235
Everything posted by Loyale 2.7 Turbo
I Believe That is Because your Brat does not have a Digital Blink Control Box... Just the Analog Blinker. ... ...I Remember that...
gauge install with pics
Loyale 2.7 Turbo replied to spokanesoob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nice Setup! ... I Like how the new Gauges sees in the Pillar... -
The Official Camber Plate Thread
Loyale 2.7 Turbo replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thank you for your Kind Reply... Now I Think I Will Check my Subie`s "Knuckle" -
Camber & Caster Questions!
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So, that`s the Part where the Axle ends, the Wheel`s Main Bearings Are, the Strut and its Spring holds it, and it Holds the Brake`s Disc plus Everything Involved, Isn`t it? "The Knucle" ... I Didn`t Knew its Name... Thanx! OK, Now I will made Plans to take it Off and inspect it Very Carefully. Thank you for your Kind Replies! -
Thanx for the Kind Replies! .. I just saw this Thread: http://www.ultimatesubaru.org/forum/showthread.php?t=47237 Do you Think that Those Camber Plates can Help me to Fix the Problem? -
I have Problems with one of my Wagon`s Alignment as you can see here: http://www.ultimatesubaru.org/forum/showthread.php?t=89868 Can those Plates help me to Fix that Negative Camber problem? -
Dash issue.. Need help plzzz
Loyale 2.7 Turbo replied to 7point62fmj's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes I would cry for sure too, what a sadness... It Means that the Wire that Got Fire, was without any Fuse Protection... -
OOOOOHHH Lookie what I got!
Loyale 2.7 Turbo replied to The Beast I Drive's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, I Was about to Suggest that... Pics Please! ... That would be Nice! -
water out the EXAUST!!!??????
Loyale 2.7 Turbo replied to GREENSUBIE's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, I Was Thinking in That, and also it can be a Muffler Still Full of Water... -
Nice Looking Finnish! ... I Like It! Just Another Question: The Handle that sees in the Roof... is Stock? ... it seems Bigger and in Different Position than the Wagon`s ones. -
Grounded lead or bad guage?
Loyale 2.7 Turbo replied to ettev's topic in Old Gen.: 80's GL/DL/XT/Loyales...
...Or the Gauge`s Wires, it could be a Wire Grounding... Except if the Gauge doesn`t Low even with Battery Disconnected... in that Case, Just the Gauge itself. Good Luck! -
I Haven`t had that Problem in my Subies, but I Fixed Same Problem in a Friend`s Ford Ranger `95 (Here Sold Rebagged as Mazda B2300) it was the Ignition Key`s Switch. That Switch was loose, not too Much, but Enough to not let the inside`s Current Bypass parts Engage Properly... it took several Hours to find that. It Might Doesn`t Apply to your Subie`s... but you Said that "shutting the car off and back on seems to fix the problem" ... and that makes me think that`s might be the Switch`s Fault. Good Luck!
EA82 detonation
Loyale 2.7 Turbo replied to paulpicard's topic in Old Gen.: 80's GL/DL/XT/Loyales...
...Or you can move Timing up to 22º or Around and see if by that way the Problem gets Fixed... but I Believe there`s an EGR Issue involved... Good Luck! -
My latest score!
Loyale 2.7 Turbo replied to Hondasucks's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nice Acquicition! Yes, Pics Please! -
They are EVERYWHERE!
Loyale 2.7 Turbo replied to 86HatchShelby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ha, Ha, Ha!!! Built Like a Rock! ... `cos They do Nothing... LOL! ... ... Nice Comment! Yes, GMC "Sonoma" is what I did Have in my Mind... Thanx! -
The Same Plattform Used on the Chevy S10, came as GMC... ¿? ...I Don`t Remember the Model`s Name, but it can Be. The Important here is the Subie: Nice Found! Thanx for Sharing! -
my kind of luck...
Loyale 2.7 Turbo replied to The Scooby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I Guess that you`re Writing About a Weber Carb Swap, isn`t it? I Suggest to see my Write Up About that: (it might be Helpful) http://www.ultimatesubaru.org/forum/showthread.php?t=74206 -
Way Cool Gift from Friend for the Older Gen
Loyale 2.7 Turbo replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ha, Ha, Ha! ... ... Ha, Ha! ... Shoes with a Snack! ... LOL! Well... I Have the EA81 Original Subaru Manual... By Mistake! ... I Ordered the EA82 one... I can "change" it if Anyone wants it... Just send me a PM -
just put new dashlights on the Brat...pics..
Loyale 2.7 Turbo replied to jonas's topic in Old Gen.: 80's GL/DL/XT/Loyales...
To Change the Glovebox with Led is Good Idea! ... My Subies got a White High Intensity Led Bulb, and it seems to be like a White Neon House Light inside! There are "Standard" Leds, and High Intensity ones... for Single Bulb Aplication -like GloveBox- is better the High Intensity ones... I Like very Much the Looks of your Dash, and the Whole Lights settlement there, as the Satellite Radio, the Stereo, the Dash`s ... They`re Nice Looking one Side to Another. in Other Cars, the Lights settlement, doesn`t Looks Good like Yours. -
Coolant additive...
Loyale 2.7 Turbo replied to MR_Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My Subies are the Exception: They Carry "Made in Honduras" Old Style Brass Radiators... Great! -
Nice Looking! ... I Like It! I was Thinking on Swaping my Subies` Dash Lights, but with Led Bulbs... http://www.ultimatesubaru.org/forum/showthread.php?t=72139 ...Didn`t done that Yet, but I think by this Year`s end, might be... Don`t you liked to try with LED`s ? But I Really Like the Looks of your Subie`s Dash
