235
Everything posted by Loyale 2.7 Turbo
One last vac hose to track down
Loyale 2.7 Turbo replied to backcountrycrui's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is a Vacuum Line (3/16" hose) that comes from the intake manyfold and goes back to the Passenger's side fender nearby the area under the Windshield's base and it has the "T" which one of its ends (3/16" hose) goes to the White Vacuum Canister and the other end (1/8" Hose) goes nearby that, to an electric solenoid valve. the "T" main end (3/16" hose) "Powers" the Vacuum activated Air Conditioner Push Button Switches inside, thru the Vacuum Canister; the other end (1/8" hose) goes again back to the Engine Thru that electric Solenoid, to "Power" the Idle Accelerator when the Air Conditioner is Powered ON. I Hope this can Help... Kind Regards. -
Hi Mark, I've not seen your Post Before... Yes, here are still Available Dual Range Transmissions for the New Subaru Lineup, but those are Optional, that costs Money, also I Asked to the Dealer and few Friends who are Mechanics and they Told me that the Gearing Ratio that Subaru Offers here in Latin America (LADM) is the Same that goes to Australia (AUDM) and Japan (JDM) but I'm Not completely Sure about that yet... Also, some the Dual Range Gearbox I have seen on Legacies from the 1990's Decade, does have the 4WD Sticker, not the AWD; just like the one Posted here: (See the Earlier Posts of this Thread for More Pictures) To Find a LADM Specs Subie in our Local Junk Yards is almost impossible, due to two Facts: All our JunkYard cars (and Many Many from the Runnin' ones) comes from the USA, Local JunkYards are Not Allowed to Sell Local Cars. if a Local Subie Crashes and the Owner choose to Sell it in Parts, is the Owner who does that directly, not a Junk Yard. Also, here the People who owns a Subie, Usually falls in Love with them and is not easy to find Subarus for Sale, Specially the Smaller ones, like the Rex and the Justy. But I will be Searchin' for a Good Dual Range Gearbox for your Legacy; I'll Write you a PM as Soon as I Found something. Kind Regards.
- 96 replies
- Dual Range EJ
- LatinAmerican Domestic Market
- (and 7 more)
GL 1.8 Face lift??
Loyale 2.7 Turbo replied to True2Blue's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No tryin' to hijack the Thread but... ...and Central American Countries too, like mine also came carb'd the EJ20. I have lots of info about that, pics and Parts Numbers here: http://www.ultimatesubaru.org/forum/showthread.php?t=101887&page=3 I Hope it can be Helpful. Kind Regards. -
I am Almost sure that your Subie's Problems are Related to a Vacuum Leak, the Idea given by Ruparts to see at the EGR is a Good Starting Point to Check; also other Places can be involved, like the intake Manyfold's Seals at the Heads in example... Good Luck, Kind Regards.
