't have the Cut-Off Electrical Valve.
Despite that the Hill Holder and the Check Valve works on my Subie, I didn't purchased those, because the Proportioning valve is alright, and there's an ancient proverb that says: "Do Not Fix what is not Damaged" Now I believe that I will Erase the Hill Holder, because the one on my "BumbleBeast" is leaky. I disconnected the Cable coming from the Clutch fork to prevent it from leaking and my Lazy solution has worked pretty well, no more Leaks... and I really do Not need the Hill Holder to Drive. Kind Regards.
