Loyale 2.7 Turbo
    235
Everything posted by Loyale 2.7 Turbo
  1. Yes, you´re goin´ quick in resuscitate and revive your Loyale... I think it´s Good Idea to give it a Second Chance to Live, and to improve it! What a bad accident with an almost unbrained camaro´s driver; But the Good thing, is that You are O.K., no Damage to any Person involved... The Loyale did Sacrifice itself to save you, as it is designed, so I think it´s good Idea to resuscitate that car, and could be a Nice Project too... Everything that happens, that first seems to be Bad, then with time becomes a Good thing that happened; so, this accident will give YOU good new things (Skills, improved car, etc... maybe spiritual or material things, or both) and good luck; and for sure, will give HIM (the unbrained Camaro´s Driver) a whole live of Bad Luck... (for ´the bad "Hit and Run" attitude) you know; it´s the Life´s Law: You´ll Harvest what you sown... Anyhow: Good Luck!
  2. Just came back here to say Good Luck in the Maderas del Carmen Mountains Trip, and to Add some info. about Subaru in Mexico: Subaru Started to Sell its Cars in Mexico in May or June of this Year, in part it was due to its Rally in Mexico, but I don´t know further details. You can Check this out: http://www.subaru.com.mx/ maybe they can help you if you need a spare part in mexico. Good Luck!
  3. Yes, I suggest Photobucket: www.photobucket.com it´s Free. Also, Are you really sure that is impossible to fix your subie? here in my country, I saw the most unbelievable crashed cars to be Fixed and runnin´ again; maybe you can fix yours... Good Luck!
  4. Well... I don´t hate Carburetors, Just the Hitachi Craps on Subarus Yes, I hate those... Why don´t you Swap your Craptachi for a Weber? I have done that on my White EA82 Wagon, and with the Weber the EA82 Performs a lot Better. Good Luck!
  5. I just wanna Tank you for Sharin´ those nice Articles with us.
  6. Check this site: http://www.nextag.com/electric-choke/search-html
  7. A little High Price, but it seems to be in Good Shape, so if you can get it for less, it will be a Good Buy! Good Luck!
  8. Yes, is Good Idea to Check that, and Everything Electric within... Good Luck!
  9. It lead me to Think in the EGR Valve... when you go Uphill, and EGR is Worn; some Oil can go inside the Intake or in the Carb, and shut off the Engine... Did you saw Oil in the Spakplugs? Also, check for a Broken Timin´ Belt... or a Broken Wire in the Main Link Fuses, the Black Box near the Battery... Good LucK!
  10. YES! My white EA82 Wagon got Same Mileage, but 21 years and four months of Ownin´ it; and Countin´ (1985) and Yes, she Loves when I drive next to the Redline...
  11. Well, both my subies got Oil under the Engine, (It seems to Come out Like Sweat) but, my EA82 was a li´l bit Cleaner when I took off the Oil Pan, two years ago... Maybe is ´cos I use two times a year, a QMI "Motor Flush" ... A cousin that works in Costa Rica, told me that some Oil Brands have more tendences to leave strong yellow barnish & gum in the Oil Passages; he told me that the Worst on that aspect is Peenzoil, and the Cleaner one is Chevron... I used many, many years Chevron 20W-50, but now, I do preffer Motul Brand; (It Hides the "Tick of Death" Sound Better) it´s cleaner. Well, Time to Cleanin´ and Also I suggest that when you make the engine to Run Again, Use a Motor Flush in Next oil Change. Good Luck!
  12. Thank you Soo much for the Info... We still are getting as much info about as we can, we hope to start the project in January 2007 if we can...
  13. Well, they are the same, except for a simply but great thing: the Spring Base on the Struts. Let me Explain: 2WD models got struts with its spring base 2 inches down in the Strut´s Body than the 4WD Struts, since 4WD struts got its spring base more "UP" than the 2WD, you can make the rear end of a 2WD Loyale, to lift up around 2" just by changin´ its 2WD Struts for the 4WD Struts. Good Luck!
  14. Also, I suggest to Check the Hoses that came from the Tank, inside the engine´s bay (Vent. Recirc.) maybe... in my Weberized EA82 White Wagon, it was the reason of gas evaporating/smelling. Good Luck!
  15. Nice Idea But I wanna Ask you if you have taked photos of that and procedure, ´cos i´m havin´ same troubles with my white wagon, if so, Could you post ´em here? Thank You!
  16. I think it will fit easily, but if you can post a Pic of the Rad, it will be Better to say.
  17. Just to Help with my Idea... I used a piece of Wood, with Sandpaper & Paint to make it look almost alike the original dash colour, then I make the Radio "Sit" on the base of the Dash´s Openin´ and this is the Result:
  18. ~► http://www.ultimatesubaru.org/forum/topic/122165-ea82-to-er27-swap/
  19. Yes! ...but I found some info about that, that says that at the end of install process, belts shall end like that. Milesfox did share more info about that Here: http://www.scoobymods.com/forums/archive/index.php/t-4551.html Good Luck!
  20. Well... I think about This: Are you Shure that the passenger´s cam is pointing down, and the DRIVER side cam is pointing UP?