Suspension Improvements For the third Gen Subaru Leone (also known as: DL, GL, GL-10, RX, RS, GT, GTi, ST, Omega, Winner, Loyale Royale, Vortex and even as Isuzu Gemminett II, depending on the Market, but here will be referred to, as the "EA82" for easy reference.) However, since the Second Gen Subaru Leone (EA81 / Brat) uses the same diameter and tall coil springs on the Front, being different on their spring rate and load rates only; you can use the third gen Leone's (EA82) coil springs on the second gen Leones (EA81), also you can use the Alternative coil springs from another automotive makes, which I mention here, on the second gen Leones, but their suspension could get way too stiff and might need a small cut off on the coil spring's wire, to work. Remember: going too weak or too stiff on the suspension on any car, could make you loose control of it, mainly on irregular terrains, so this could be Dangerous if you don't know what you're doing. Disclaimer: Use this information, and All the information I post, at your own Risk! Introduction: Please note that this writeup is intended to give you ideas to make stronger the Suspension, intended for rude use / offroad \ heavy loads; it gains a Sporty feeling, but the suspension could become harder, Stiffer. The modifications written here, has been tested with great results on the third gen Leone (EA82) Wagon only. My dad purchased this 1985 Subaru Wagon EA82 new that year; I've done regular maintenance and lots of repairs on it since then; when this subie became mine, I did many modifications and named it: the "BumbleBeast" I've Been part of this Great Club since year 2001 and I've Learned a Lot (mainly here, in this Awesome Website) about how to fix and improve many Things, but I personally have Discovered by myself, many other things about those older subie Models, things which I've Shared here with you, like the following suspension ideas... Let's begin! In this Writeup: ► Shock Absorbers and Coil Springs. ► Alternative ones from non-Subaru cars. ► Their part numbers. ► Photos. First Part: modifying the Suspension with other cars' Parts: About The REAR Suspension: In my own humble opinion, the subaru's weakest suspension part is the Rear shock absorbers; no matter how careful I drive, if I hit a pothole with some Load on the car, is almost sure that a Rear shock absorber will say Good Bye... Those are somehow, the "Achilles Heel" of the Subie: The trail arms, of the front wheel drive (2WD) Subarus, have a different mounting point (perch) for the Shock Absorbers than their four wheel drive (AWD) counterparts, as you can see in the following photos: The 2WD ones mounts the shock absorbers in the position where normally goes the constant velocity joint (Axle)... ...while 4WD ones have the said mounting point, raised, two inches higher on their trail arms, to let the axle pass. So, Subaru made two different Rear Shock Absorbers for the EA82: The Front wheel drive (2WD) Models' Shock Absorbers, has the base plate for the coil spring, welded to their bodies, two inches (2") Higher than the four wheel drive (AWD) ones, to compensate the lower mounting point (perch) on the trail arm; and both models use Same Coil Spring. 2WD .Vs. 4WD ► Using a 2WD shock absorber, on a 4WD subie, will lift the rear, due to the Higher position of the Coil spring's base. Then Subaru Suddenly changed the Production of those two, for one "Universal" Rear Shock absorber, which featured Adjustable Base for the Coil Springs, so you can place said base Up or Down (2" of Difference) and also included a "Middle" (1") Position; Despite the Coil Spring's Base position, the Total damper travel of those "Universal" Subaru Rear Shock absorbers, is 160 mm / 6.3" inches. Here is a Photo of said "Universal" Rear Shock Absorber, with Part Number and KYB equivalence: The Subaru Part Number for the Spring Coil's Base (seat) is: 21025GA230 But those Rear Shock Absorbers are Still Weak to handle our Horrid Roads, plenty of Potholes -and even Potholes inside the Potholes- with my Loaded Subaru "BumbleBeast", especially during my Usual offroad Weekend Mountain Travels; and I wanted my Subie to be Taller without a Lift kit in the Rear. Chapter 1: How to Improve the Rear Suspension: First I Needed Stronger Coil Springs for the Rear of my Wagon, because Usually I Travel with it Fully Loaded and many people in our very Bad Roads; also