235
Everything posted by Loyale 2.7 Turbo
Water in GearBox! O.o
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A li'l Update: My "BumbleBeast" is working good, just like if nothing wrong had happened, thanks to God. Right now I am changing a couple of Parts on the Steering area, Then I'll take it for an Alignment... Kind Regards.- 44 replies
- 3
- Transmission
- Manual
- (and 8 more)
Now that Phrase is like the ones I use to talk... Also it suits perfectly some local people I know here in Honduras.- 44 replies
- Transmission
- Manual
- (and 8 more)
Transmission pop out
Loyale 2.7 Turbo replied to Sir Moist's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You forgot to add the Details of your Ride, such as Model Transmission type, etc... -
Appreciated SubaruJawn, Very respectfully let me tell you this, despite that I know that you will not like my advise: Try to avoid driving on Rainy nights with those Blueish lights, the deep blue accent of the light is somehow "Swallowed" by humidity, making to drive on wet pavement with such "illumination" to be pretty Dangerous. Such kind of bulbs are used more for the Looks they give to the car, but they really provides much worser illumination. Kind Regards.
Kia Sephia Sporty
Loyale 2.7 Turbo replied to Loyale 2.7 Turbo's topic in Non Soob Cars and Bikes Discussion
This photo was taken moments before I did the oil change on my Wife's car, the "KiaStein" I was drinking the Orange Steaz and eating a mix of seeds & Dried Fuits ... my favourite snacks I have years using this "Delo 400" motor oil which is certified by the American Petroleum institute to be Suitable for Gasoline and Diesel Engines. (up to date SM class) Kind Regards. -
Time for an Update! After the recent weird climate changes in the Caribbean (More info ~► Here) first my li'l daughter was ill, then my Wife and finally I, so I ended using the money on medicines. Now we're alright, But I needed my "BumbleBeast" back to its Daily Driver status, as soon as possible. So, this past weekend, I simply poured fresh 80W~90 GL-5 transmission & differential Oil, and the Beast is running again; a bit noisey but flawlessly as only a Subaru could survive such ordeal. Of course I plan to open and Check the Transmission, but untill I have all the needed items to reseal it, meanwhile I hope it could keep working good. Kind Regards. ► Edit: Fixed the web link on the word: "Here" above.- 44 replies
- 1
- Transmission
- Manual
- (and 8 more)
Why won't my car start?
Loyale 2.7 Turbo replied to jnorion's topic in Historic Subaru Forum: 50's thru 70's
Sometimes the best route to go is Trial and Error, especially with this old-school carbureted engines, so, if you can manage it to start, let it warm a little, then move the distributor slowly counterclockwise and then clockwise, until it seems to run Better, and then move the idle mixture screw on the Carburetor; when it is better at idle, move again slowly the distributor and try accelerating; that will give you an start point to put the timing & mixture closer to where they should be. Also check the PCV valve and hoses for vacuum leaks, correct if necessary. Kind Regards. -
Don't forget to share some Photos with Us. Have a Nice Wheelin' Trip! Kind Regards.
Seems like we have more durable and crazier, Alternative ideas for Rear wheel drive conversions, in my Country: This thread might continue here: ~► http://www.ultimatesubaru.org/forum/topic/88248-rear-wheel-drive-loyale/ Kind Regards.
I am not very familiar with these newer models, however it worth tell you that some Fuel Pumps' Circuits, receives the signal from the Crank position sensor to let the fuel pump work, so it will be stopped / not receiving voltage until the engine moves, either by the Starter motor or by itself. So, I kindly suggest you to re-check the voltage at the Fuel Pump while cranking. Kind Regards.
I would start by Checking the Timing at the Distributor, then the Choke. I believe that your Carburetor needs a Cleanup... Good Luck! ... Kind Regards. -
GL Dashboard to DL Swap
Loyale 2.7 Turbo replied to Tronkus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You want to install a GL instrument Cluster on your DL, both EA82's. The USMB member: "Fangster" mentioned that he accomplished that, in Australia, on this Thread: ~► http://www.ultimatesubaru.org/forum/topic/50291-93-loyale-speedometer-cluster/ Also, another Australian: "hilux_1990" wrote that he did the same retrofitting: on this thread: ~► http://www.ultimatesubaru.org/forum/topic/4560-l-series-gauge-cluster-swap/?p=99981 But no one did mention an Step by Step procedures ... ... maybe another members could elaborate further on this subject. Good Luck! ... Kind Regards. -
Dash bulb replacement
Loyale 2.7 Turbo replied to NocturneVoyager's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looks good, but very Bright! I kindly suggest you to Drive with the Dimmer knob at minimum (Low) position. Kind Regards. -
Weber issues... idle won't kick down
Loyale 2.7 Turbo replied to LucasP's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is another thread going on regarding Weber Jettings. You might find useful info there: ~► http://www.ultimatesubaru.org/forum/topic/144895-ea81-weber-3236-or-3838/?do=findComment&comment=1293629 Kind Regards. -
Ea81 weber 32/36 or 38/38
Loyale 2.7 Turbo replied to tweety's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Great Plan, Kind Regards. -
Exactly what I meant. Horrible story with that ungrateful man... ...that phrase is New for me. Kind Regards.- 44 replies
- Transmission
- Manual
- (and 8 more)
Lots of Subaru Reprodution Decals (my new store)
Loyale 2.7 Turbo replied to Pooparu's topic in Products for your Subaru
Awesome! ... ... I really like your Amazing Job, and the "Subaru is my Religion" new design. Kind Regards. -
If you talk with him again, please tell him that I send my Greetings. He's not alone. Kind Regards.
I'm glad that you understood that I went thru many "Trial and Error" tests on my Wagon, prior to decide which main fuel Jets were the most perfectly working ones; but you must keep in mind that all the Tests I did, were done with the 1.8L Engine moving a heavyweighted Wagon body, with certain amount of added Load; which delivers Different Results than testing another 1.8L engine, moving a Lightweighted Trike. Long story Short: You must do your Own tests. Too big main fuel Jets, will make the engine to Waste the Gasoline, Too small main fuel Jets, will make the engine to Loose some of its potential... Good Luck with the Jet Sizes' Test. Please don't forget to share the results here with us. Kind Regards.
