235
Everything posted by Loyale 2.7 Turbo
Acura/Honda Lugs on Pugs?
Loyale 2.7 Turbo replied to b88185's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This: is the Keyword: Subarus Screws are 1.25 Pitch, so The Nuts Won't Work unless you Change the Screw too. -
advise on rear shocks and front strut.
Loyale 2.7 Turbo replied to HATCHY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
More info about your Ride would be Great... ...But since this is the Older Gen of Subies Section, I Kindly Suggest you to Read my This Writeup about that: http://www.ultimatesubaru.org/forum/showthread.php?t=110546 Kind Regards. -
Welcome! Holy Cow! ... What a Big Difference! Usually the Same happens in my Country. Well... Reading about your Subie, it seems like it has Problems with the MAF and / Or the Sensors... Have you taken it to an EFi Technician?
it Looks Awesome! I Never Liked their Two-Tone Paint, so I Believe that Painting the Baja as you Did makes it to Look Cool! ... I Really Like it. Could I Ask which Kind of Paint did you Used and what brand of Spray Gun, at which PSi? I Paint using "Sagola" Spray Gun and my Favourite Paint is the Polyurethane Based. Kind Regards.
Could I Ask, What is the Rarest Old-School Subaru Part or Option you've Seen? I Just Found on-line a Nice Hardtop Coupe for Sale in Boston, with Low Mileage and it had some sort of Protective Cover around the Distribuitor, that I've never seen Before. See, its an EA81: The Link for More info about it is This. Have you Seen other Rare Part or Option?
I Haven't time to go to the Shippin' Companies Yet... But I Found this Motivational post:
- 62 replies
Nice '73 1400 GL!
Loyale 2.7 Turbo replied to Mike Kamm's topic in Historic Subaru Forum: 50's thru 70's
Not Hijackin' the Thread but about this: another USMB member came to Central America Driving and back to USA again, See: -
Thank you for your Kind Reply... Now I Understood "Keisters" The Guy that is Searchin' for the Calipers just called by Phone again, asking my Subie's Vin Number... he said that the Salesman needed it to Search for the Proper Part on their Database. I'm Crossing Fingers now... if he could bring those calipers here, I will Avoid Taxes and Shipping Costs. Kind Regards.
Nice '73 1400 GL!
My EA82 Wagon came Runnin' from California to Honduras, New in 1985... -
Fuel Pump on ea71...need help!!
Loyale 2.7 Turbo replied to oleman77's topic in Historic Subaru Forum: 50's thru 70's
Pete, you can do a Simple Test to Address the Problem: if the Engine Runs Great with the Fuel pump Directly Wired to the Battery (Disconnecting the Original Wire) then is an Electric Supply issue. But if the Problem Persist, then is the Carb's Float that gets Stuck closed somehow... I Kindly Suggest you to Try these Suggestions. Kind Regards. -
can I run a msd 6AL
Thank you for your Kind answer... That's New Stuff for me. I Run my EA82 Weberized Wagon with an Accel (Made in USA) SuperStock 8140 High Vibration Coil, that Surpasses the Stock Coil's Output... I've been Runnin' it since some years ago and it works Great, but that MSD Stuff sounds even more Accurate. Kind Regards. -
Meet Stanley the wonder Van
Loyale 2.7 Turbo replied to Subie Gal's topic in Historic Subaru Forum: 50's thru 70's
Not Tryin' to Hijack the Thread, but Sharing info: ...Or you could see them in my Country Streets there are Several Still Runnin' Great, but not in such Showroom Condition. We got the Newer ones too... ...I Believe that is something Related to the USA Safety Regulations. But Canada has them! even the ones with the VW Conversion Shape: Maybe you can bring one from Canada... or are they unregistrable? Kind Regards.