I do many Weekend "Mountain Adventure" Family Travels offroading; so, let me explain my own Method for searching and finding suitable replacements: I took off one of the Old Rear coil springs in order to take measurements of it with my vernier scale (Caliper Tool known here as "Pie de Rey" = King's Foot), and then I carried it as a Sample for comparison purposes, to the local Junk Yards; then I searched, and searched for suitable replacements, among piles of coil springs and strut assemblies, found on many different local Junk Yards, called here "Yonkers" as you can see in the following photo: Honduran “Yonkers” are different from the regular “PaP” (pull a Part) or any other USA version of a Junk Yard; they receive the cars and disassemble everything; sending the unuseful things such like crashed metallic bodies and cracked plastics to the Recyclers; and then they classifies everything in “Areas” so, you can find in a Latin American “Yónker”, one area dedicated solely to Doors, other area dedicated to Engines, other areas for Starters, Alternators, Seats, Headlamps, Struts, Mirrors, Transmissions, etc, etc, etc, let me share with you a photo of a typical Latin American “Yonker” (Junk Yard): I went there carrying my Vernier Scale and made annotations of the Measurements found on the Coil Springs that could be suitable replacements; then I came home, contrasted those measurements and researched online further information regarding those coil springs that I found to be as possible candidates; because they don't only need to have similar size and shapes; they must be of similar capabilities. The variables that I compare, are their Measurements, Spring Rates, Load Rates and Wire Diameters, to find the perfect ones for the application. I wanted taller coil springs with similar diameter and shape, but with increased load rate / spring rate, under certain margin, because you can not go too stiff nor too soft on them, otherwise the stability and safety of the car would get compromised. So after many search and research, I found that the Subie's Rear Coil Springs are almost the Same Size, Tall and Wide than the Honda Accord's Front Coil Springs (1986 ~ 1989) but the Honda ones have Thicker wire and it has Two More Turns than the Subie ones; so I Swapped the Rear Subaru Coil Springs with the Honda Front ones; it Makes the Subie More Capable to Manage the extra Weight when is Loaded, without going too low; also the Honda's Coil Springs does Lift the Subaru's Rear in two inches (2") and its Movement & Handling while Driving in Unpavemented Roads / Pot Holes, becomes Firmer and Sportier. So they gets rid from the Bouncing and Saggy Butt. The Front Honda's Coil Springs that Fits on the Subaru's Rear, came from the 1986 ~ 1989 Honda Accord, (The Prelude from that Era has them too) it could come either from the Manual or Automatic, With or Without A/C, but Keep in mind that the Hondas with manual trans and without AC, does have weaker Coil Springs than the Hondas with Auto Trans and A/C, so I chose the Stiffer ones. The Part Number for the Honda's Coil Springs, is: ~► MOOG CC248 for "Moog" Brand. ~► NCP 2775298 for "Napa" Brand. So, How to get Rid of those weak Rear Shock Absorbers? My Subie was in dire need of Stronger Rear Shock Absorbers, so after Searchin' and Researchin' a Lot using "my own method" that I explained above, I Found This permanent and simple Solution: To Swap the Toyota 4Runner's Front Shock Absorbers in the Place of the Subaru's Rear ones! (Despite that this two photos says: "Subaru 4WD" the shock absorber shown on them, are "Subaru 2WD" the ones with taller spring perch. Sorry, that was an involuntary mistake while editing the photos on a hard day's late night...) As you can See in these Photos, the Toyota ones has the Same extended Tallness than the Subaru Ones; Also the Toyota ones has the Same Wide Base for the Coil Spring and they use almost the Same Design; But the Toyota Ones are Thicker and Heavier, have a thicker bar, they're more Capable to manage the Stress of Riding in my Crazy Country Roads, especially for offroading with a Fully Loaded Subaru Wagon. (Subaru 2WD shock absorbers shown on this photo) The Subie Ones had their Threaded top of Nº 10 mm and the Hole opening on their Base is for a Nº 10 mm Screw; While the 4Runner ones has them Nº 12 mm Screws; So the Subie's Nut on the Base for Nº 10 mm Screw had to be Removed in order to Use a Pass-Thru Nº 12 mm Screw with its own Nut and locking washer. The Subie's Part for the Shock Absorber's Top shall be Modified too, in order to Accept the Nº 12 mm Screw Size instead the Older Nº 10 mm One, I Just made the Hole Larger; pretty easy! For Those who want the 4Runner's Shock Absorber Part Number, it is: ~► KYB 341232 in KYB (Kayaba) Japanese Brand The salesman from the Aftermarket parts store where I purchased those KYB 341232 Shock absorbers, said that those are for the Front of a Toyota 4Runner for the 1998 model year; However, Toyota used the same platform and shared these shock absorbers in the Hi-Lux Surf, and the Land Cruiser Prado / Colorado (J90) Which is a very Popular car here, in LADM (Latin American Domestic Market). The Following is a Screen Caption of a website that I Saved long time ago, where you can find the Original Toyota's Part Numbers for their OEM Shock Absorbers... According to online databases, it does interchange with: ~► Monroe D8344 ~► Sachs 230631 ~► BOGE 27-D67-A I Tested the KYB 341232 only, any other Toyota Shock Absorber could be "Visually" Identical, but might have some differences, such like even shorter travel, Harder ride, Thicker Body, etc ... So I Kindly suggest you to Stick to the KYB Part Number I Provided, I can not guarantee to work the other ones... My Subaru "BumbleBeast" Runs very well with that Setup: Toyota Shock Absorbers + Honda Coil Springs in the Rear, since many, many years ago... ...despite that they has only 4.3" of total damper Travel. (as I wrote above, the Subaru rear Shock Absorbers has 6.3") But that shorter travel is not an issue, because the Coil Springs won't let it go down more than 4" under compression, and the total expanded -extended- lenght is Equal to the Subaru's ones, as you can see in the photos above. In case you need to do a Rear Alignment on these Subaru Models, here is the Factory Guide about how to do that: ► IMPORTANT NOTE: You can use the 4Runner's shocks along with the subaru coil springs, to keep the original height of the suspension. If you use the Honda coil springs, the rear suspension will be lifted two inches (2"), stressing the angle of the rear axles in 4WD (AWD) models only. (You might drop the rear differential a little to compensate the lift) The 2WD (FWD) models doesn't have any problem with that configuration. ► LEVELING ISSUE: Since Those front Honda Coil Springs does Lift the Subaru's Rear two inches (2"); after that Swap, I had to Lift the front of my "BumbleBeast" an equal amount to compensate, using lift blocks, as you can read the complete information and see many photos about that, ~► Here, but also, below you'll see a photo of said lift blocks already installed. About The FRONT Suspension: The 4WD (AWD) Shock Absorbers has a 5.75" / 147 mm in Total damper travel, While 2WD (FWD) Shock Absorbers has a 6.12" / 155 mm in Total damper travel. Since I couldn't find any 2WD (FWD) Shock absorbers locally, I installed into my "BumbleBeast", new Monroe Front Shock Absorbers for the XT; this are their part Numbers: Passenger Side: ~► 71876 .................Driver Side: ~► 71877 Chapter 2: How to Improve the Front Suspension: Next, I wanted to install Firmer Coil Springs for the Front of my Subaru, as I already did on the Rear, to have equal balance of handling and sportier feeling (Harder / sportier Suspension). Initially, I searched for stiffer Coil Springs for the Front of this models of Subaru, on year 1999; Because my 2.7 Wagon (now dead) Project, had the Heavyweighed ER27 engine, plus a Fiberglass & Metal sheet Reinforced Front Bumper; I Needed Something Stronger than the EA82's coil Springs to better carry that extra weight. So, using "my own method" which I described with details above; I Found that a suitable replacement are the front coil springs from a Ford Tempo; which looked pretty similar to the Subaru ones, but having around two more Turns and a thicker wire. I found those Tempo Coil springs on year 1999, already taken outside their car; (they only had a Mark done with white paint marker on them, that said: '94 Tempo) and originally I used them on my Loyale 2.7 wagon project; but since it is dead (More info, ~► Here) I decided to remove certain parts from it to make my EA82 Weberized Wagon (Now renamed as the BumbleBeast) a Better car, with the Better parts from the two; including the front Tempo coil Springs. So, I installed those Tempo's Coil Springs on the front of my "BumbleBeast" and those add to the Front Suspension the Same Firm & Sporty Feeling that the Rear suspension obtained with the Above written Modifications. ► IMPORTANT NOTE: The Ford Tempo Coil Spring's total radius -diameter- is Half inch (½") smaller than the Subaru ones, but that is Not a problem, I Drive my Subaru "BumbleBeast" with them since Years ago and they doesn't "Shift" nor make any clunk noise. Somehow these front coil springs from the Ford Tempo, aids to keep the Camber / alignment within specs; other coil springs that has been tested on the front of these Subarus, makes the camber to be even Worse... Further information on the subject, photos and even a Video can be found, ~► Here. (thank you Bryan Dudas / Subaru Adventures \ Anderson Design and Fabrication, for your kind words) According to the info I obtained back then from the Junk Yard's salesman, the Front coil Springs came off a basic 1990's "Second Gen" Ford Tempo with in-line 4 Cylinder engine and manual transmission; Those are "Non-Progressive" Coils, so they measure the Same between each turn. I searched on internet for The Part Number for those Ford Tempo Front Coil Springs, So those should be: ~► MOOG CC854 for "Moog" Brand. ~► NCP 2775375 for "Napa" Brand. These are the Lift Blocks I had to use in the Front, to compensate the Rear Lift, as I explained in the "Leveling issue" note, written above: ► IMPORTANT NOTE: The Ford Tempo Coil Springs I used, came out from a used 4 cylinder Tempo, so they were used and not as Stiff as brand New coil Springs, so I didn't had any fitment problems nor had to trim them; but People who has brought those Coil Springs brand new, had to Trim them up to 1.5 Turns, especially the Moog CC856 because those are "Progressive" which means that they has different spaces between coils and they're intended for heavier V6 Automatic Tempos, and are even Stiffer than the Moog CC854 I Used, so I don't recommend to use those uncut, they might be too stiff for the Subaru. Also, I found that the Front Coil Springs from the Kia Sephia (first and second generation), are almost identical to the front coil springs on the Subaru Loyale; but the Kia Sephia ones have a thicker wire (around 2 mm) and the Sephia ones have a slightly bigger total radius, but they fit on the Subaru's shock absorbers; and the Sephia ones have an increased load capabilities. Let me Show you: They're almost identical, here are the Sephia's ones, Load Capabilities: Even the first gen Sephia, has an increased load ratio than the second gen Sephia. The ideas in this writeup are for those who are interested in Improving the Suspension of their Subies (Specially for Off-Roading), let me Tell you again that this Mods are intended for a More Rude Use and Longer Lasting Parts; not for Confort; so be adviced that the Ride will become Harder, with the stiffer suspension. Despite that, I use my lifted Subaru "BumbleBeast" as daily driver on city roads & Highways during weekdays (60% usage) and offroading on Weekends (40% usage) on our usual "Mountain Adventure" travels with my Family + Luggage, toys, food, etc... ...to Drive my Modified Subie with those 4Runner Shock Absorbers + Accord's Coil Springs in the Rear, and the Subaru XT Shock Absorbers + the Tempo's Coil Springs in the Front, Changes the Handling & Feeling of the Subie in the same way you'll notice while Driving a Police Car after being Driving the Civil Version of it before. I've Test Drove it Unloaded and Loaded, up to 160 KPH (100 MPH) in Highways... ...Bad Pavemented Roads and gravel off roads... ...and it Feels Really AWESOME! ... ... but rides Pretty Hard to be a "Family Wagon" anymore. Please see further details on the Second Part of this Writeup, below!
- 1 reply
- 17
- Struts
- Loyale 2.7 Turbo
(and 8 more)
Tagged with:
Yes, it Doesn't Need to be Grounded... Seems like The Positive Crankcase Ventilation Valve (PCV) Located behind / under the Carb, in the intake Manyfold; is receiving Oil from the Hoses that brings Fumes from each Head to the Air Filter Box... The PCV is connected to the Air Filter Box too but maybe a Bad Hoses` Connection at the Air Filter Box is making the PCV to Suck the Oil that is Blown by those Head's Hoses... So I Suggest to Check the Hoses Config and maybe it will be needed a New PCV Valve. Good Luck; Kind Regards.
How to fix hole in hood...
Loyale 2.7 Turbo replied to Txakura's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Good Idea and Good Work! ... Both are Lookin' Very Nice! Kind Regards. -
Welcome! Could you Tell us the Reason Why your Subie isn't Runnin'? Kind Regards.
90 legend/90 vanagon virus
Loyale 2.7 Turbo replied to thummmper's topic in Meet n' Greet. Your USMB Welcome Center
Welcome! It will be Nice to See Pictures of your Car here! Kind Regards. -
Well... I Believe that I Forgot to write that the RED OIL is used to Restore & Shine Wooden Furniture... here is very widely used & Easy to Find: http://gatesantiques.com/red_oil_furniture_polish_gates_antiques_restoration.html and it might be Known also as: "Wood Oil" it works Wonderfully! I Hope this can Help. Kind Regards.
Holy Cow! ... inside the Disty itself is a "Module" that Works as the Older "Points" System did but Electronically; sometimes it got Burnt out and Stop Working; So even if the Rest is Perfect, there will No Spark at All... I Faced that Problem in some Toyota's 22R and once Swapped it Works Great Again... Maybe that is the Case with your Subie's ignition Problems. I Hope this can Help. Kind Regards.
Water Leak from front of engine
Loyale 2.7 Turbo replied to justindenney's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am not Completely Sure about the Trouble, Maybe I Didn't understood it well... but let me tell you that the Water Pump has a 5/8" Hose that comes from the its upper Part in 90 Degrees to give a Hot Water Flow to the Heather... maybe it has Failed... I Hope this can Help. Kind Regards. -
Oskar_Subaru's ride [56k warning]
Loyale 2.7 Turbo replied to KristjanJohann's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Beautiful Subaru on a Wonderful Country Landscapes... Thank you for Sharing such Nice Photos! Kind Regards. -
Broken intake bolt XT6
Loyale 2.7 Turbo replied to MilesFox's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you have Problems to ReThread in Aluminium, I Kindly Suggest you this Writeup Plenty of Pics: http://www.ultimatesubaru.org/forum/showthread.php?t=73277 Kind Regards. -
Welcome!
Hello from Tauranga New Zealand
Loyale 2.7 Turbo replied to hedgier1's topic in Meet n' Greet. Your USMB Welcome Center
Add an ¡Hola! (Hi!, in Spanish) From Central America ... ... Welcome. -
While you Find the Answer & Fix it, I Kindly Suggest to Avoid to Smoke a Cigarrete inside! I Had that issue in my Old EA82 Wagon when I Swapped the Stock Hitachi Carb with a Weber Carb and mistakenly cap closed the Gas Tank's Vent Line... I Just re Opened it an the Problem has Gone Forever. I Hope that Idea can Help: Maybe it has Mistakenly bad Plugged Vacuum hoses somewhere; I Suggest to take 'em to the Dealer... it Could be Dangerous. Kind Regards.
Seems like the Coil itself is Dead... could you Try with another one?
By "No Spark" do You Mean at Each Sparkplug's Wire end? ... Because an internally Broken wire, in example: The Main Wire that Goes from the ignition Coil to the Distribuitor, can be the Cause. Those Wires can be internally Damaged... did you Checked already if EACH Sparkplug wire is getting Power? Kind Regards.
Thank you for your Kind Words & Best Wishes! Well... Gotta Love those Thick Glass Headlamps! ... ... Their crystal clear glass Never get Dark and they can receive a Huge front Impact from another car's Bumper Directly without any Damage! ... Could you imagine how will looked the hit if that Sportage's Bumper would hit a Plastic Headlamp? The Damaged Part was the Car's Base for the HeadLamp that got a Little Bent; but that is an Easy Fix. Kind Regards.
Starting from the Very Basic to the Hardest: I Kindly Suggest you to Check First the Fusible Links, and if Everithing seems to be Allright, Check for Bad ECU. Good Luck! Kind Regards.
